Flat Panel Televisions
Problem for Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Tv
By mike45 on Aug 27, 2007
toshiba 50 plasma wont turn on, only 11 months old
Same Problem
Mar 27, 2009
-   I have the same problem on my Toshiba 42PH95. It is 3 years old. I bought the schematics, which are very weak, since they leave out the Power Supply. It appears to the center of the issue, made by Senseng (spelling?) part no PSC10131F. Discount-Merchant.com had this part but 0 stock now. I am an electronic technician, but not on TVs so I followed the power on circuit. 5volts is present at the power switch and switches when the button is depressed. It goes via a few connecters to a logic board and switches there into a chip (gate array) many ins and many outs. But no outs respond.
My actual problem is a little different in that I grt no flashing Red Led on the front, just some relay clicks when power is plugged in and no response when the power on/off switch is depressed or same with the remote on/off, nothing.
AC fuse is good, power gets to the power board. 5 volts and 3.3 volts are present. I disconnected the Sein board per a few posts, but no help.
I hope this might help someone, and I will let you all know if I get a resolution.
-   Maico4
Mar 16, 2009
-   it wont turn on-   Guest
May 11, 2008
-   MY 50' TOSHIBE WONT TURN ON. POWER LIGHT JUST KEEPS FLASHIN RED-   DaleJ
Apr 17, 2008
-   I have a Soyo DYLTO32B 32 IN. tv. Same has your problem. Turn tv off at bed time. The next morning black screen. E-mail SOYO support page. They said soure was the problem,but when it it black. Hard to change soure. Thank you Dennis-   Guest
Feb 01, 2008
-   I have the same problem here. The 50" plasma Toshiba just keep trying to turn on it self (for like every 3 to 5 second, it turns on and for every 3 - 5 it turns off, and I did not touch anything). I hope there is a solution before I ship the thing to service.-   Guest
Solution #1
posted on Aug 27, 2007
Somewhat Helpful)
RHONNHIE
Rank: Master
Rating: 75%, 19 votes
YOU HAD TO CHECK POWER CORD IF ITS NOT THEN YOU HAD TO CHECK POWER SUPPLY CIRCUIT A FUSE
Comments:
Aug 27, 2007
- YOU HAVE TO CALL SERVICE TECHNICIAN
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2008
Not Rated)
hedpuk
Rank: Apprentice
Rating: 0%, 0 votes
Hitachi 32LD8D20 just stopped working whilst playing on XBOX. Red light on the front of the tv is still on but no image is being displayed. All leads and cables are still plugged in. ONly 6 months old
Was this helpful?
Yes
No
Solution #3
posted on Mar 26, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you all guys... call a servivce technician I have the same problem ..with my tv .. and I found that this web page is not worth ****..****..****..****..****
Solution #4
posted on Jan 08, 2008
Not Rated)
kennyfixall
Rank: Guide
Rating: 78%, 4 votes
do u have any small electronic knowlage ,just basic, if u do i can explain to your how u can do it ur self,, am sure possible is a power supply issue or main video board output,
Was this helpful?
Yes
No
Popular Solutions for Flat Panel Televisions
Questions and Unsolved Problems for Flat Panel Televisions
Answer
trying to find ot who makes vivo plasmas
Answer
how can i make homemade satellite disk for better viewing for my tv?
Answer
Hi i have an ACER MGW at3705 tv it will turn itself on midway through the day for no reason can you... (More)
Answer
USB videos not playing ON TV.OTHER FILES OF USB ARE OPENING BUT VIDEOS ON USB R NOT PLAYING ON MY 40... (More)
Answer
need help sharp tv 29v-fl200 ic regulator 14 pins is missing
7 Other Users Have The Same Problem - Continued
Comment by lg60pc1d, posted on Jan 19, 2008
purchased tv on 7/30/2007.  less than 6 months old, cycles through trying to turn on over and over again.
Comment by Guest, posted on Dec 04, 2007
We have had are tv for 13 months and it worked fine until now. When you go to turn on the tv with the cable remote to turn everything on, the tv will not turn on now and if thats not enough the volume wont work either by remote control. Please help. We have tried new batteries, a new remote, the original remote to the tv and nothing has helped so far. Please Help.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Flat Panel Televisions:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
