Question about Morphy Richards Accents 44744 4 Slice Toaster, Copper
Voltage change to 120V
Can I change the 220v plug out with a 120v plug and operate the toaster at 120v? I know it will draw 15 amps instead of the 9 amps on the name plate. We live is the USA and our circuits in the kitchen is 20 amp 120v.
    Habit-Forming:
  • 31 Answers
You can change the plug out but I very much doubt that your toaster will even heat. The way toasters work is by a resistance wire that heats up because of the current going through it that causes the wire to heat up. Since the wire that is in your toaster is designed to heat up under 220V drawing 9 amps. SInce you are now supplying only 120V then since I=V/R then in the first instance 9=220/R or 9*R=220 =24.444 Ohms Since in the second instance your V=120 then your Current =4.9 Amps and this will not be enough wattage to heat up the wires.
Posted on Aug 02, 2013
My 4 slice duo lit toaster "toasts" the upper half of my toast more than the bottom half. Center elements glow red after about a minute while the end elements take about two minutes to glow. Thoughts?
It should not work that way take it back and get a new unit. I am assuming it is operating on the correct voltage. If it is a 220V unit on 120V it would work that way.
Dec 07, 2016 | Kitchen Appliances - Others
Can I use this thermostat to control a 310w, 120v heat lamp load?
Voltage & Amperage are two different things. Check how much amperage iheat lamp requires. Rich
Apr 13, 2015 | Dimplex ETS610A1 Electronic Line Voltage...
Bought a used air compressor with no owners manual. Just read that you should never use an extra long extension cord. Could doing this cause the motor to struggle and the unit to shut down?
If it is a 120V compressor, they draw about 20 amps when running. It takes a clean 120v plug and a 20 amp circuit breaker and dedicated outlet to operate them. Make sure the plug copper contacts are clean and bright and the receptacle also. It also takes a very heavy extension cord to operate them on a extension (and is not recommended), use a longer pressure hose instead.
Sep 21, 2014 | Dryers
Need a power transformer from 220v input to 120v output
Yes, you need a step down transformer. These are often rated in watts (the power rating is the same on both sides of a transformer) so it is easy enough to match this with the power consumption of the stereo. Apparently you will need about a 4kW transformer eg
http://www.220converters.com/store/p/45-Simran-THG4000-4000-W-Watts-Step-Down-Voltage-Converter-220v-to-110v-Transformer.html
Ugly things.
Jun 23, 2017 | Crest Audio CC5500 Amplifier
I accidentally plug my Wii that I got from US from 120v to 220v. I got the converter but I mistakenly plug it to the wrong voltage:(. I heard the poop sound. Did I burn the power adapter or the wii it...
You have most likely cooked the Wii itself, To check connect the correct power adapter to the correct system and in the correct power source ( 120v or 220v ) if it works all good if not you know you cooked it. If you are unable to test in this manner have it checked by a qualified technician.
Jan 11, 2013 | Video Game Consoles & Games
How can i change my 220V jet pump into a 120V jetpump?
Why do you want to?
You have to change the motor to a 120v model, same frame.
Service wiring has to have a hot, neutral and a ground. You should already have three wires so that is not a problem, just have to move one of the 220 hot wires to neutral. That will give you one hot, one neutral and one ground wire to make your 120V circuit.
If you only have 120V service and a 220V pump motor you can purchase a step up transformer that will take 120V in and give you 220V out. You must know the power in watts or KVA of the motor in order to purchase the correct step up transformer.
A bit more information about your situation would help.
Aug 19, 2012 | Plumbing
Hi, i have a dream machine sony ICF-c218 by mistak connected to 220v the original transformer is 120V & i also would like know the output voltage of this transformer so that i can change it 220V p
My self sushil from india pl.find the details
yellow-blue is 3.2 VAC
red-white is 4.2 VAC.
Clock is well functioning without frequencies difference error. I think the clock is using crystal for pulses generator instead of AC power supply frequency.
May 22, 2012 | Sony Audio Players & Recorders
Will my Logitech X-230 speakers work in a country with 220-240 V power outlets or would i need an adapter to use them there? If i connect them directly to the 240 V outlet, will they run properly or would...
Check the back of your sub to check your voltage range. You will see something like this: 110V-120V or 110V-220V. If you see the later, you are ready to go. If you see 110-120V only, you will need a power converter to power your speakers as well as any other 110-120V equipment. But no matter what, if it is 110-120V DO NOT PLUG DIRECT TO 220V!! It will blow your speakers. (I lived in Germany for 11 years.)
Aug 12, 2009 | Logitech Z-2300 Computer Speakers
Ac adapter
Hi I am an Indian too !
Of course you can use the 220v AC adapter, it will not harm your massager but may only underperform [slow speed, slow vibrations etc]
And be aware that the foreign products you receive, and have adapters rated at 120v are bound to get busted if you use them here in India, don't use them at first place.
Rather, buy an adapter rated for 220-240v for the same output voltage as that of 120v
Jul 12, 2008 | Televison & Video
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
Morphy Richards Accents 44744 4 Slice Toaster, Copper Logo
109 people viewed this question
Top Morphy Richards Kitchen Appliances - Others Experts
Mike
Ruth summersides
Are you a Morphy Richards Kitchen Appliances - Other Expert? Answer questions, earn points and help others
