Question about AEG Santo 7085 KG Side by Side Refrigerator
Broken water pipe that feeds the cold water outlet
Good day The water pipe at the bottom of the door that supply cold water to to the cold water outlet is broken and is leaking water when you want to fill a glass with water. Can someone please explain to me on what to do to reair it?
2 Suggested Answers
SOURCE: broken glass AEG hob
If it is just the edge of the corner glass not a lot you can do if it is broken nearer the inside be very careful as the weight of pans can cause the break to spread.Check serial no. on base of hob body the first 2 digits are the year and 3rd digit is weeks in year.For example 92800055 that would be 2009 and 28th week equals july 2009.Any AEG unit has 2years full warranty.Check and you might be able to claim new glass.Hope this helped.
Posted on May 07, 2010
Hot water barely comes out,
If you switched the feed hoses over and the problem reversed itself, cold has gone from fast to slow useing the hot water pipe and hot from slow to fast useing the cold water pipe then this would indicate a fault in the water supply from the hot pipe. What sort of pressure is coming from the hot pipe when not connected to the machine but filling in to a bucket? Are there any shut off valves before the pipe that supplies the hot water? Are they fully turned on? Any kinks in the feed pipe for the hot water? Has the hot water feed pipe collapsed internally? Change the pipe to check this and not just at the machine side.
Dec 31, 2012 | GE Spacemaker Washer and Dryer Electric...
Plumbing in water supply to fridge.
if this is for ice maker this is how its done. run the line through the floor in back of fridge to a cold water pipe. closest to where fridge sits.
  • Turn off the cold water supply to the pipes.
  • Attach a pipe clamp to the cold water pipe.
  • Screw a packing nut into the cold water pipe. Turn the packing nut until it punctures and taps into the pipe. Attach ΒΌ-inch copper tubing to the outlet valve on the packing nut using a compression nut. Make certain the valve is closed before you secure the packing nut.
  • Attach the copper tubing to the intake connection using a compression nut. to back of fridge,
  • Turn on the cold water supply.
  • Turn on the outlet valve on the packing nut.
  • the kit should have directions with it. good-day !
    Aug 20, 2011 | Microwave Ovens
    Does the wma76 hotpoint need a hot water feed? Is a cold water feed enough?
    Hi from retired Englishman in France (it's 21:29!),
    If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
    All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
    If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
    The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
    Hope this answers your question.
    John C
    Jan 26, 2011 | Hotpoint WMA76 Front Load Washer
    How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
    Tanks are marked with Hot and Cold.
    1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
    2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
    3) If hot and cold are reversed, the tank will not work.
    Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
    Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
    Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
    Does it run on hot or cold feed? only have one water inlet, second hand good condition but only red pipe feed with it do i need a blue cold feed?
    If it only has the one valve, then it must be connected to the cold supplky, it does not matter what colour the hose is, as long as it is connected to the cold water supply.
    Nov 04, 2010 | Bosch Exxcel WFO 2465 Front Load Washer
    How do I install a second hand waher/dryer with limited piping?
    1 yes all standard.2 Yes you can get a Y piece. 3 no you will only use water from cold. But you can solve that by going to a good hardware store or B.Q and gettein a self cutting tap for washing machines. You can fit this in just minutes, and do not even need to turn off the water supply. just make sure there is a clean straight piece of pipe to fit it to. 4 yes fit waste pipe to u bend under sink.
    Feb 04, 2010 | Washing Machines
    GE Dishwasher no water upon start, humming, blinking lights
    Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
    Jan 18, 2010 | Dishwashers
    Front load washer will not fill with cold water and will just stop at the rinse cycle and buzz
    Check your inlet pipe on cold water supply, When you dissconnect look inside where pipe fits onto machine you will see a small filter, if it is blocked take it out with great care and clean. always replace it. if your water supply is ok and filter is clear then it will be a faulty water valve. Good luck and feel free to give feed back ok.
    John
    Sep 03, 2009 | Kenmore Washing Machines
    Cold water or cold & hot water connection?
    If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
    Apr 11, 2009 | Bosch Washing Machines
    AEG Santo 7085 KG Side by Side Refrigerator Logo
    Top AEG Refrigerators Experts
    Oscar Netto
    Oscar Netto
    ashburton
    Jim Goldsmith
    Jim Goldsmith
    Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
