Question about Marshall Amplifiers Marshall Headphones Major New Version with Mic
Headphone jack bent
Right side not working
  • Marshall Amp... Master
  • 5,484 Answers
I recently bought Ear Pollution over the head headphones and they just stopped working for no reason
It sounds like you have a break in the wires. They make the wires stranded and they are finer than hair but will break if bent back and forth enough or if pulled on hard enough
Nov 21, 2013 | EAR POLLUTION EarPollution CS40...
Only one side of my earphones works I would really like to know what is the problem and how to fix it I also have warranty
Always good to have a warranty. Usually one side will not work because the wires get grounded out or become disconnected internally due to the cord being bent near the headphone jack.
Apr 16, 2013 | Audio Players & Recorders
Korg triton extreme synth. L/r outputs work fine by themselves put plug in both right side cuts out using headphone jack instead if you pull the right slightly out of input you get both sides working
I need more info to correctly troubleshoot this. However my best guess from what your telling me is that its either the Audio jack on the Korg or the headphones. If everything else is working properly replace the headphones and the Audio outputs. Post again with more details if that does not work
Jan 05, 2013 | Music
I got a spring problem, How do I get it back into the connector so it stays right there by the jack?
This is what I did after I couldn't find an answer online. Took the fat end, and kind of like a key chain ring, bent the last tiny bit where the spring ends. Then took this bent bit and then like a screw lead that into the jack end. From there just go in a circle and push the next bit of the spring into the jack end in a circle until all of the thicker spring part is back up and under the lip of the jack.
Feb 06, 2011 | Audio Technica ATH-M50 Professional...
Only the right earbud works no matter what headphones i use i even bought a brand new pair and it didnt work.
sounds like your headphone jack has gone bad or has a bent pin you can look into it and see if you can fix it or you can try and replace the headphone jack yourself if you have some good sodering skills
Sep 29, 2009 | Creative Labs Muvo V100 MP3 Player
When i put my headphones into the mp3 the left side does not work
THE HEADPHONE JACK INSIDE YOUR PLAYER IS BENT AND NEEDS TO BE SENT OUT TO FIX! IF NO WARRENTY BUY A NEW ONE ,IT WILL COST AS MUCH TO FIX!
Dec 01, 2008 | Insignia Sport MP3 Player
Ipod head phone jack no good
I agree with Solution 5. The copper pins in the jack that make the connection to your headphone plug are bent in such a way that they are springy and will make a good tight connection to the plug. When those copper connections get worn, they are not so springy and they bend inward causing you to lose audio on one side of your headphones unless you wiggle the plug and find that sweet spot that makes a connection. Then you have to hold the wire to keep pressure on it... it gets annoying.
You can open the case and there are slots in the headphone jack that you can get a hook scribe (like the dentists use) or safety pin to bent those copper connections back out. Don't bend them too far or they will break. You can also pick get a new part for $25 or a used part much cheaper. Once you iPod is open, it's a matter of a couple screws and a ribbon cable to replace the jack. Problem solved!
Feb 08, 2008 | Apple iPod MA446LL/A MP3 Player
Sound wont work right /not much at all
Headphone connector is usually designed to pass audio to speakers when the headphones are disconnected. A corroded or bent connector will lose audio. Does the headphone audio level seem ok? Try inserting and removing the headphone jack several times to clean the connector.
Nov 30, 2007 | Protron PD-800 DVD Player
Audio only plays from left headphone
The contacts inside the headphone jack are made of a springy metal there is one for the left and one for the right speakers. This happened to my Blackberry and I took it apart and got inside the jack block and re-sprung the contacts. It worked for me... I used a dental pick.
Nov 09, 2007 | Kingston Kpex100 Digital Media Player
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Marshall Amplifiers Marshall Headphones Major New Version with Mic Logo
46 people viewed this question
Top Marshall Amplifiers Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marshall Amplifiers Audio Player and Recorder Expert? Answer questions, earn points and help others
