Question about HP DeskJet Office Equipment & Supplies
Diagnostic tools is anyone there?
Hi!
Go to www.hp.com
Search for your model printer
If the search fails, go through each submenu until your model is found.
Usually, once you find your model, you will find available files to download such as drivers and diagnostic tools... Or, you may have to hit support, then these files will show up.
Hope this helps!
Posted on Jul 14, 2013
2000 mustang misfire cylinders 1 and 2
plug test light, coil packs? pressure test, check heads, valves, fuel injector? going to need a diagnostic on that one, unless you got the tools, take it to the er and get a rundown, anyone with a proper diagnostic computer should be able to do it
Dec 12, 2014 | 2000 Ford Mustang
Can anyone explain how to install this alarm system on my 89 camaro?
Lol, really going to need a lot more info then that. I am assuming that you would not have the knowledge required to perform this safely. I would suggest professional installation.
Apr 10, 2013 | Cars & Trucks
Questions about my car scanner tool ?
You can click http://drsets.com/wholesale/auto-diagnostic-tool/ ,go to choose which one you would like to have .
Feb 21, 2013 | Ankaka.com Car OBD-II Diagnostics Tool...
Does anyone know where i can borrow a pci motherboard diagnostic tool?
Hello zacklong13,
Below is the link where you can buy PCI DIagnostic tool for only 4.99http://www.meritline.com/pc-pci-isa-diagnostic-card-motherbboard-2-digit-analyzer-test-post---p-60724.aspx?source=fghdac
Thanks.
Apr 19, 2012 | Computers & Internet
My securty light is on in my 2002 chevy impala and my car wont start. how do i fix the problem
The GM PASSLOCK system is the probable cause, Try a different ignition key. If that doesn't solve the problem continue reading:
A Scan Tool can be used to read and erase trouble codes, display, record and play back LIVE diagnostic data and perform other tests allowed by the vehicle maker. Scan tools that cover vehicles 1982 to present are available at your local auto supply dealer.
You don't indicate any diagnostic tests to date. A dealer or your local mechanic will charge $100-$200 to perform a diagnostic scan. However, AutoZone will provide a thorough scan for FREE. Anyone who tells you that a modern vehicle can be diagnosed without a scanner with the problems you have set forth is merely guessing.
Oct 07, 2011 | 2002 Chevrolet Impala
Honda element check engine light on multiple times. dealer turns off, but keeps coming back
The dealer should not simply reset the check engine light without informing you as to the reason it is coming on. The hadheld diagnostic tool should be plugged in to your cars unit and the code deciphered - it could be a simple matter such as the gas pressure valve system in the fuel tank or something more sinister or expensive if you leave it - I am astonished that they simply reset it - go to another dealer and ask them or your local garage as the diagnostic tool is not dealer specific - anyone can buy them.
Mar 18, 2011 | 2003 Honda Element
My router password
Click on the link below and download the tool to find out your WPA.
Read the instructions on the Download page to know how the tool works
HP Network Diagnostic Tool
After you have downloaded and installed, open the HP Diagnostic Network tool and click on Advanced Tool - Click Retrieve WEP/WPA
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 03, 2011 | Linksys Wireless-G Broadband Router
EAC FAIL ON A 2004 PLATE FORD FUSION 2
the best thing to do at this point is to have the diagnostic trouble codes read that may be stored in the memory of the on board computer, it is called the OBD 2 (on board diagnostics generation two) electronic engine control system.
Oct 06, 2009 | 2004 Ford Fusion
Finding a fault code for ABS Brakes
Diagnostic fault codes can only be read through the use of a bidirectional scan tool. There are no provisions for "Flash Code" diagnostics.
May 22, 2008 | 1992 Pontiac Sunbird
15 people viewed this question
Seeker5211
Seeker5211
