Question about Health & Beauty
Redstreak M80 50 CC will not run
My Redstreak M80 50cc will only run for about 20 seconds before quitting. Please help.
My 50cc scooter won't go over 30mph
Hi, Bob and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. The accelerator pump is inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichener valve is not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper float level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Help Ruck won go above 30mph Thanks
Advice please 49cc won go over 20 mph
gy6 50cc to 100cc bbk upgrade still wont go over 30mph It Is The Ride
My scooter won reach top speed anymore scooters
SCOOTER WONT GO OVER 20MPH HELP
Mar 28, 2017 | GAS Motorcycles
Service manual a) Honda glx 50cc b) Honda supra 50 cc I wand service manual please help me
Try the Carl Salter website for a free Honda manual, he doesn't do all the models but you might be lucky http://www.carlsalter.com/honda-service-manuals.asp
May 30, 2015 | Honda Motorcycles
POULAN 50CC CHAINSAW
Try chainsawr.com
CHAINSAWR.COM ....don't forget the R at the end... caps or small, it doesn't matter.
Mar 10, 2015 | Poulan Pro PP5020AV 50 cc Gas Powered...
Installed 70cc cylinder ,having stock exhaust ,50 cc cylinder head Mixture is normal but engine overheats after riding a short distance
problem could very well be that stock exhaust system as it was designed for the 50cc cylinder and not a 70cc cylinder.
Jun 19, 2011 | 2009 Keeway Matrix 50
On a kazuma 50cc engine carb adj screw location
The lower of the 2 screws is the fuel/ air mixture- the upper screw is the idle adjust screw
Jan 22, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Got a kazuma 50cc quad have problem starting it when i finally get it going it wont take any throttle without cutting out.
i have i 50cc ATV quad and we have done every think to it and it still won't start but the fuel isn't going to the spark plug any one know what to do. ?
Jan 09, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
