Decrypt bitlocker from toshiba 320 gb - Computers & Internet
  • 40 Answers
HI,
Below links have step by step guide to decrypt bitlocker:
1)
http://technet.microsoft.com/en-us/library/ee523219%28v=ws.10%29.aspx
2)
http://techstrick.blogspot.in/2012/11/remove-password-from-bitlocker-in-Windows-7.html
or you cab break the bitlocker key using disk decrypter:
http://www.elcomsoft.com/efdd.html
Regards,
Rahul
Posted on Jul 14, 2013
How to remove bitlocket from my laptop...it appears on one of my apps and also the avast shortcut...I tried to remove the app and installed it again but its still there
Go to Start > Control Panel
Right click on Bit Locker
To turn off or temporarily disable BitLocker
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Click Turn Off BitLocker. This opens the BitLocker Drive Encryption dialog box.
To decrypt the drive, click Decrypt the volume. To temporarily disable BitLocker, click Disable BitLocker Drive Encryption.
Feb 04, 2015 | Cell Phones
Tip
How to Recover Data From a Disk Encrypted by Bitlocker. Data Recovery.
Today we will describe the procedure of data recovery from a damaged disk encrypted by Bitlocker. Such problem may emerge as a result of damage to the file system of an encrypted disk (for example, damage to the area of the hard disk, where BitLocker stores important data, that happens due to unexpected system shutdown), inability to load OS or BitLocker recovery console, and other similar errors that prevent normal opening of the encrypted disk. The described problems may affect both system disk,portable external drive or USB drive.
In order to recover data we will use the utility Repair-bde (BitLocker Repair Tool), a command prompt utility which appeared back in Windows 7 / 2008 R2. This utility is used for access and recovery of encrypted data in a damaged disk encrypted by BitLocker.
Warning. This procedure should be applied after all the others have failed, and it was impossible to unlock the encrypted disk in a standard way by using a Bitlocker password or recovery key.
Requirements for data recovery from a BitLocker volume
To recover data from a disk encrypted by BitLocker you need to have at least one of the following Bitlocker defense elements:
  • BitLocker recovery password;
  • Recovery key;
  • System startup key (Startup key - .bek).
Data will be recovered to a separate disk the size of which should be no less than the size of the damaged disk. In the course of recovery, all contents of this disk will be deleted and replaced by decrypted data from the Bitlocker volume.
In our example, disk E: (size 2 Gb) is a USB drive the contents of which are encrypted by BitLocker, and which cannot be opened for some reason. To recover data, we have installed an additional external disk F: (size 16 Gb).
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-9.png
Method 1. Data recovery with the use of a BitLocker password
In the first place, try recovering data with this method (it will work with Windows 8 / 2012 and newer versions):
  • Launch command prompt as administrator.
  • Execute the command:
    repair-bde E: F: -pw -Force
    where E: - disk with Bitlocker data, F: - disk where decrypted data should be extracted.
  • In the course of executing the command you will have to specify BitLocker password (the same which a user is to enter into UI when trying to access an encrypted volume).
  • http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-2.png
Method 2. Decryption of a Bitlocker volume with a recovery key
For decryption of data located in a damaged volume which is encrypted with Bitlocker we will need a recovery key or a system startup key (if the system partition is encrypted).
Advice. BitLockerRecoveryKey is a unique sequence of 48 symbols. The recovery key is generated when a Bitlocker volume is created; it can be printed, saved as a text file to a local (this choice is not recommended) or external disk, or in a user account at Microsoft website.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0.png
Now let us launch data recovery with the help of this key:
repair-bde E: F: -rp 011407-712393-682121-100210-377003-405174-520014-328130 -Force
If Bitlocker is used for encryption of the system partition containing Windows, and for loading the system a special startup key on a USB drive is used, the encrypted volume can be decrypted as follows:
repair-bde E: F: -rk I:\3F558473-943D-4330-8449-62C36BA53345.BEK -Force
where file 3F558473-943D-4330-8449-62C36BA53345.BEK is a key to launch BitLocker disk encryption on a USB drive G: (by default, this file is hidden).
