Need a control board for an ac mod # m6y12f2a-e
Lennox ac stops working after normal shutoff untill i shut off power to air handler turn power back on ac runs till nornal temp reached shuts off will not come back on untill i kill power to air handler...
The 13HPX is a Heat Pump. It has a control board in the outside unit that will lock out after a few trips from one of the controls, such as a low or high pressure switch tripping. Turning the power off is making this board reset. Take the door off next time. to the outside unit and look at the lights on the control board. There should a sticker on the inside the door that you have to remove that describes why the unit is hard locking out according to the light configuration.
Oct 24, 2017 | Heating & Cooling
Carrier central AC/Heat system repeats "Replace
Try unplugging the unit and waiting a few which many times resets the board.
Aug 03, 2011 | Heating & Cooling
I have a Maytag M6Y12F2A-B air conditioner. The fan runs, but the compressor does not start. I believe I need to replace the capacitor. This happened last year, and at that time I found capacitors...
Hello, here is a link for parts for your ac http://www.appliancefactoryparts.com/aircleaners/climatrol/m6y12f2aay.html yes is sounds like either a bad capacitor or bad temp control switch. If you have a multimeter you can check if tje capacitor is bad by first discharging it with a insulated screwdriver ( put screwdriver across capacitor terminals ) tjen set the meter to microfarad range, if the microfarad number is lower than whats printed on the of the capacitor replace.
May 20, 2011 | Maytag M6Y12F2A Air Conditioner
The dometic roof ac humms when rv is on 110 ac unit was under warranty dometic sent a complete control board I changed control and stil have problem just like before. Dometic said one of the relays was...
not likely but possible. if they already had one bad board what's to say their production methods have changed since they made your last bad board. I have just had 6 bad compressors from this chinese company danfoss in one month! for only 2 freezers i have installed 3 bad compressors in each! nobody takes pride in production anymore they want the stuff to break.
Oct 10, 2009 | Dometic Rooftop RV Air Conditioner
Maytag M6Y12F2A Window AC Unit
The capacitor should have a MFD (or UF)rating. As long as you match these numbers you can use any brand. Try searching these numbers not the model of the unit.
Aug 26, 2009 | Maytag M6Y12F2A Air Conditioner
AC just shut off
clean both coils(fins)and drain non-detergent non additive oil(not motor car oil) for fan motor take cover off compressor relay and inspect wires(clean plugs and pins of oxide) you may need a hard start kit if it has a hard time startting
Aug 20, 2009 | Maytag M6Y12F2A Air Conditioner
Control panel for Maytag M6Y12F2A-E
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said you can't find a ccontrol panel for Maytag M6Y12F2A-E online to purchase.
Go to repair clinic .com which is a sponsor of fiya.site
Please remember to leave solved rating before you go!
Thank you
Sep 28, 2008 | Maytag M6Y12F2A Air Conditioner
Conrol panel box
May i ask where you bought your control box?
Jul 08, 2008 | Maytag M6Y12F2A Air Conditioner
EE problem
It could be the control board. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Jul 01, 2008 | Maytag M6Y12F2A Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
