Question about Kenmore Heating & Cooling
Deminsions for Kenmore ac heat unit model 580-75184700
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: need deminsions to purchase new oven
every oven has different dimensions, the easiest and best thing to do, is to slightly pull unit from the cabinet its installed in and measure the max. opening both height and width.--- if its a freestanding range that you are talkin about the dimensions are standard inches,, 20-24-30-36.
Posted on Dec 15, 2008
Why does the heat strip in my kenmore heat/cool window unit, heats all the time, you can see the red glow through the condenser. I would be happy if I could just unplug the strip and use ac
It's probably controlled by a small switching relay or a control/circuit board with a switch/relay, that has stuck closed or been fused together.
Mar 21, 2017 | Kenmore Heating & Cooling
Can a pro recommend a comperable replacement wall AC only-no heat?
Most air conditioners now are reverse cycle, which means that they can heat as well as cool. Cooling only units were popular many years ago due to the price difference for a reverse cycle. Today, the cost of manufacturing has dropped and it has resulted in cooling only units being virtually finished. I would suggest you get a local air con sales company to come to your house to measure up properly and determine what would be best. There are a lot of factors in installing air conditioning. IE/ The size of the house, the area it will be required to heat / cool, the amount of windows, types of walls, roof etc (Heat loading on the house) Roof and wall insulation etc etc.
Apr 09, 2014 | Heating & Cooling
Ve a kenmore ac heat combo model # 58075184500 that the cord was pulled away from the outlet and melted both just slightly. I replaced the wall outlet but the unit seems to have low voltage to it. the fan...
Before doing anything elese I would replace that cord also... it may have damaged to cord too...
Make sure to get a heavy enough replacement cord so it does not burn up again...
heatman101
Dec 13, 2010 | Kenmore Room Air Conditioner
What are the deminsions of dryer venting through the bottom. Model # 87872??
check with kenmore,check handbook,check plateeitheron back or inside the door.call lowes. karl
Oct 28, 2009 | Kenmore Dryers
Kenmore 110 ac model 25370156000
sounds like 1 of 2 problems. first, check the condensor coil for dust, dirt, lint on the inside of the unit. this is the coil thats on the back of the unit that is outside. it can be sprayed out with a garden hose. make sure the unit is unplugged and let it drain for a hour or so. if the coil is not dirty, then the unit has developed a freon leak and needs to be serviced.
Jun 03, 2009 | Kenmore 76129 Air Conditioner
Need deminsions to purchase new oven
Dec 15, 2008 | Ovens
Reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Nov 07, 2007 | Kenmore 71121 Air Conditioner
Heating & Cooling Logo
42 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