After the procedure of data recovery and decryption, before opening the disk where the contents of the Bitlocker volume were extracted, it is necessary to run its check. In order to do it, execute the following command and wait until it is complete:
Chkdsk F: /f
Important note. If you failed to recover data from an encrypted disk with the described methods, it is worth trying to create a sector-by-sector copy of the damaged disk with the help of a Linux utility DDRescue (or any other similar utility). After that, try recovering data from the received copy by the following scenario.
Data Recovery Software
We also should notice that exist more common and simpler way to recover files from Bitlocker encrypted storage. These are data recovery software. Of course, not all programs ?an cope in such situation but some of them have required function.
The only thing is that you must have a password to unlock the device which was specified when encrypt.
Then it's simple. Connecting device with the information that you want to recover to your computer and getting message.
Further, enter password in a special window after double-clicking on the device you need to recover in "This PC".
After that, the storage becomes fully accessible for data recovery for any of the Hetman Software programs.
on Jun 06, 2016 | Hetman Partition Recovery - Recover...
Tip
In this article we will describe the procedure of data recovery from a damaged disk encrypted by Bitlocker. Such problem may emerge as a result of damage to the file system of an encrypted disk (for example, damage to the area of the hard disk, where
  • Recovery key;
Chkdsk F: /f
After that, the storage becomes fully accessible for data recovery for Hetman Partition Recovery.
https://hetmanrecovery.com/recovery_news/how-to-recover-data-from-disk-encrypted-bitloker.htm
on May 05, 2016 | Hetman Partition Recovery - Recover...
How to turn off encripted key function
It depends which one. If it is like Bitlocker, go into Bitlocker and click to turn off Bitlocker. This may take sometime to decrypt the files!
Mar 04, 2014 | Sony VAIO Computers & Internet
How to decrypt memory card using bitlocker
You need the bitlocker code that was created when it was converted to an encrypted memory card.
Dec 07, 2013 | Computers & Internet
Bitlocker lost the key
There is no way to decrypt a bitlocked hard drive without the key.
http://technet.microsoft.com/en-us/library/ee449438(v=ws.10).aspx#BKMK_RecoveryInfo
Nov 27, 2013 | Seagate 500GB USB 20 5400RPM Portable 500...
I have encrypted my local disk using bitlocker encryption and now it shows Local Disk(D:) is not accessible Access is denied and when i right click it was not showing security tab. please help me
Try This:
Before you start
  • You must be logged on as an administrator.
  • The volume must be encrypted.
To turn off BitLocker Drive Encryption
  1. Click Start, click Control Panel, click Security, and then click BitLocker Drive Encryption.
  2. From the BitLocker Drive Encryption page, find the volume on which you want BitLocker Drive Encryption turned off, and click Turn Off BitLocker Drive Encryption.
  3. From the What level of decryption do you want dialog box, click either Disable BitLocker Drive Encryption or Decrypt the volume as needed.
    By completing this procedure, you have either disabled BitLocker or decrypted the operating system volume.
    Good Luck!!
Aug 16, 2012 | HP Computers & Internet
How can i take the bitlocker off my PNY 4GB flash drive?
Windows version like XP.
There are 5 steps to remove BitLocker Drive Encryption from removable drive. Here are the steps.
  1. Open Control Panel then click on BitLocker drive encryption link.
  1. On the nest window, click Turn Off BitLocker link on your removable drive or USB flash drive.
  1. Next, the BitLocker Drive Encryption window will appear, click on Decrypt Drive button to start the decryption process.
  1. The decryption progress takes some minutes to finish, so wait until the process completed. Do not plug off your removable drive during the process.
  2. After the process completed, a message box appears, tell you the decryption process was completed. Click on Close button to close the window.
right click on your 4 gb usb drive select turn of bit locker in W7
hope it helps you
Mar 09, 2012 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Need to remove bitlocker from USB2.0
hope it helps you
Mar 09, 2012 | Electronics - Others
Same proble, MS BitLocker is error message.
Bitlocker is available for Vista Business, Enterprise and Ultimate. This gives more security to your data files against unauthorized access. Once bitlocker detects theres a major change of hardware, such as master boot record, motherboard replacememt and such, it thinks that the hard drive is moved to another computer. Usually, bitlocker encryption can be disabled using the USB drive that was used to store the codes for decryption.
Jun 07, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
