Question about Refrigerators
How do I access the evaporator coil on GE refrigerator ZISW42DYA
  • 74 Answers
SOURCE: side by side GE refrigerator psf26pgta
The fan should be a standard 12v DC computer style fan , test that you are getting voltage to the fan connector . You should also be able to get the fan to run by connecting it to a suitable supply . Once you have eliminated the possibility of fan failure then it gets more involved.
Posted on Aug 28, 2008
tech master
  • 120 Answers
SOURCE: GE frost-free refrigerator
well you need to know when it was manufacture if it lands under the 5 years seal system warranty then it can be fix for free. on the other hand be sure that compressor is running because if it is not it could be a relay and that is a cheap fix
Posted on Oct 17, 2008
Sea Breeze
  • 4654 Answers
SOURCE: evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Posted on Aug 05, 2009
aasc
  • 1606 Answers
SOURCE: I have a GE side-by-side model GSS20IEMBWW.Freezer
Do you hear the freezer fan working when you push in the light switch manually ? If not , then probably bad main control board (99% chance ) Pt # WR55X10656 . If you do hear the fan , then probably (90% chance ) the defrost heater is bad . Pt # WR51X10101 .
Posted on Aug 07, 2009
woodchuck789
  • 4059 Answers
SOURCE: GE Monogram Built-in refrig has blocked evaporator drain.
You should be able to see the drain under the coil. Part 804 on this diagram. Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing.
Posted on Aug 26, 2009
How do I access the evaporator fan in a GE apartment-size refrigerator model GTS12BBMARWW?
are u sure its where u say it is and not along the back side of the wall?
Feb 10, 2015 | GE Refrigerators
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
Where is the evaporator fan located in a ge gss22sgrf
In front of the evaporator coil in the freezer compartment, behind the fan guard. you must remove the rear freezer panel to access it.
Mar 30, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Kmonogram built in refrigerator, where is the evaporator coil and how to vacuum it.
Finding the evaporator will take disassembly of parts of the cover on the top of refrigerator. If you have other questions please let me know. Just be really careful to not damage the evaporator and unplug before working on your Monogram you need to find the evaporator coil to repair, replace parts or work in that area it is on top of the ZISS480NRSS and listed as part location #800 in the photo below. Click below to enlarge,
ZISS480NRSS Parts ZISS480NRSS Service Manual
Thanks, Sea Breeze
Aug 06, 2012 | GE Monogram ZISS480NRSS 48" Built-In...
Freon leak in housing? Can it be fixed
replacing leaking evaporator coil in this video on GE side by side
Jul 22, 2012 | GE FUF17SVRWW Upright Freezer
Refrigerator is only going down to 50.2 degrees and there is frost on back wall of freezer.
the frost on the back wall of the freezer is a usuall indication that there is a problem with the defrost circuit,defrost heater,thermastat, or the defrost timer.you can use a blow dryer and defrost the evaporator coil.remove the rear panel in the freezer to gain access to the evaporator coil.you also need to make sure that the evaprorator fan is functioning properly.
Nov 14, 2010 | GE Refrigerators
How do I get to the defrost heater to replace it on the ge profile performance side by side TIX30PBDB
Good day,
You can access the heater by removing the rear panel in the freezer compartment.
It is located at the bottom of the evaporator coil. It is mounted with a bracket, and comes out as an assembly.
Nov 06, 2009 | GE GSS25JFM Side by Side Refrigerator
Top of freezer is fine but the bottom isn't as
Sounds like your evaporator fan is not doing its job. The purpose of this fan is to move cold air from the evaporator coil (behind the lining of the unit) to the rest of the freezer and to the refrigerator.
The fan should be behind an access plate at the top of the freezer compartment. If it is running, you should be able to hear it. If you don't hear it, open the access plate and look at it. If the fan is not turning, you will need to replace the fan motor.
Oct 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Aug 25, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
