Question about Refrigerators
Samsung rfg238aars how to reset the front display panel when it shows 88 88
4 Suggested Answers
  • 65 Answers
SOURCE: samsung RFG 297 series... contro panel reads 88 88
This is technical unit an they can be pretty touchy with power outages sometimes. It may be in a display mode. If you havent already try unplugging the unit for a minute or two and plug it back in. This doesnt reset its programming try holding Energy Saver Key + Lighting Key for 8 seconds and let the unit run thru a self diagnstic test and hopefully it will reset. If neither works its going to have the main board replaced.
Posted on Jan 23, 2010
Testimonial: "It worked! Thank you so much!"
aasc
  • 1606 Answers
SOURCE: Panel showing 88 88
You can try unplugging , wait a few minutes , and plugging back in . If that doesn't work , then the main control board , located on the back of the refrig ( behind an 8 " X 10 " panel ) , was damaged by the power surge , and needs to be replaced .
Posted on Nov 29, 2009
  • 79 Answers
SOURCE: Our power went out due
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Posted on Feb 02, 2011
Samsung refrigerator RFG238AARS isn't making ice or dispensing water. How do I reset from the back?
Check your manual for resetting the unit electronics. It should be mentioned.
Dec 28, 2016 | Samsung Refrigerators
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
How to reset Panel for PFSS6PKW bottom freezer GE Profile Refrigerator? When power went off display is just showing 88 88.
Try pressing and holding the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 or 15 seconds. It should give you and audible beep and reset the panel.
Oct 16, 2014 | Refrigerators
Ge adora French door refrigerator has 88 on front panel and buttons do not work
Try removing all power for 1 minute, see if it resets.
88 on a display is a "test" display usually....all lights lit
also check if the controls are locked....top right button
Mar 12, 2014 | Refrigerators
My samsung model RF263AEPN is flashing an 88 89 after the power went out
This is taken directly from the Samsung website:French Door: Why Is The Display Blinking 88 88 And Not Responding?Cyber
Drastic power fluctuations such as power outages and surges can cause electronic device to behave abnormally. If the refrigerator display is showing 88 88 (all eights) and is still cooling properly, unplug the refrigerator for 60 seconds and then plug it back in. If the display returns to normal after approximately 2 minutes service is not required. However, if the display does not return to normal service is required.
Sep 23, 2013 | Samsung RF263AEPN French Door Refrigerator
Samsung side by side RFG297AAWP display shows 88 88
Press and hold the energy saver button, and the lighting button at the same time until it beeps and clears, 10 seconds. When it goes back to normal panel do the same thing again which will put the fridge in a running diagnosis mode and see if any parts of the 8's are flashing, if so look on the back of the fridge at the error codes.
Nov 24, 2011 | Samsung RFG297AAWP Side by Side Bottom...
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
Feb 02, 2011 | Samsung Refrigerators
Refrigerator control panel
88-89 Flashing Reverse 9.
I noticed this occurs when the Ice Machine get jammed up.
Remove all ICE from Tray and Clean.
Press and Hold Energy Save+Alarm Button for 10 Sec.
Jul 18, 2010 | Samsung Refrigerators
Samsung RFG 297 series... contro panel reads 88 88
Jan 23, 2010 | Samsung RM255LASH Side by Side...
Refrigerators Logo
874 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
