Question about Black & Decker 5.2 AMP 14-Inch Grass Hog Trimmer/Edger #GH700
26 black decker gh700 schematics
After unscrewing all the housing screws, houw do you open the plastic housing? Are there snaps? or are the parts interlocked?
SOURCE: I have a Black and Decker Handy Shortcut, I need a part
If one of you wants to sell yours I will buy it for the part I need!! I am missing the center plastic post , the one without the blades on it. email me at mnorling24@hotmail.com
Posted on Mar 29, 2009
milten1
  • 1304 Answers
SOURCE: Where can I get a new bowl for my Black and Decker
call 1-866-925-PART
ask for part number
175727-00
17.00
Posted on Oct 08, 2009
  • 634 Answers
SOURCE: Good Afternoon,
they often bind and a pair of channels locks will give the leverage to unscrew, and grease the bolt to avoid such issues. have a nice day.
Posted on Apr 23, 2010
SOURCE: mm850switch for black decker wher do wiring go
Here is a picture of where the wires go on the switch.
Posted on Jul 22, 2010
How do I disassemble the drill to get to the battery so I can replace it?
Just unscrew all the screws holding the case together, not just the handle part.
Gently split the case in half to get to the battery in the handle part.
Be careful pulling the spade connectors off the battery leads and remove battery.
Swap over the new one, making sure the polarity is correct and slot back in.
Line up the case and snap back together, replacing all the screws.
Oct 12, 2016 | Black & Decker Black And Decker Pivot...
Gh700 grasshog trimmer - round plastic gear drive broke in half - can I get a replacement or even a metal gear?
Same problem; GH700 with a stripped gear, inside the casing.
I wish places with replacement parts sell uncommonly broken pieces... I didn't have an account for commenting a request in that site.
If someone asked them, it could be available in a matter of time.
Black and Decker GH700 14 GrassHog Trimmer Edger Parts
Sep 01, 2011 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
I have a nearly-new 14"
These machines, unfortunately, are now considered disposable consumer items by the industry. One should expect a couple of years of good service from them and that is about it. Your problem is of course, the drive belt. Black and Decker does not list a replacement belt in the parts available for your model.
http://servicenet.blackanddecker.com/Products/Detail?isId=true&productNumber=GH700&selectedType=17047
This big lawn tool parts company does not list internal parts either; only external. Sorry.
http://www.ereplacementparts.com/black-and-decker-gh700-grasshog-trimmeredger-parts-c-4167_9518_9530.html
Jun 12, 2011 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
My grass hog xp starts but the spool won't spin
This unit is supposedly the same as the GH700 drive system. There is a 5:1 plastic reduction gear inside the housing driven by a steel gear from the motor. It easily strips, melts, or simply breaks. The part is difficult to find. I have not found one yet for my situation.
Apr 19, 2010 | Black & Decker 14" Grass Hog Xp...
ENGINE WILL NOT ENGAGE WITH SPINNING SPOOL
I had the same problem, The pully is plastic and is mostlikely melted. I took mine apart when it finally stopped working and found that the belt had broken as well. When taking it apart, there is a hidden screw under the black sticker label. Just feel for the soft spot. Also, there are screws under the black plastic embelishments.
Apr 18, 2010 | Black & Decker 14" Grass Hog Xp...
Black & Decker P1400AB fuse change
If it is the fuse inside the cigarette lighter plug, just unscrew it and put a new fuse in.
If you mean replacing the two 25amp fuses inside the inverter housing, you can bypass the fuses by soldering the two sides together. Or, if you want to put new fuses in, heat the solder holding the fuses in until they pop out and insert new ones.
As for opening the housing, good luck!! I ended up using steel cutters to rip off the plastic. The best option would be to buy a new one and return the old one in the package.
Jan 16, 2010 | Black & Decker PI400AB Power Inverter
Black and decker leaf hog on off switch schematic Switch doesn't engage
Take out all the screws. Gently remove half of the case. Put a shim in behind the plastic pivot that rocks the switch. I rolled up a 1/2" by 3" piede of duct tape and jammed into the back of the oval socket for the rocker. This pushes the rocker against the switch hard enough so that it rocks the switch properly. Snap the case into place and test the switch before you put the screws back in to make sure it is now working properly.
Aug 27, 2009 | Black & Decker & Leaf Hog Blower / Vacuum
Can't remove casing for B&D Cordelss Grasshog (NST2018 Type 2)
These are the steps to open the clamshell/motor housing for the Black and Decker 18V Cordless Trimmer Model NST2018. The orange clamshell has two plastic clips that engage two recesses inside the black plastic ring. You use two screwdrivers to disengage the clips and seperate the black plastic ring from the orange clamshell. Follow these steps: Wrap tube assembly in a small towel and mount in a large bench vice securely. You will notice two small openings at the top of the black plastic ring at the top of the orange clamshell. The next steps require two people. Person one inserts a flat-bladed screwdriver into into each of the small openings at the top of the black plastic ring (two screwdrivers). Using the tube assembly for leverage, pry the black plastic ring from the orange clamshell with enough force to disengage the orange plastic clips from the black plastic ring. Person two pulls the orange clamshell/motor housing away from the black plastic ring/tube assembly along a straight line (same axis as the tube assembly). After you've separated the motor/clamshell housing from the black plastic ring, remove the six screws and open the clamshells.
Jul 24, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 5.2 AMP 14-Inch Grass Hog Trimmer/Edger #GH700 Logo
42 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
