Question about Vehicle Parts & Accessories
My 2001 Landrover Disco suddelnly wont unlock or start with the manual keys. All other electronics in car work. Any idea whats wrong?
Battery is new, key fob died long ago which is why I use manual keys , fuses appear to be fine, lock pin in door not broken ( connected to handle ). Locksmith opened car but has no idea why keys don't work . Said its like car does not recognize keys. Alarm goes off immediately when u put key in ignition. Stereo , lights etc all work .
  • Vehicle Part... Master
  • 14,036 Answers
Problem sound like key or immobilizer the land rover discovery need diagnostic equipment to trouble shoot or reprogram key.
Posted on Jul 14, 2013
SOURCE: 2006 chevy cobalt. new battery in fob for
Found a web site that instructed us to turn the car on and off 8 times within 10 seconds and leave car on, on the 8th time. this is supposed to put the receiver into program mode. Press a button on fob and turn car off. Should be ready. Tried it, didn't work. This is for fobs that have already been programmed with the 40 bit code. Pulled off positive battery cable for a couple of minutes and put back on. Now everything works.
Posted on Oct 15, 2009
  • 33 Answers
SOURCE: i locked my v40 volvo with the key fob but now it
first thing to try would be to replace the battery in the remote fob .Hope this helps
Posted on Oct 31, 2009
Danniboi
  • 1098 Answers
SOURCE: went to hospital parked car came out key fob not
Im not sure there is any easy fix for this so I will just give a little advice.
Can you give me the make and model of the car? and is the alarm and immobilizer a standard factory one? Will do my best to help you once I know the make and model, and the year please.
Regards
Dan
Posted on Nov 07, 2010
krishna pokh
  • 4 Answers
SOURCE: 2004 honda civic will not
hello frnd
adapt key with immobilizer and ecu.if not solved check wiring of ecu immobilizer and ignition starter switch.
thanks
Posted on May 11, 2011
SOURCE: My 2007 toyota avensis won't unlock with the fob
Did you get an answer to this??
Posted on Jul 17, 2011
When i changed ignition on 2001 ford explorer I ended up having to replace steering column now it wont turn over & the anti theft light flashes & wont stop. what can be done to get car started?
At least you know the anti theft system is working. Jokes aside, I would think that the electronic security system is not recognising the new lock and steering column. You could try leaving the battery completely disconnected for at least 2 or 3 hours to see if the system resets. Reconnect the battery and then try again with the new key. You will have to put the security code back into your radio as well. If this doesn't work, it may need to go to a Dealer to reprogram your electronic system.
Apr 13, 2015 | 2001 Ford Explorer Sport
Landrover alarm who stop going off
Inserting the key in the ignition and turning it on can work sometimes, but do you not have a remote for the alarm? Check the battery in the actual remote if you do have one. the alarm sounds as if (by your description) it has a back up battery, if so, youll have to locate IT and disconnect it, and that should reset the alarm. Without details, its shots in the dark here. Learn your vehicle, and contact a dealer to speak with someone who Should know his product. If your attempting to steal the vehicle as we speak, then I suggest you just run. ;O)
Apr 13, 2014 | 2000 Land Rover Discovery
Fuses checked and now the car wont run but did before I did this.
Doing a search online came up with very little info.
The only thing that sounded serious was to disconnect both battery cables and wait a couple of hours before hooking them back up.
Or even overnight.
The idea is to drain the memory power from the CCM in the car, then reprogram everything.
Your owners manual should have a section on replacing the battery in the car and the battery in the key fob. There is a procedure to reset the alarm at that point.
Jul 24, 2012 | 2001 Volkswagen New Beetle
Wont start
If the battery is hot, it possible that there is a short internally or the battery has been overcharged. A battery will get hot normally just from engine heat and electrons bouncing around to create the electricity inside the battery. First start with having the battery tested and then the charging system when the engine is running. Let me know what you find and if you need further assistance.
May 11, 2010 | 2001 Land Rover Discovery Series II
VW car key wont work
lock the car with key and hold it over for 30 secs,then,hold unlock button down on remote for 30 secs ,this should reset system....
Mar 24, 2010 | Volkswagen Fox Cars & Trucks
Crankshaft position sensor landrover disco
I have a series 2 v8, its cutting out when driving, when idling, have checked for spark..it didn't have any then when I came back after half an hour it started, the other time I disconnected the battery for half an hour or so & it started...nay suggesttions...??
Mar 01, 2010 | 2001 Land Rover Discovery Series II
When i turn the key in the ignition the engine clicks once and if i hold the key forward then i hear an electronic humm but the car wont start. what is wrong?
Either the battery is dead or you starter is bad.
Have someone give you a jump, does the car start now ?
If not please let me know.
Feb 08, 2010 | 2001 Mitsubishi Eclipse
Electronic lock/unlock not working
Apparently the "LOCK" function is working normally because the burglar alarm is being activated when you 'lock' the car. Is this right?
The fact the engine won't start when the burglar alarm is activated is NORMAL If the doors will not UNLOCK front the driver's door manual switch, I believe you have a bad DOOR UNLOCK relay in the control module.
Aug 10, 2009 | 2001 Hyundai Elantra
Alarm and imobiliser on a discovery 300tdi
before you cut or rewire the alarm, when welding the disco although disconecting the battery protects the battery, the imobiliser holds current, this my have gone into system factory setting, so it my be worth getting the imob and key re-conected, this is a cheap job at any Landrover specialist. hope your running smooth soon
Apr 27, 2009 | 1997 Land Rover Discovery
Vehicle Parts & Accessories Logo
79 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
