Question about VeriFone VX510
Tcp error 1003003b - VeriFone VX510
TCP Err 10050042
I have no idea about cash registers but a TCP error sounds me to Internet connection. Chack if this might be the reason
Jun 26, 2015 | Retail Supplies
Tip
Network sharing issue
In Multiwindow platform normal,sharing folder and printer is always big issue.
Error type:
ex:
\\server is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.
This method can be used for many network error
Solution:
1)Fixing the winsock and tcp/ip .
On the run command :
for winsock run:
netsh winsock reset
to reset tcp/ip run:
netsh int ip reset c:\resetlog.txt
or
run winsock fix from www.snapfiles.com/get/winsockxpfix.html
2) Enable NetBIOS over TCP/IP
open up Network Connections, under Control Panel.
Right click on your network adapter and click on Properties.
Click on Internet Protocol (TCP/IP), then click on Properties.
Click on Advanced, and click on the WINS tab.
Even if it is set to Default, set the radio button to Enable NetBIOS over TCP/IP.
Press OK on each screen until everything’s closed.
Go back to the client machine and try again.
You should be able to connect!
3)dnsflush
Open Network Connection
Check box File & Printer sharing > ok
Disabled NIC
Enabled it back
Open CMD > ipconfig /flushdns
ipconfig/registerdns
4) Make sure windows firewall and antivirus firewall turn off
on Apr 21, 2010 | Computers & Internet
Tcp error 10050042
TCP error means you are not connecting to internet, reset your modem and try again make sure you can get to yahoo.com or similar site, if you can then press star key above red x go to tools and then ping test.
then toruble shot and then repair key
Jul 14, 2014 | VeriFone Retail Supplies
I am having problem with my cable net my laptop giving error 720 and when i troubleshoot it says DNS error in connecting net
Check TCP/IP filtering properties: Open TCP/IP properties of the
connection, Advanced button, Options tab, TCP/IP filtering properties.
If filtering is enabled, change all to permit all instead of permit
only. save the changes and then return to disable filtering.
Nov 20, 2013 | Computers & Internet
Error code tcp on internet connection for sharp tv
Yes, my firewall was blocking it. I got around it and it fixed the problem.
for more help visit CBR Tech Solutions
Apr 21, 2012 | Sharp LC-70LE640
I keep getting kicked off during online play (8002AD23). I have a wired, ethernet connection
That error means your PS3 is having trouble connecting to the PS Network. That can be caused either by your internet speed (if you are downloading something for example, it may lower your speed and cause this error) or by a random glitch on the PSN. You should also try forwarding the ports from your router. The PS3 required ports are : TCP 80 TCP 443 TCP 5223 UDP 3478 UDP 3479 UDP 3658
Also keep in mind that it is recommended you set your PS3 to use a Static IP. I hope that helps
Philip
May 27, 2011 | Sony Playstation 3 (PS3) Console
Not connecting to internet
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Make sure that UPnP is Enabled
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Jun 19, 2010 | Sony PlayStation® 3 (80GB) Console
I want to play cod 4 on line and when i go to sign in it comes up dns error how can i fix this
You will need to do port forward :
Call Of Duty 4 28960 28960 TCP/UDP
Call Of Duty 4 20800 20800 TCP/UDP
Call Of Duty 4 20810 20810 TCP/UDP
Nov 13, 2009 | NetGear DG834G Router
Tcp error on connection in internet
tcp error means there is something wrong with TCP/IP PROTOCOL, with is basic network service. try restarting services. if it won't work there may be something wrong with DNS server
Oct 05, 2009 | Microsoft Computers & Internet
Computer
You are going to go to the tcp/ip settings and enter a permanent ip address.
If you access the internet you could always use the ip address you are getting from dhcp, just go to start-run and type cmd then at the command prompt type ipconfig and copy the ip, subnet, gw and dns to the tcp/ip settings.
Thank you for choosing agadycom.
Nov 13, 2008 | Microsoft Windows Server Standard 2003 for...
VeriFone VX510 Logo
242 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
