What eroor8 in weat point washing machine - Washing Machines
    Problem Solver:
  • 14 Answers
Error 8 Washing machine has detected an
overfill situation This error code can be caused by
overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as
the pressure sensor will falsely read
that there is too much water in the
washing machine. Also check the pressure sensor and
that the machine has not actually
overfilled with water. Check for overfoaming or over
soaping Check the air chamber and the
pressure switch hose Check water level sensor Check wiring to water pressure
sensor Check connections to water level
sensor Check main electronic controller
Posted on Jul 14, 2013
How do you get it to wash
plug power cord into power point and turn on power point
turn dial round to cycle
then make sure door is closed
A model number and make of washing machine would enable a more specific answer
Aug 15, 2016 | Washing Machines
Danlowd watsap weating
Www.whats app.com/download/nokias
Aug 26, 2013 | WhatsApp Messenger
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
My game got weat
put it in rice, however you may experience a problem where it says it cant keep track of time. there is no way around this
Jun 09, 2011 | Nintendo Pokemon Ruby for Game Boy Advance
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
How do you get the mildew smell out of a clothes dryer?
Very unusual problem with a dryer as it gets hot and would normally evaporate moisture causing mildew!
Try the following:
  • Unplug the power point of the dryer.
  • Gently clean the interior (and exterior) with a super absorbent cloth/non-scracth sponge lighty soaked in a mild bleach soapy mixture to kill off and remove the (blackish) mildew (Nappy wash is not a bad mixture). Weat rubber gloves for protection.
  • Let the unit wet for a few minutes and then using clean warm water and sponge, remove all trace of the bleachy soap on the unit as it is corrosive. Additional drying off with disposable paper towel will help remove any trace of bleach.
  • Put a wet clean bathroom towel lightly soaking with material conditioner mixture at double the normal recommended ratio, power the dryer and dry off the towel as per normal: the fabric conditioner is also a freshner.
  • Musty milldew odour should be gone!
Hope it helps! Please let me know how you go!
Aug 05, 2010 | Hotpoint Dryers
Indeset w101 washing machine programer, we set the
Depending on the model you may have a reset point on the selector switch dial.
This is usually indicated by 2 or 3 black dots on the dial.
If it has , then switch the m/c off, set the dial to one of these points, switch on and wait until light fashes, switch off, and reselect your programme.
It should now work normally.
If it does not, then there is probably a control board fault.
If there is no reset point, then again it is likely to be a control board fault.
Please rate my solution.
Thankyou.
Jan 15, 2010 | Washing Machines
Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units.
Christina Weate
Jun 11, 2009 | Televison & Video
Washing machine
Check pump fiter and pump.
Jul 22, 2008 | Zanussi ZJ1217 Front Load Washer
Ac odor
clean the ac with coil cleaner make sure to wash it off with water very good .
Jun 24, 2008 | Comfort-Aire RAD-81 Air Conditioner
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
