Question about Yamaha 12V Air Pump
Gives speed when half trottle but no speed when full trottle
You have a low idle adjustment and a high in your carbs I would just try spraying carb clean wile running if not the rebuild carbs
Posted on Jul 21, 2013
Low rpm at idle but boggs when you step on gas pedal
Hi Alex possibly a dirty trottle body. Get a can of trottle body cteaner and start car. Then get someone to revv it up over half way and spray cleaner in bursts of 3-4 seconds into the trottle intake. Regards Jim...
May 20, 2015 | 1997 Toyota Camry
Engine does 'nt run on idle speed in a forklift truck
You may have to change the needles in the carb or a basic rebuild. also check your idle screw to see if it vibrated back to too low a setting
hope this helps
Nov 12, 2011 | Motorcycles
The motor does not respond on full trottle, half and up it just like chokes itself
You need to adjust the high speed mixture on the carburetor. When you say it 'chokes itself' you imply it is too rich.
Jun 29, 2011 | 2011 Derbi GP1 50
What is h and l screws for we have been moving them around to try make the saw tick over as it keep cutting out
"H" is high speed and "L" is low speed. Turn both screws in full, then unscrew them one and a half turns each. Start the saw, you may have to adjust the trottle screw to keep it running.Then adjust the "L" screw a little, in or out, with the trottle screw until you are happy with it ticking over. then adjust the "H" screw to get it to run full. You need time and patience. Stephen.
Sep 24, 2010 | Husqvarna Chain Saw 20" Bar
I have an echo srm2501. could you tell me the standard settings for the low speed trottle screw and the high speed screw
On these little carbs, a good starting point (before fine tuning the carb) is about One and one-half turns out (counterclockwise) from a lightly seated postition. That should allow the unit to start and you can fine tune from there.
Aug 21, 2010 | Garden
My speed is limited. I can't drive faster than 30 mph. It happened after winter. If durig drive I do a trottle from half to fullI, engine is suffocatatig and don't have full power. Is it the truth to clean...
It sounds like your fuel line is clogged. Check to see if there is a filter on the fuel line and change it if there is. If not, take off the petcock valve (under the tank) and clean it out. Good luck.
Apr 20, 2010 | 2000 Honda VT 125 Shadow
Why does mio not fully full trottle?
your problem is in the bikes brain it has a chip in side it that only allows it to go a certian amount of speed send it it to have it rebuilt but make sure battrey is unhooked when you go to remove brain
Nov 06, 2009 | 2008 Yamaha MT-01
My weed eater blower starts and i can run the engine at full
See if there's a plastic adjustment/tiny little unit with standard slot,try half turn.
Jul 18, 2009 | Poulan Garden
My craftsman 19.5 b&s engine has developed a Rabit jumping problem. becoming more difficult to control the speed with the clutch/brake. I also notice that the internal control when going downhill is...
I don't know if you have a hydrostatic or gear drive trans, but you should be able to go slower either by shifting to a lower gear or by moving the hydro drive lever to a slower speed. Always run the engine at full speed. Slowing the mower down by slowing the engine is extremely hard on the motor. It need the higher rpm's to keep it cool and not have to work as hard. There is a brake adjustment on the left rear axle. There is a brake disc with lever and a nut holding it on. Turn the nut clockwise about a half turn at a time to adjust the brake and check it. You don't want to get it too tight or it won't roll.
Jun 24, 2009 | Craftsman Garden
I have a 89 nissan 4x4
Have you checked the EGR valve yet? Or check your Fuel regulator or pump.
Feb 05, 2009 | 1989 Nissan Pathfinder
Yamaha 12V Air Pump Logo
95 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
