Question about Cycling
Apollo bike I have adjusted the seat height as my daughter has not ridden her FS26 bike for years. Could you please explain how the handlebars are adjusted?
  • 73 Answers
By the bolt in the center (loosen it, then tap it, to free it up) that will allow them to go up or down. To change the angle of the bars the handle bar stem has 1 or 2 bolts facing the front wheel...loosen them and go where you need to go.then retighten them... happy Cycling.
em has 1 or 2 bolts
Posted on Jul 15, 2013
  • 74 Answers
SOURCE: diamondback rm 20 kids bike. Can you adjust the handlebars?
Yes, there is an allen screw on the top of the stem of the handle bars.....it may also be a bolt with a head on it that can be turned with a socket or cresent wrench.
Loosen the bolt 3 or 4 complete revolutions and then wiggle the bars back and forth from side to side while pulling up. Be careful not to completely remove the screw as the piece that it is connected to will fall off and you will have to remove the bars completely to fix.
Posted on May 03, 2009
  • 193 Answers
SOURCE: 20'' Mongoose BMX - How can i adjust handlebar height?
You need to unscrew the circular nut like thing on the stem all the way off and pull up hard on the bars and it should come up, try spraying some lucricant on the stem to loosen it if needed.
Posted on Jun 20, 2009
dunnbiker
  • 8546 Answers
SOURCE: Can the handlebar height be
The stem could be flipped over if the rise change would result in a hgiehr handlebar, but it would be minimal. That style of stem requires the steerer tube to be cut at the time of assembly and spacers are usually installed that would allow lowering the bars but not raising them since steerer tube length can't be increased.
Or, get a stem with a steeper rise.
Posted on Aug 22, 2010
  • 71 Answers
SOURCE: i have a mongoose rockadile
i have never fixed this bike but normally there is an allen wrench bolt right on top of the shaft you have to loosen it (not take it out there is a tightening nut at the other end of the that you want to stay on) then after it is lose you should be able to adjust it but if not you will have to loosen or take of the first bolt down the shaft and that should make it able to be adjusted i hope this helps
SabiousOne
Posted on Nov 09, 2010
dunnbiker
  • 8546 Answers
SOURCE: How do I adjust the height of the handlebars on a
http://www.sheldonbrown.com/handsup.html
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
A reputable Bicycle Shop would have fit the bike to you before you took it home.
Posted on Aug 14, 2011
Can the handlebar be raised on a 2015 giant anthem 1
The seat should typically be at a point such that your knee has a slight bend at the bottom of the pedal stroke. The handlebars go wherever they are most comfortable for you. Reach (horizontal distance) is adjusted with a different stem. Height on your bike can only be increased by using a stem raiser. The following Google search will show you what is available, and the video results will show the procedure to install it.
Sep 12, 2016 | Giant Anthem 1
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
What are the safety precautions I should consider when buying a balance bike?
  1. Seat height.
  2. Size.
  3. Tires.
  4. Weight.
  5. Brakes.
  6. Turning limiters.
  7. Footrests.
  8. Frame materials.
  9. Grips.
Jul 18, 2016 | Strider ST-3 No Pedal Balance Bike Cobra
Lower seat height
More info required ... what bike? Pedal bike? loosen the bolt on the tube under the seat and adjust the seat stem downward until it will go no more. If it is already in the lowest position, you will have to wait for your daughter to grow a little.
Jun 06, 2013 | Motorcycles
How to adjust the handlebars on a bike
To adjust the handlebar position on your Raleigh, loosen the nut on the bottom of the stem extension. Use a 13mm or 14mm wrench, whichever fits. Do not use pliers or Vicegrips! It is upside down, so be careful to turn it counter-clockwise while looking at it from the bottom. To change the handlebar height, you need to loosen the bolt on top of the vertical part of the stem. You may need to tap it with a small hammer to break it loose after it is loosened about 1/4 inch. Now you can adjust the handlebar height, being careful not to exceed the maximum height engraved on the stem. You should also carefully align the bars with the front wheel before tightening the bolt. If you do not understand the terms used here, you should take the bike to a bicycle repair shop.
Feb 26, 2013 | Raleigh Krush 16 Girls Bike 2012 - bikes
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
Handlebar adjustment
Threadless stems limit what you can do with height.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Jul 09, 2011 | Apollo Evolution XC
How do you adjust the seat
Hi there Vriddick
To adjust the seat for height, there is a locking bolt on the seat post, below the seat. Loosen this and the seat should drop down the hole. Lift it up to your specified height and tighten up the bolt. You can also use this method to adjust the direction of the seat in relation to the handlebars, left or right.
If you need the seat adjusted for its angle. Under the seat itself are two bolts clamping two large circular bits of metal, undo these bolts and tilt the seat downwards or upwards, retighten when you have it just right.
Jun 20, 2010 | Schwinn Scwhinn 26 Inch Womens Coronado...
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Cycling Logo
56 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
