Ge wcvh6800jmr will not complete any cycle. door unlocks and goes to pause.
  • 236 Answers
SOURCE: Don't properly spin out clothed leaves them soakng wet-Now it just keeps pausing and locking door and unlocking door without washing
sounds like there is a pumping/blockage problem. check the filter and all drain hoses/outlets. if all clear the pump may be faulty. is the drum turning at all?
Posted on Feb 16, 2008
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
appldoctom
  • 311 Answers
SOURCE: GE Front Load Washer WSXH208HIWW Door Won't unlock
more info/unplug reset wait 5 min
Posted on Dec 31, 2008
SOURCE: GE WBVH6240FWW pause/drain problem
I had the same problem for months. Load would pause all the time and items would be soaked. Today it wouldn't do anything and I found out that it was a drainage problem. I called the warranty department and they scheduled a service but warned me that if the problem was caused by debris in the sytem, I would be charged for it. So, I took the job on and finished with like new results after about 4 hours of work. First the pump filter was nasty(batteries, coins, a wrench, hair,etc.), so I emptied and rinsed. Unplug machine. Take off lower front panel (3 screws) and the turn the pump cleanout knob counterclockwise about 2 turns. Have something ready to catch water. Put back in and test machine. If that doesn't work, you will have to clean your pump. Repeat the same drainage process with pump cleanout knob, take hoses off from pump (to the right side of pump cleanout tube), disconnect wiring, remove both screws holding the cleanout tube and pump to the frame and remove assembly out of washer. Remove the 3 screws on the back of pump. Take a flat screwdriver and pry the impeller from the body of the pump(pry carefully because you don't want to mess up the o-ring). Once you have the impeller out, clean impeller and inside of pump casing.(Don't get the electical portion wet!). Put everything back together and test. That is everything I had to do. It sounds hard but it really isn't. Remember to disconnect power from the machine before working on it. You don't want water from the pump cleanout spraying all over the place, the machine has an internal ground and you may become one if your not careful. Our machine is working awesome, my wife is not yelling no more, and I really hope this helps somebody out there. Good luck.
Posted on May 09, 2009
SOURCE: Our GE front load washer pauses during the wash
Clean the filter. It is probably clogged.
Posted on Aug 12, 2009
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
Unlocking your washer so it actually works.
If the green cycle light is flashing on then off, this usually means the cycle is paused. The lid lock should unlock when in pause mode, if not you will need to press and hold the "Pause/Play" button to clear the cycle completely, if there is water in the unit, it will drain first, then unlock the lid and be on standby to start a new cycle. Pleazer Appliance...
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
WASHER TROUBLESHOOTING
My GE front loader keeps stopping in the middle of the cycle. It does it over and over and never completes the cycle. It just started doing this a couple of days ago. It took me all day to do one load of laundry the other day. Tried again today with no luck. I tried it on three different cycles and all the same. It just keeps stopping and going to pause. When I shut it off it takes about 20 minutes for the door to unlock. Is this problem worth fixing or should I junk it?
Aug 07, 2010 | Frigidaire ATF6000ES Front Load Washer
My 4 year old front load GE washer won't go to the
is there water left in the lower area below the lower wash arm?if so maybe the bottom sump is blocked by food debris or the pump and or sump is blocked by food debris shutting the unit off earlier than the cycle says,find the tech sheet and run the diagnostics for the entire cycle,its normally in the lower area below the door in this panel on one of the side walls in an envelope
Jul 25, 2010 | GE Washing Machines
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Front Loader Washer - Not washing
It sound like a lid switch issue. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look that the switch is not broken or loose. If all is fine, you should replace the switch. Good luck!
Aug 27, 2007 | GE WBVH6240F Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
