Question about Toys
None of my lights want come on on my 94 crown vic the fuses are not blown
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 44 Answers
CHECK YOUR HEADLIGHT SWITCH OR A DIMMER SWITCH WILL CAUSE SAME PROBLEM AND CHECK RELAY MAKE SURE YOUR BATTERY TERMINAL'S ARE CLEAN BEFORE TRYING TO FIX ANY ELECTRICAL GOOD LUCK
Posted on Jul 14, 2013
  • jamison stewart Jul 14, 2013
    My car is not electrical
94 CROWN VIC/ OVERHEAD LIGHT WORKS SPORADICALLY
1) you must connect the switch in series, in tha way you will not have this problem, and you must add of course the relais, for to avoid the spark, and arching by load .Now you have connected in paralell.
God bless you
Jun 27, 2012 | Ford Crown Victoria Cars & Trucks
Fuse panel diagram 2006 crown vic
The diagram is part of the owners manual, you can access a free pdf copy HERE.
Jun 01, 2012 | Cars & Trucks
93 CROWN VIC. NO BRAKE OR TURN SIGNALS/HAZARDS
The fuse for these lights sound like it may be blown. Find you fuse panel, your owners manual will tell you exactly which one it is, sometimes it is printed on the panel cover. Replace with the same size fuse.
Jan 06, 2010 | 1993 Ford Crown Victoria
Rear and interior dashboard lights don't work 1994 Crown Vic.
Easy stuff first. Try replacing the #9 fuse on the interior fuse panel. This fuse protects the instrument panel, license, parking and tail light circuits. The panel is located under the dash to the left of the steering column. You will need to pry off the cover on the panel to access the fuses. The fuse you want is a 15 amp fuse located directly under the turn signal flasher. It should be easy to figure out which fuse it is because it will be 'blown' or open. This is easy to determine just by looking at the fuse once it's removed. And, if you aren't sure what's what, I'm sure you can find a diagram of this fuse panel somewhere on the Internets if you look around a little. I took this info out of the Owner Manual from my own '94 Vic. If this doesn't solve the problem I would suggest taking your Vic to a shop and letting them take a look at it.
Dec 19, 2009 | 1994 Ford Crown Victoria
94 crown vic how do i find out if car has keyless entry
Easy. Does your Vic have a five number keypad above the driver's side exterior door handle? If so the you got key-less. If not, you do not.
Jun 13, 2009 | 1994 Ford Crown Victoria
94 crown vic remote start??
you will not need anything else. If your not planning on doing it yourself than you will need to bring it to a shop to have it put in. This car is pretty system install. You can obtain a wiring diagram for it and put it in yourself. But if not you will not need anything else for this vehicle
Feb 20, 2009 | Valet 561T Remote Start Module
'94 Ford Crown Vic Headlights
They are changed from within the engine compartment... at the rear of the headlight bazels... if it's the side on the battery you may have to remove it.... also don't touch the bulbs with your fingers as that shortens the life of them.
Robert
Jan 17, 2009 | 1994 Ford Crown Victoria
Toys Logo
43 people viewed this question
Top Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
