Question about Canon PIXMA Office Equipment & Supplies
How to replace canon mp250 printer roller - PIXMA Canon Office Equipment & Supplies
5 Suggested Answers
SOURCE: canon mp250 paper will not feed snags on something
I had a paper feed problem with a Canon MP 250 and solved it this way. (not my own)
After many attempts t clean the feed rollers etc. I tried the following.
I cut a piece of card stock about two inches wide. I fed this sock from the front to rear and carefully worked the card stock in and out and from side to side (flossed it) and dislodged a drywall screw !!
I realize that having a drywall screw lodged in the paper feed is not common, however this "flossing trick may help to clear the paper feed path in other situations.
Posted on Dec 05, 2010
  • 5382 Answers
SOURCE: i have a canon pixma mp250 printer and i can't find the manual to explain how to replace the black ink cartridge.
To change the ink, make sure that the printer is on (green light is lit). Then lift up the entire scanner unit and latch the support on the right. Wait for the cartridge carrier to move into the ink cartridge replacement position. Open the cartridge cover on the right hand side by pinching the front and the tab on the top together; then lift it upwards. The cover will rotate towards the back of the printer. Pull the empty cartridge back out of the slot. Open your new cartridge and peel off the protective tape. (Do not touch the electrical contacts or the nozzles.) Place the new cartridge in the slot (slide it forward). Then rotate the cartridge cover back down until it clicks. If you do not need to change the color cartridge, lift up on the scanner unit until the support unlocks. Then carefully lower the entire scanner unit to close it (don't pinch your fingers or drop the scanner unit). If the orange Alarm light comes on, check that the cartridges are correctly installed and the cover is in place. Wait until the printer recharges ink system before sending a print job or copying a page.
Canon has the documentation for the MP250 on their site: http://usa.canon.com/cusa/consumer/products/printers_multifunction/photo_all_in_one_inkjet_printers/pixma_mp250#BrochuresAndManuals (for the manuals) .
I hope this helps.
Posted on Apr 04, 2012
  • 102366 Answers
SOURCE: i have a canon pixma mp250 printer and i can't find the manual to explain how to scan
You may download the manual from here.
Posted on Jul 07, 2012
Geekman
  • 32281 Answers
SOURCE: How to install canon all-in-one printer without the cd?
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on Mar 20, 2013
Canon mp250 error no paper
Get a q-tip and wipe roller with rubbing alcohol on the q-tip. This should renew the friction ability of the rollers.
Jan 03, 2013 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error code p22
P22 (Scanner error)Cause: The scanner is not workingSolution:1. Replace Canon MP250 printer scanner.2. Board Replace Canon MP250 printer
Better TO buy a new one..
Http://www.tech911.biz
Mar 22, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Mp258 error code p22
6. P22 (Scanner error)Cause: The scanner is not workingSolution:1. Replace Canon MP250 printer scanner.2. Board Replace Canon MP250 printer
HTTP://WWW.TECH911.BIZ
The paper is misfeeding to the right
clean the rubber roller carefully so it can guide the paper again properly canon ink cartridges
Dec 03, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
E03
just clean the rollers this works for me canon ink cartridges
Nov 19, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hello i have a canon mp250 printer and when i put paper in it i takes it at an angle and says paper jam what could the problem be and how can i fix it
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My mp250 printer is jamming paper and making a clicking sound
There's a piece or shred of paper caught in the paper track somewhere. Or one of the rollers has become mis-aligned. Its a case getting into it and checking it out.
Jul 19, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
old marine
old marine
