Question about BaByliss Health & Beauty
Babyliss men won't charge
Type T 73 charging light comes on shows charging but then will not start
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
  • 127 Answers
SOURCE: Husquavarna tractor battery won"t start engine
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
Posted on Jun 26, 2009
  • 4 Answers
SOURCE: My rear flea light won't
it might be water damaged return it to bike shop and ask for full replacement under the lifetime warranty
Posted on Sep 28, 2011
awaissabair
  • 580 Answers
SOURCE: 2012 VW Jetta TDI battery won't hold charge and car only clicks and won't start
You need to charge your battery up more. Either get a battery charger or leave the jumper cables hooked up for a longer period of time.
Your battery was probably completely dead. You might even need a new battery...they really don't like to be completely drained.
Posted on Oct 09, 2012
  • 14036 Answers
SOURCE: 2001 jaguar s-type won't crank battery new and charged. Turn the ignition car won't make a sound
many things will cause no start problems could have faulty ignition switch.use test light see if power going to starter if not check ignition fuse to starter.if power going to starter, more likely starter solenoid or starter faulty.if ignition fuse okay and starter and solenoid okay still no start problem could be in the ignition switch or inhibitor switch faulty.code scan for faulty theft security system which will also cause no start conditions.
Posted on Oct 22, 2012
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Pentax Optio P80 battery won't charge all the way
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 01, 2012 | Pentax Cameras
My Samsung N145 Battery does not power the notebook
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 27, 2012 | Samsung NP-N145-JP02US NETBOOK
Batter was low and it won't come back on
Mar 24, 2012 | Computers & Internet
I have a09 street bob that won't start. The lights come on, I can hear the engine whine when I put it in on, but when I press the start I get nothing. Not even so much as a click.
Sounds like a battery low on charge. As the bike has huge pistons compared to a 4 cylinder machine, it's harder for the starter motor to turn and needs more power.
Try charging the battery, on a proper charger not an optimate battery conditioner type.
When starting turn any ancilaries (lights, heated grips etc) off.
Good Luck
Jul 15, 2011 | Harley Davidson Boulevard 400 Motorcycles
I have lost the charger for my Babyliss 7053u, where can I find a new one?
A new kit is fairly cheap: http://www.amazon.co.uk/BaByliss-Men-7053U-Over-Grooming/dp/B002FGTJ0O
I couldn't find just the charger anywhere... I would recommend just buying a new kit.
Apr 21, 2011 | BaByliss 7053U Beard Trimmer
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
My sony ericsson phone wont come on
when not used for some time battery takes about 30 min to start charging. if used and suddenly stopped then is time to replace battery.
May 10, 2009 | Sony Ericsson K750i Cellular Phone
Audiovox PVD 73
the green light that comes on when you charge it goes off.
Dec 28, 2008 | Audiovox D1708 Portable DVD Player
Health & Beauty Logo
85 people viewed this question
Top BaByliss Health & Beauty Experts
NOEL
NOEL
ray gallant
Tom Chichester
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
