Question about Motorola Mobility RAZR V3i Cellular Phone
Text caption over picture, need to remove
A text caption was accidentally saved over the picture and need to remove the text. I used the add text function and edit text function and it didn't clear the text from the picture. How can the text be deleted after it's been saved?
    Problem Solver:
  • 9 Answers
You will have to bring up the picture and edit it to take the text off.
Posted on Sep 02, 2007
How to turn off CC to get rid of that black box
Here's the link to the manual. CC instructions are on page 22.
http://books.jvc.com/Download/77833385/LCT0604-001B-A.pdf
Closed Caption
Use this function to display the Closed Captioning
text onscreen (when included in a bro a d c a s t ) .
P ress the ME N U b u t t o n
To CLOSED CAPTION
To operate
To select Caption, Text, or Off.
To CAPTION or TEXT
To select a caption or text channel
To FINISH
To save setting and exit
Dec 31, 2012 | JVC AV-20120 TV
TV picture has black square that covers 95% of the screen
some one has accidentally touch the text closed caption on the remote button. press the close caption button on the remote until it goes off.good luck.
Sep 23, 2011 | Televison & Video
Square Black marquis takes up the screen seconds after channel changes. Can't make it go away.
Check your closed-caption settings. You will probably find the TV is set for "text" mode right now. There's usually a single button (may be marked "CC" or "Caption") on the remote control to choose the setting. It's easy to bump the button accidentally and set captions without realizing it. When set for text, the TV blacks out the area where the text would go if there was any. Turning captions to "off" will clear up the mystery.
Oct 28, 2010 | JVC AV-27530 27" TV
Black box on top of picture
This sounds like the text function is turned on in the closed captioning part of the menu. If the remote has a separate captioning button press that until captioning and text are off. Otherwise the caption/text settings are in the customer menu. Go into the menu to the captioning options & shut captioning/text off and see if this corrects your problem.
Nov 09, 2009 | JVC AV-27D201 27" TV
Cannot get closed caption
To view captions or text:
1. Select the desired program. Closed captioned programs are
usually marked in your local TV listing as “CC.”
2. Press CAP/TEXT on the remote repeatedly to select caption or text mode.
3. Press 1/2 on remote to select the caption or text channel.
4. To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen. I hope this helps. Thanks for using Fixya. Good luck
Nov 04, 2009 | Toshiba 20AF45 20" TV
I have a black filter over my picture which does not let me see my picture clearly.
You may have closed-captioning turned on and set for "text" mode. Check your settings and be sure it's turned off. Many remote controls have a single button to control captioning and it's easy to set text mode without knowing it. Then the set puts up an area for text to be displayed, but there isn't anything to put there. On channels where captions aren't being used you don't see any problems, but on others you'll see the box on the screen.
Jun 16, 2009 | Televison & Video
80% of the picture is black
Ok, if the video is present around the outside of the black box you have a problem with close captioning. It is stuck in either Text 3 or Text 4 mode. The options for close captioning are CC1, CC2, Text 1, Text 2, Text 3 and Text 4 and of course OFF. Apparently the close captioning is stuck on or is not being properly shut off. Better read the owners manual to see if you are missing a step when turning off close caption.
May 27, 2009 | JVC Televison & Video
No captions sanyo projection tv
By captions you mean subtitles - this constraint is a feature of your TV and not the projector, If however you mean the menu text for the projector then you sometimes have to select s-vid or composite as the menu text (and the volume level) doesn't appear when you are using Component.
Jan 20, 2009 | Sanyo PLV-Z4 Multimedia Projectors
Edit Text on a picture after Adding it
no, text in an image is not saved as text, it is encoded to each pixel that it overwrites.
do not add text in camera, save the images to a hard disk and use a simple image editor, like irfanview http://www.irfanview.com, to do the text overlays, it has undo, you can use irfanview to pixel edit the text set image
May 16, 2008 | Olympus FE-230 Digital Camera
Black squares or rectangles over picture
It's the closed captioning. The reason it doesn't go away when you press the "caption" button is because there are four option for closed captioning: Text 1, Text 2, Text 3, and Text 4. The fifth option, which has no designation, is the "off" option. Using the remote, just click on the "caption button until the option has no designation.
Mine was a large black rectangle in the middle of the picture. It's not like Nina3's problem.
Feb 01, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Motorola Mobility RAZR V3i Cellular Phone Logo
169 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
