Question about Lenovo G560 067999U Notebook
Keyboard working first row keys not working
Why doesnt the third row of keys on my keyboard do not workk
The keyboard itself is defective. The keys are "strung" together in groupings. The T just happens to be on another string then the top row.. To verify you can easly hook up an external keyboard and verify that it works. Once verified it all works then the problem itself will be in the keyboard. Replace the keyboard. You can easly find them online and are not that expensive or hard to replace.
May 15, 2014 | HEWLETT-PACKARD ProBook 6460B
The keys on my laptop are stuck. They will not work
you'll need to replace the keyboard, it's relatively cheap. trying to fix a keyboard with sticky keys due to a spill or anything else isn't cost or time effective.
May 20, 2012 | HP Computers & Internet
Which is the shift key
Hi,The 'SHIFT' key is usually placed just below the 'Enter' key on standard keyboards.Here is a picture.
Jul 16, 2011 | Compaq Keyboard
The keys on the keyboard is not working. Mainly the bottom row of letters are not working.
Hi. If you have Mac, it seems that bottom row keys not working is a common problem but I can't find a solution yet. If you have a desktop PC, just replace the keyboard. It is cheaper to replace a desktop's keyboard than to repair it. If you have a laptop, you may try cleaning the contact between the keys and metalic contacts of the keyboard. Use a pencil eraser to clean the contact. You need to completely remove the keyboard from the laptop. If you are not a tech. savvy, you may have to ask for professional help.
Feb 03, 2011 | Computers & Internet
Can't type same key twice in a row on keyboard. Have to wait a couple of seconds before typing same key again. bar on bottom of screen flashes yellow every time I press a key and window toggles between...
Have you ever tried putting in another keyboard? If the
other keyboard works, it's definite that you have a defective keyboard, and you must get a replacement. This is my observation based from your comments that there is no problem with the keyboard settings in your PC.
Dec 02, 2009 | Computers & Internet
My home row keys (and only those 8) do not work.
Unfortunately, this is most likely a bad keyboard and the keyboard will need to be replaced. In the meantime, you can use a USB keyboard in its place.
Aug 21, 2009 | Dell Inspiron E1505 Notebook
All the keys bottom row don't work "zxcvbnm" this is the 3rd time three different keyboards
please open your keyboard by scriw tool and clean the carbin from your keyboard button from the bottom row.
Aug 13, 2009 | Compaq Keyboard
My dell laptop keys 1QAZ KEYS ARE NOT WORKING
if a row is not working, in this case at an angle, it usually means either the keyboard is going bad, or the cable is not in right. Often unplugging and replugging the keyboard into the MB will fix a missing row.
Jun 17, 2009 | Dell Inspiron 1720 Notebook
S510 Keyboard Problem, Keys Dont Work, Everything Else Works,Ect-Mute
I had the same the problem. The cause was a corrupted encryption code. That is why only worked the keys that don't require encryption.
1) Install the Logitech software and restart.
2) The software will tell you to press CTRL-ALT-F12. This procedure resets the keyboard encryption and tells you to enter a new code.
3) If you already had the software installed simply press CTRL-ALT-F12 and follow the above procedure.
Mar 15, 2008 | Logitech Cordless Desktop S 510
Lenovo G560 067999U Notebook Logo
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
