Question about 1999 Jeep Grand Cherokee Clock Spring
How to change clock spring on 1999 jeep grand cherokee
    New Friend:
  • 24 Answers
Disconnect battery, remove horn/airbag, lock the clock spring, remove wheel, unbolt clock spring & connectors... reverse order to install.
Posted on Jul 25, 2013
My horn blows when i make left turns. what is going on
The horn pad or the clock spring in the steering column is shorting to ground. The clock spring is the device that allows contacts in the steering wheel to move in circles.
Sep 20, 2012 | 1999 Jeep Grand Cherokee
I need to replace the clock spring, how do i do this? 1999 grand cherokee laredo
The steering wheel has to be removed to do that. Removing the steering wheel requires removing the airbag, which leads to a whole other can of worms. If you've never worked on the airbag system or don't know how to, best to leave it to someone who does or you may end up with a huge repair bill, if you accidentally deploy the airbags.
Feb 02, 2011 | 1999 Jeep Grand Cherokee
Have 99 grand cherokee & the horn isn't working & the airbag light is on what could be the problem?
The clock spring behind the sterring wheel is bad. This is the thing that allow all the electrical stuff in your sterring wheel to be able to work while you are turning the wheel. Sometimes this is recalled because of safety issues with the air bag. Check with local jeep dealer for recalls. 4 thumbs up is appreciated if this helps.
Dec 05, 2010 | 1999 Jeep Grand Cherokee
OBD11tech thinks I have a bad clock spring on my 1999 jeep cherokee classic due to my horn not working & the air bag light stays on. Where is the clock spring & how do I change it?
it's inside the steering wheel
must be careful, because of the air bag.
disconnect the battery and wait for 10 minutes for the air bag capacitor to discharge power.
remove the air bag module from the steering wheel
remove the center nut, then steering wheel
the clock pring is a yellow round piece that fitted inside the steering column. there is a snap ring hold the clock spring in place. disconnect the wiring then remove the clock spring.
Feb 28, 2010 | 1999 Jeep Grand Cherokee
1999 Jeep Grand Cherokee...how do I reset the darn clock?
hi
on the dash clocks you have a reset button comming from the speedometer, it you turn this left and right that sets the hrs,mins.
hope this helps
Nov 05, 2009 | 1999 Jeep Grand Cherokee
My 1999 jeep grand cherokee airbag light and alert keeps going off. How do I fix it?
It's possible the clock spring in the steering column is bad. That would have to be looked at and repaired by a qualified mechanic.
Jun 17, 2009 | 1998 Jeep Cherokee
Air bag light keeps coming on my 1999 jeep grand cherokee
Jeeps did have a problem with the clock spring in the steering column. This clock spring is a part that connects the lower harness with the switches on the steering wheel. To replace the clock spring it will have to be done by a qualified tech since the airbag itself has to be removed. Have the car checked for codes first before making any repairs.
Mar 05, 2009 | 1999 Jeep Grand Cherokee
1999 jeep grand cherkoee-air bag light on then chimes
Check the rotating contact (also known as the clock spring) under the steering wheel, this is the weak link in all airbag systems.
Oct 01, 2008 | 1999 Jeep Cherokee
1999 Jeep Grand Cherokee Clock Spring Logo
114 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Tom
Mike Stager
Mike Stager
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
