Question about Sony Hvr-M15U Compact Desktop Hdv/Dvcam/Dv Vtr
FCP Firewire output through Sony Hvr-M15U Compact Desktop Hdv/Dvcam/Dv Vtr
I am trying to output FCP video through firewire connection to Sony Hvr-M15U. On the monitor connected to the Sony Hvr-M15U the video image is frozen while the audio plays normally. Can't figure out why the video freezes while audio plays. My output settings in the View menu are as follows: External Video - All Frames; Video Playback - Apple Firewire NTSC (720x480); Audio Playback - Audio follows Video. Any thoughts would be welcome. Thank you.
    New Friend:
Give your jump
Posted on Jul 15, 2013
2 Suggested Answers
  • 239 Answers
SOURCE: Sony DSR-30 not Processing DV video from tape or DV in.
try a different cable
Posted on Sep 06, 2012
Firewire port
U have to select input switchto DV
Jul 18, 2013 | Sony HVR-1500 HDV VCR
I can't initialize on FCP
If you are capturing HD, go into the menu > IN/OUT REC > i.LINK CONV and set it to off, and A/V->DV OUT to off. Go into FCP and go to the File Menu and select "easy setup". In the easy setup menu set the "Format" to "HDV" and set "Use" to HDV - 1080i60. Click "Setup". Now go to File > Log and Capture (command-8). You're now set to capture. Just queue your tape and hit "Capture Now" or set in and out points and capture "Clip".
If you want to capture SD footage, then on your Sony unit, go to the menu and set the i.LINK CONV to "on". In the easy setup menu you will want to set "Format" to "NTSC" and "Use" to DV-NTSC".
Sep 26, 2008 | Sony GV-HD700 HDV VCR
How do i upload my video from my sony dsr 150?
you can connect your fcp with camera through firewire/dv.
Jul 27, 2011 | Sony Dvcam DSR-PD150 DV Digital Camcorder
I have tried to connect my Canon XM2 to my IMac via firewire, but it is not 'seen' by IMovie, FCE or FCP, so I can't capture anything. Thanks
Open the System Profiler on the Mac and establish if the camera is connected to the Mac's firewire BUS. If not, try another cable and also test is the camera's firewire port is working. It's either a cable or socket issue. Some cameras require that the menu of the camera be set to output over firewire, check this as well.
May 05, 2011 | Canon DM-XM2 Mini DV Digital Camcorder
I am trying to digitize HDV footage using fcp 6.0.6 on an Intel imac with 2gb ram. Trying desperately to get my computer to recognize the Vixia HV 30 camera, but it will not. I have tried changing...
First, confirm what type of video is being output from the camera as HDV cameras can also ouput DV or can Downconvert HDV footage form the camera to DV even if the settings for recording were HDV.
The message is to double check and understand the menu settings within the camera.
Once done FCP will require an Easy Setup that matches the camera output.
If you shot and are indeed outputting HDV, start off with Easy Setup>HDV-Apple Intermediate Codec1080i60, assuming you a an NTSC user.
Mar 18, 2011 | Canon VIXIA HV30 DV Camcorder
Please help me...When I connect my canon xh a1 to FCP 6.0 it says Unable to Initialize Capture Device Device is not connected or the capture preset is not setup correctly. You may still log offline...
Try playing the tape before connecting up to the mac with the firewire and before loading FCP up. Usually fixes it for me when using either iMovie to import or FCP
Jul 16, 2009 | Canon XH A1 Mini DV Digital Camcorder
Playback problem DSR 11
if you plug & unplug cable after turning off ,perhaps you can the conector firewire on the vcr inside there are 4 yellow cables if not the conector defect.try to push the cable firewire litle up down side just to make sure
Apr 29, 2009 | Sony DSR-11 DV / Mini DV VCR
Dvcam dsr 45 firewire problem
if you can use your computer and cable firewire for other device. it means that your ic firewire in your dsr 45 is defect/broken,if you want to capture without firewire dsr45 , you need video and aodio in card for your computer.note ic firewire easy to defect/ broken if you plug/ uplug it when the device and the cumputer are on.
Aug 26, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Hvr-M15U Compact Desktop Hdv/Dvcam/Dv Vtr Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
