Question about Samsung Televison & Video
How do I change tv/video mode - Samsung Televison & Video
    Champion:
  • 247 Answers
Take remote look for tv/av or a button with an in bound arrow with a square and press u will see av 1 av 2 according to the source say dvd u accessed on the back of tv u are good to go
Posted on Jul 19, 2013
Have a westinghouse lcd tv 50inch model ew50t5kw and would like to know before changing any parts or boards what causes a blue screen no sound or picture
  1. Frank: Verizon. com says try this: Change your VCR's Channel to 3 or 4. Most blue screen issues are caused by the VCR not being set to Channel 3 or 4. If changing the VCR's channel (using the channel buttons on the VCR or from the VCR remote control) did not change your TV screen, go to step 2.
  2. Make sure your TV is not in Video mode. There are three possible ways to change your TV's mode using your TV remote control: 1) Press a Mode button, toggle through the options and select TV, 2) Press a Video button to change your TV's mode from Video to TV or 3) Press Menu, locate Mode or Audio/Video setup and select TV from one of the options. If you are not sure how to change your TV's mode, see your TV's user guide for more information.
  3. Check to make sure your set-top box is plugged in and turned on.
  4. Check to see if other TVs (connected to different outlets) have a blue screen. If they do, contact the Verizon Fiber Solutions Center.
May 21, 2015 | Westinghouse Televison & Video
How do I change the TV from video mode to TV mode without the remote control?
Look for a button named AV or Input or something of the like. Press the button to toggle between different video modes such as AV, TV, S-Video etc.,
Dec 03, 2009 | Sanyo DS31520 31" TV
Toshiba television will change from tv/video mode to
I would check to see if the Input button is stuck on the front panel of TV. If it is not stuck then it is probably still bad. Tactile switches are notorious for failing in this manor. The only real fix if it is not stuck down is replacing the switch.
I hope this helps,
Skyassoc
Jun 22, 2009 | Toshiba 36A43 36" TV
How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Jan 12, 2009 | Toshiba 14AF44 14" TV
How Do I Get a DVD to Work with This TV?
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
Good Luck!
Feb 16, 2008 | RCA G32665 32" TV
Dvd hookup
  • First make sure the audio (red &black) and video (yellow) are plugged into their respective color matching inputs on the TV monitor.
  • Second either using the TV remote contol or TV's builtin control panel set the tuner mode to video. Depends on which TV's input terminal you connect the DVD player; that's where the Video mode has to be assigned.
  • For example: if you connect them to video1, set the tuner to video1. changing the channels up or down will never set it to video mode. You must press video button to change the tuner from regular channel mode to video mode.
Feb 16, 2008 | Televison & Video
Video mode
my TV remote broked and i want to know how can i change Emerson EWF2004to video without the remote so i can watch movies
Oct 29, 2007 | Emerson EWF2004 20" TV
Video mode
I just bought this same TV at a yard sale today. There was no remote and it had the same problem. I used autoprogrtam feature of my cable remote to use the TV part of the that remote. With that remote I was then able to change video inputs and access all the menus properly. Good luck, Dan
Sep 04, 2007 | Sanyo DS27820 27" TV
Channal selector down
Sounds like it is changing to another video mode that has no input so the screen is blue. On many tv's the channel buttons also act as video input button. This should happen with the buttons on the tv. If you are using the the remote I am not sure why it is acting like a video input button. Try changing video to tv with one and changing the stations with the other. I take it you are watching antenna tv and not using cable box or satellite. If this does not work and you have old vcr just use it as a tuner to change your channels.
Aug 03, 2007 | Toshiba CX35F70 35" TV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
