Question about Vehicle Parts & Accessories
Cool start remote starter
Dead battery
    Top Expert:
  • Vehicle Part... Master
  • 12,223 Answers
See the diagram attached. God bless you
Posted on Jul 25, 2013
2011 camry remote starter does not start car
only 2 possible for remote. unit is bad or battery dead. if both remotes fail to start car, take to dealer as internal unit on car is bad and needs to be reprogramed
Feb 25, 2015 | 2011 Toyota Camry
Would a dead battery stop your key from turning on in a 2003 gmc envoy
Sounds like a flat battery. Just enough to power your lights but not enough to power the starter motor. Try recharging the battery.and check battery connections are good.
Feb 22, 2015 | 2003 GMC Envoy
Dead battery
You have a random electrical short in the system and it is on the acc. side of your ignition system.Systems such as interior lights, glovebox light, brake lights, memory circuits for onboard computer, radio and some aftermarket components. Without me being able to see your car it is very hard to determine the cause. First determine that the battery is dead. Its possible that the battery cables have a bad connection, not at the battery but at the starter sol. or the battery cable ground connection on the engine. Clean these connections to see if you fixed it. If not then after that you will need to remove the poss. battery cable take a volt ohm meter and put the black lead to the poss. post of the battery and the red lead to the cable, set the meter to 10 amps BEFORE you hook it up. Then wate until all systems have timed out when this happens the needle will drop. If not then you have a direct short. If it does drop it should drop to less then 2 amps (that is normal) if it is above that you have a drain on the battery. Before you start this test make sure the key is out of the ign. then remove the interior light fuse that way you can open the doors without resetting the timers. Watch the meter and remove one fuse at a time, if the needle drops then that is the circuit that is giving you the trouble. Find out what that fuse controls and repair as needed. Hope this helps. Let everyone know if it did OK
Mar 04, 2013 | 2005 Chevrolet TrailBlazer
I have a cool start remote starter... on the remote starter the blue light goes on when i press the start button, unlock, or lock button....so i kno the battery isnt dead. but it just wont work. my freidn...
The starter need a lot more charge to crank the engine then lights, door lock and other auxiliary equipment. So it could be a battery. Try jump wire your car. If this does not help - check the starter relay in the relay box of engine compartment.
Jul 11, 2011 | Ford Taurus Cars & Trucks
I turned off the car and removed the key, then all of the dash lights began flashing and I heard a distinctive click, like the turn signal was on but it wasn't. The only way to get it to stop was to...
There is a very good possibility that the remote starter is causing your problem. You should have it check by the shop that installed it. If the shop stand behind there installs, you should not be charged. I would suggest that the remote starter ground wire be checked to ensure that it is not loose.
Nov 15, 2010 | Prestige Remote Start
2001 Corvette would not start, wouldn't even turn
From your symptoms, you are probably experiencing a bad starter relay, or bad starter. These are often intermittent problems, but can both cause it to act this way. The remote has nothing to do with it. I would start with the relay, and if not the relay, it's likely the solenoid portion of the starter. If it's the starter solenoid, then you may be able to take it apart and replace the contacts in it, which is usually where they go bad.
May 24, 2010 | 2001 Chevrolet Corvette
When it try's to start, my Jeep cranks 2 to 3
You have most likely installed the remote starter in the standard mode. You will need to follow the directions and hook up the tachometer wire and program the remote starter unit to start in the "tach" mode. That way it will continue cranking until the vehicle starts on your battery goes dead, whichever comes first.
Dec 16, 2009 | Remote Starter with Keyless Entry
F-150 Problem
load test the battery first/ next starter draw test its one or the other
Jul 07, 2008 | 1990 Ford F150
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
