Question about Microwave Ovens
SharpMicrowave Is the keypad easily replaced?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
I don't believe so, you may need to take it to your provider
Posted on Jul 14, 2013
Turntable does not turn (work). model:JVM3660SD001
have you check if the unit has the power... & also check if all the settings was made..
Jun 13, 2008 | GE Microwave Ovens
New microwave keypad problems
Take it back to the place where it was purchased, If it's new, It can easily still be their problem still, There's probably nothing you can do that wouldn't be a lot of trouble for you
Dec 02, 2013 | Bosch HMV8051U Microwave Oven
My ge jvm1540 over the range microwave is displaying service needed keypad shortage what does this mean
see this steps and follow and fix it. God bless you
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can b
Nov 15, 2012 | Microwave Ovens
Keypad don't light up
see this causes and fix it. God bless you
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Sep 25, 2012 | Maytag MMV4205 Microwave Oven
Countdown dial swich does not move stuck
please see the next topic and proceed according with common sense.
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right parts.
God bless you
Sep 07, 2012 | Microwave Ovens
Sharp Carousel Microwave - R1481 keypad doesn't work
No! I'am afraid not, the problem is in the keypad control board, the whole assembly must be replaced, the part alone will cost around $100.00 or more depending on make and model.
Apr 16, 2012 | Sharp R410L Microwave Ovens
I am getting a keypad shorted error msg and beeping. Can the keypad be easily replace (by me?)
On these models the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can find helpful exploded view diagrams and order parts by entering your full model number with suffix from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
Apr 27, 2011 | GE Spacemaker JVM1740 Microwave Oven
Locked timer/keypad
Try unplugging it for a few minutes. If that fails, read the owners manual for instructions on how to unlock.
Jun 26, 2010 | Maytag Appliances Over-the-Range Microwave...
Can I replace keypad for my PLMV168KC3 Frigidaire Microwave?
Is it a membrane type touchpad?
These are usually held in place with an adhesive. You can pull the old one off and stick the new one on. The complication usually involves the connection between the touchpad and the body of the microwave. This connection may or may not be easily accessible.
Oct 09, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
