Question about HP Officejet Pro L7680 All-In-One Printer
69552 event log 109 69556 - HP Officejet Pro L7680 All-In-One Printer
3 Suggested Answers
SOURCE: HP Photosmart D7360 not seen by PC, despite driver, s/w loaded
Not a solution per se - just a diagnosis. I have decided that the USB out port on the printer is bad - and after wasting time just trying to crack the case, will just use this as a photo printer "offline." It prints beautifully directly from media inserted into any of its onboard slots. I will just have to save things as .jpgs or picture formats to print from this printer. HP didn't have the part available, anyway. I called and inquired.
Posted on Jan 28, 2009
  • 8 Answers
SOURCE: HP Officejet Pro L7580 ADF will not pick up paper
You can lift the top of the unit to inspect the rollers. Be careful because the L series the roller can pop off easily and if you're not paying attention to original orientation, can be a pain to put back in.. you press the blueish button to release the pick up assembly. See if any rollers are dusty. If they are, use Isopropyl alcohol (highest % you can find) and a LINT FREE cloth (dryer sheets/coffee filters or something of that nature..) and wipe clean
Hope this helps, I'm honestly doing all this from memory, I used to work for that dept here in Oregon ..
Posted on Sep 08, 2009
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
Feb 04, 2014 | Dell PowerEdge Computers & Internet
How do i read cbs.log
not sure what a cbs.log is
Click start type in cbs.log in search press ENTER it will take you the the log and anything associated with this cbs.log
or Click start type event viewer press ENTER you will see all events and event errors in red
Hope this helps.
Dec 27, 2012 | Western Digital My Book Essential Edition...
Sel full 1912 error
You will get the "Sel Full 1912 error" on your server when the system event log is full and unable to record further events. You must clear the event log before the error will cancel. Boot your system into the BIOS/CMOS, locate the system logs and select clear log, reboot your system. Once the system is back up, I would go into the admin task folder and make sure the logs are clear there as well.
Good Luck.
Please rate my solutions here on FixYa.com
Jan 01, 2012 | Dell PowerEdge 2950 (becwfk1_6) Server
C2A2: system event log (sel) full
even tough you did not specify the generation of your server
if this is the complete error message
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS
this is the way to resolve it :
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key.
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup
Aug 18, 2010 | HP ProLiant ML110 Server
Printer problem - HP Photosmart 8150
If the printer cannot print or move any paper, follow these steps to display the Event Log. Otherwise, print the Event Log.
1. Press Menu until INFORMATION MENU appears.
2. Press Item until SHOW EVENT LOG appears. Press Select to show the Event Log.
3. Press - Value + to scroll through the Event Log.
4. Write down the error messages.
If you see a 52.X error then this indicates the following:
0 Laser/Scanner Error
1 Laser/Scanner Startup Error
2 laser/Scanner Rotation Error
ACTION:
1. Press GO. The page containing the error will automatically be reprinted.
2. Turn the printer off, and then turn the printer on.
3. Reseat the cables fort the Laser / Scanner Assembly.
4. Replace the Laser/Scanner Assembly
Sep 21, 2009 | HP Photosmart 8150 InkJet Printer
HP Officejet Pro L7580 ADF will not pick up paper. ADF top roller will not lower to grab paper. During process, ADF mechanism clicks as if it is trying to lower top roller, but ADF top roller will not...
Aug 11, 2009 | HP OfficeJet Pro L7580 InkJet Printer
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
kw7157@yahoo.co.uk
Mar 20, 2009 | HP LaserJet 4100 Printer
Windows event log service wont start, error code 5
Your right its not a virus, and its not because your running one of the top anti- virus software,the problem is else where.
Have you checked the log files to see if you have permission?????
Have you checked event viewer to see if you have permission????
I need to know or the fix I have for you will not work.
Mar 13, 2009 | Dell Inspiron 530 Desktop Computer
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Jan 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
456 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
