Computers & Internet Logo
Posted on Mar 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't burn a audio cd
When I click burn a window pops up and says drive is not ready. Or it might say doesn't reconize drive. I'm using windows 98 and using DeepBurner software.
Anonymous
Level 2:
  • Expert 55 Answers
  • Posted on Mar 29, 2009
Anonymous
Expert
Level 2:
Answers
55
Questions
0
Helped
20348
Points
204
Possible drive problem
2answers
My computer no longer "sees"
hello
at end of this instruction set, see link to review more questions/answers,as your issue with CD/DVD ROM will vary .
This document applies to HP and Compaq desktop computers with Windows XP, Me, and 98. Use this document to make Windows and the CD writing software recognize the CD or DVD writer drive. Start at Step 1; do not skip to other sections until Step 1 has been completed. Step 1: Does Windows detect the CD or DVD drive? Use Device Manager to determine if Windows is recognizing the drive:
  1. In Windows XP, click Start , and right-click My Computer . In Windows 98 and Me, right-click the My Computer icon on the desktop.
  2. In Windows XP, select Properties , click the Hardware tab, and then click the Device Manager button. In Windows 98 and Me, select Properties , and click the Device Manager tab.
  3. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  4. Do the following depending on what is listed in the DVD/CD-ROM drives category:
    • If the CD or DVD drive name is missing , the drive is not being detected by Windows. Close Device Manager and skip to the section CD or DVD drive is not recognized by Windows .
    • If a drive name is shown but is disabled (icon is marked with a red X, c00877300.gif ), the drive has been disabled. Right-click the drive name and select Enable . You may have to restart the computer to complete the enabling process. The drive should work correctly once it has been enabled. NOTE: If the drive cannot be enabled, a required service or driver that the drive needs is not functioning or has been disabled. Click the plus sign next to IDE ATA/ATAPI controllers and troubleshoot any problems found according to any error codes in Device Manager. Resetting the BIOS may also resolve this problem.
    • If a drive name is shown but contains an alert icon (an icon marked with an alert symbol, c00877301.gif ), then use the section Using Device Manager error codes to troubleshoot the problem. You may also use the next section Disc burning software does not recognize the original drive to reset the drive configuration.
    • If the CD or DVD drive is listed as normal but your disc burning software does not recognize the drive, Device Manager shows no special icons c00877302.gif . Windows is detecting the drive but the writing software does not. Leave Device Manager open and continue with the next section Disc burning software does not recognize the original drive .
here is a link that will give you several other questions and answers to CD/DVD ROM issues.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11843&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443069
please rate me with 4 thumbs UP to keep my services active
1helpful
4answers
How can i downlord song in cd
You have burn the cd as a Audio cd. All you need a blank cd and a nice cd burning tool such as Nero.
Just install the Nero onto your system, then put the cd in and click on Make Audio cd on Nero and follow the on screen instructions.
Thanks !!
Please rate the solution if you like it.
CD Player in caravan doesn't play burned cds.
the CD player is a clever one thats looking for the copyright on the CD .Try using nero to burn the cd that oftens fools the player ,or an old computer with windows 98 on it with a copy of the old nero or windows media player that come with windows 98 as the later versions will not work with a lot of expensive players .if it has a line in plug then use a i pod or your mobile phone ,if it has a tape player then use a cassete with the wire coming out that plugs into a audio device ,i use my mobile phone which has a 1gb memory card in my jag as i have the same problem with the cd player ,also in the every day car my escort i use this as iam fed up with having the window broke and cd player nicked .But i have found that burning cds with an old computer with windows 98 i can burn cds that will play in the jag ,not that i use it a lot cant affords the petrol here in spain at 5 dollars a gallon
2answers
Is Windows 98 too outdated, to enable burn to a disc
Yes it is possible to burn them to a disc. Or the simplest way is get a USB flash drive and save them all there.
1helpful
2answers
Drivers for Toshiba satellite A75-S226
here ya go
http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
Using windows dvd maker vista with sp1 starts to burn then at about 98% get error message and stops the burn. also when i try to format a dvd disc ready to burn that wont work and the dvd drive d is...
two things. Firsly make sure that you are using the correct disks i.e if your drive is dvd-r then only use dvd-r disks, if its dvd+r then only use dvd+r disks if it is a multi drive then it won't matter what disks you use. Secondly don't format the disk first. If it asks you to format the disk click on the X to shut the pop up box. Only put the disk in when dvd maker asks for you to insert a disk.
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Do you have to have "Secure Disc" installed before you can burn CD's? How do I transfer my music from windows media player to a disc using the external burner? Sorry, I'm computer challenged. ...
hi frankie;
you can use third party software to burn your songs into the disc or you can use the built in burner of Windows. What operating system are you using? some things you need to check before burning:
1. cd-rom capable of burning?
2. is it a cd rewritable or a dvd rewritable?
-you can use cd-r or cdrw on dvd rewritables but not dvd-r/dvdrw on cd rewritable.
1. locate the songs you played on your media player in your computer,highlight it and right click one of the highlighted mp3 then select copy from the list
2. Insert the cd into your optical drive ( cdrom or dvd rom).
3. Open My computer and double click your optical drive icon.
4. Right click on the empty space inside that window and right click mouse then paste
5. There should be a link at the left side of the window that says "Write these files to CD"
***frankie; i would just like to remind you that the music burning im referring to is mp3 music, if you want to burn audio cd, you need 3rd party software for that.
Some cd players(discman, etc.) only play audio music format and not of mp3 format. Provide me details of what you want to do and i will help you. :)
1helpful
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Grand Canyon Tech
Grand Canyon Tech
