Question about Canon Pixma Mp250 Printer
How to take canon mp250 printer apart to replace feed roller
5 Suggested Answers
  • 14 Answers
SOURCE: Does anyone know the difference
The exchange roller kit has all the tires that pick up the paper in the kit (feed, separation, and pick up tires). I think the other tire you are talking about is just one tire not the set.
Also check to see a switch on the scanner that is used for single feed or multiple feed. If its on single feed it will multi feed all the time. You can clean the tire with rubbing alcohol too, to see if your double feeding goes away.
Posted on Mar 03, 2009
tbreeze47
  • 3083 Answers
SOURCE: After paper jam was cleared my printer wont feed
There is a small plastic gear that turns the roller, and when a paper jam occurs, oftentimes the gear strips it's teeth, and then the roller won't turn and feed the paper. I had this happen with an HP printer, and took it apart to see what the problem was. Upon finding the stripped gear, I tried to contact HP to get a replacement part and was told that they don't sell parts to anyone except HP authorized dealers, so I found a used printer and cannibalized the part, replacing it myself. Unfortunately, the broken gear problem happens a lot. About the only thing you can do is maybe load less paper, or load just the sheets you need for your print job, but even this doesn't guarantee that a jam won't occur. If you use labels a lot, they can leave glue residue on the rollers, causing a jam. You just have to keep them clean and hope for the best. In my opinion, the clean roller maintenance doesn't always work, and just a small amount of adhesive on the roller(s) can mess you up. They use a lot of plastic parts in printers these days, so they're very susceptible to breaking. Unfortunate, but that's the way it is. I guess that's their way of ensuring the printers won't last an awful long time, making people buy replacement printers sooner than they should have to. Don't think any one printer is necessarily better than the other, these days, so just try not to overload the paper and hope for the best. Sorry I don't have better news, and good luck.
Posted on Apr 06, 2010
SOURCE: canon mp250 paper will not feed snags on something
I had a paper feed problem with a Canon MP 250 and solved it this way. (not my own)
After many attempts t clean the feed rollers etc. I tried the following.
I cut a piece of card stock about two inches wide. I fed this sock from the front to rear and carefully worked the card stock in and out and from side to side (flossed it) and dislodged a drywall screw !!
I realize that having a drywall screw lodged in the paper feed is not common, however this "flossing trick may help to clear the paper feed path in other situations.
Posted on Dec 05, 2010
Geekman
  • 32281 Answers
SOURCE: Hi I have a canon
Most likely it would be better to put your money towards a new printer.
I suggest you Google search for the specifications and prices from various suppliers on the Internet for a price comparison.
Posted on Jun 13, 2011
Canon mp250 error no paper
Get a q-tip and wipe roller with rubbing alcohol on the q-tip. This should renew the friction ability of the rollers.
Jan 03, 2013 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error code p22
P22 (Scanner error)Cause: The scanner is not workingSolution:1. Replace Canon MP250 printer scanner.2. Board Replace Canon MP250 printer
Better TO buy a new one..
Http://www.tech911.biz
Mar 22, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
Mp258 error code p22
6. P22 (Scanner error)Cause: The scanner is not workingSolution:1. Replace Canon MP250 printer scanner.2. Board Replace Canon MP250 printer
HTTP://WWW.TECH911.BIZ
Hello i have a canon mp250 printer and when i put paper in it i takes it at an angle and says paper jam what could the problem be and how can i fix it
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 15, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
My mp250 printer is jamming paper and making a clicking sound
There's a piece or shred of paper caught in the paper track somewhere. Or one of the rollers has become mis-aligned. Its a case getting into it and checking it out.
Jul 19, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Canon mp250 paper will not feed snags on something roller works but will not feed
Mar 17, 2010 | Canon Office Equipment & Supplies
Paper feed problem
Try cleaning the rollers with a damp paper towel. Dilute alcohol with water (half and half). Be sure to clean all the way around. Taking it apart is quite a process. Be sure you can get the replacement parts before you start.
May 09, 2008 | Canon BJC 7000 InkJet Printer
Canon Pixma Mp250 Printer Logo
43 people viewed this question
old marine
old marine
