Question about Zenith MBR3447 Remote Control
Manual how do I find the 3 digit code?
    Top Expert:
  • Zenith Master
  • 12,223 Answers
Go to www.remotecodelist.com + memorex.com and download
God bless you
Posted on Jul 15, 2013
What is the code for viore
try 002 if that dont work CODE RETRIEVAL:
This feature can help you to find out what the 3 digit code that is currently stored in your
"Innovage Jumbo Universal Remote" for a specific device without having to reference the
code list manual.
1. Press and hold down the CODE SEARCH button •for at least 3 seconds until the red LED
lights up solid red.
2. Press the device button , e.g. TV, DVD, VCR, etc. and the LED light will blink once and
then remain solid red.
3. Press each of the number buttons 0-9 until the LED blinks once. This will signify the
1st number in the 3-digit code for the device that is programmed in your remote control.
4. Repeat same process to find the 2nd and 3rd digit for the 3-digit code.
5. Once you have found the 3rd digit the LED will turn off
i found the manual for remote at http://files.remotecentral.com/download/363/jumbo-manual.zip.html
Jan 13, 2013 | Innovage Jumbo Remote Control
Need remote code for symphonic
Without knowing the model number I can not find the right code but these two manuals will give you the codes.
4 digit codes - http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf 3 digit codes - http://www.jascoproducts.com/support/download-files/RemoteCode-3-Digit.pdf
May 07, 2011 | GE JASRM24912 Remote Control
I need codes for GE universal remote 24993 for Orion TVs
Try these out: 035, 121, 135, 191 If it is a 4 digit coded unit: 0121, 0135, 0035 Hope this helps.
Mar 02, 2011 | GE 24993 Remote Control
We can not locate our owners manual and would like to obtain the code number to enter when we call our home phone to obtain messages when out of town. (the model # is 82209)
Hi there, I hope this helps you.  I located the manual for the 1717.  It states that the remote access code is factory set at 123.  You can review the remote access code by pressing and releaseing setup.
You can change the Remote Access Code
to any three digit number from 100 to 999.
1 Press and hold S. After the Ring
Select setting is announced, continue
to press and release S until the
system announces the current Remote
Access Code.
2 Press and release or
until the system announces the first
digit you want.
3 Press and release S to select the
announced digit.
4 Repeat Steps 2 and 3 for the second
and third digits of the code.
5 Press P to exit
You can get a copy of the 1717 manual at this web site:  http://www.retrevo.com/samples/AT%26T-page-2-manuals.html
I hope all this helps you.  Good luck.   Barb
Feb 23, 2011 | AT&T 1717 Digital Answering Machine
How to program radioshack 3 in one remote to a panasonic dvd home theater sound system sa-dm3?
hi,
try any one of the following code. if not work do the following steps to find out code.021, 107, 035, 081, 110, 162,225, 454,035, 162,051, 054, 055, 250
MANUAL CODE SEARCH
If the 3-in-One Easy Remote Control does not op-erate your remote-controlled devices when you
first set it up, you might have to manually find the correct code for your devices. you can
follow these steps to search the remote control's entire library.
1. Manually turn on the device you want to set
up.
2. Press the corresponding device key (TV,
VCR, or CBL).
3. Hold down P until the red light blinks twice,
then press 9, 9, and 1. The red light blinks
twice again.
4. Aim the remote control at the device you
want to operate.
5. Repeatedly press PWR then the device key
for the device until it responds to the command.
6. When the device responds to the command,
press P within 5 seconds to save the code.
Note: If you do not press P within 5 seconds,
the remote control does not save the code.
• Because the remote control's library has
so many codes, this procedure can take
several minutes.
• If your device turns off during the search,
but does not operate after you lock in the
code, begin the search again, pausing
longer between key presses.
Determining the 3-Digit Code
After you set up your remote control using manual code search, you can find which 3-digit code the
remote control is set to by following these steps.
1. Press the device key you want to get the
manufacturer's code from, then hold down P
until the red light blinks twice.
2. Press 9 9 0 . The red light blinks twice again.
3. Press 1 then count the number of times the
red light blinks. This is the first digit of the 3-
digit code.
Note: If the red light does not blink, the digit
is a 0.
4. Repeat Step 3 twice to find the second and
third numbers of your 3-digit manufacturer's
code, pressing 2 and 3 respectively for each
additional digit.
ok
Dec 14, 2010 | Panasonic Televison & Video
I have a Vizio TV and just bought a InVoca 3 voice activated remote control. I did not see any manufacturers codes for my Vizio that I have to enter into my InVoca 3. Can I use my Invoca 3 with my...
For the InVoca 3.0 I used a Goldstar TV code for a Vizio TV.I'm not sure what the 3 digit code was but you can search Goldstar codes on theremote shown in the manual with a 2 digit code 33. You also can train it fromyou remote but I did not try that method. They might have different manualsbecause my manual has more instructions than the online version one.
Aug 17, 2010 | KNG America InVoca 3.0 Remote Control
Owners manual for casio phonemate TA140. Info on remote access
I have a casio/phonemate TA 140 answering machine but no owners/user manual. Where can I download a copy?
Oct 21, 2009 | Casio Lands Phones
Goldstar tv code for magnavox remote
Depending on the age of your magnavox remote, it may require a 3 digit or 4 digit code. Check the manual of your magnavox remote and see if it requires 3 or 4 digit codes. Once you know what type of codes the remote requires, use the 3 or 4 digit code banks below. Start with the first code in each listing and continue down the list until you find one that works.
Here is a listing of 3 digit codes for GoldStar TVs:
GOLDSTAR: 002 - 102 - 117 - 207 - 217 - 307 - 502 - 818 - 914
Here is a listing of 4 digit codes for Goldstar TVs:
GOLDSTAR: 0019 - 0030 - 0032 - 0056 - 0178
Aug 06, 2009 | Televison & Video
Remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Nov 22, 2008 | Akai LCT3215/26 32 in. LCD Television
ILO DVDRO4
So the game is asking for the code?
Jul 04, 2008 | iLO 2600 Television
Zenith MBR3447 Remote Control Logo
29 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
