Question about Bosch AHS 41 ACCU Cordless Hedge Trimmer
Bosch ahs 41 accu trimeer. 2 years old. stopped working, no power getting through from batteries which I know to be charged. Is it:a a fuse somewhere or b motor is blown ?
  • 98 Answers
SOURCE: One year old Bosch dishwasher stop wrking.will not
Start with the basics: Check the status of the breaker and the electrical connections under the toe kick panel. If the unitis getting power, You may want to call the dishwasher helpline to see if it is a recalled model. A free replacement of the control panel circuit board is available for many of these, but if the power switch is the culprit, you will need to buy a replacement button.
I have written a guide to help with drainage issues. The helpline number is near the top. It is here. Thanks!
Posted on Jul 19, 2009
projdoc
  • 2237 Answers
SOURCE: Bosch Fridge Freezer (about 12 years old) has
the main board is most likely bad.
Posted on Nov 13, 2009
stug_57u
  • 99 Answers
SOURCE: The switch only works on about every 10th try
This sounds like an open circuit problem.First thing first, check all connections that you can in the plug and switch area. If they are all good and tight I would suggest that you may have an internal break in the power supply cord. This normally happens near the plug or handle, unless the cable is on the floor and liable to be trodden on. The quick way to check this is to plug tha machine in and lock the switch in the on position. Now CAREFULLY wiggle the cable along its length starting from the machine end and working your way towards the plug. If this causes the machine to turn on and off you can try and pin point the break. Then unplug and cut the cable back to that point and rewire.
Also, make and model number might help and I can check if there are any common problems. Is it Bosch as pictured, as they are good machines and rarely have problems other than wear and tear.
Posted on Dec 01, 2009
Testimonial: "Good suggestion as a first test of the problem."
Macmarkus
  • 2605 Answers
SOURCE: bosch dw shu043 dishwasher stopped working in middle of cycle
Hi and welcome to Fixya. Based on your post, I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line. Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair. This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat & cool, become loose from normal operating vibrations and burn up from all the added heat caused by "resistance". The end result is no power to the controls. Check it out and post back what you find. Thanks for visiting "fixya" and please take a moment to rate the solution/suggestion provided here for you. Good luck. Macmarkus :)
Posted on May 21, 2010
  • 2509 Answers
SOURCE: Bosch washing machine model WFF1401GB/01, 10 years
Check the motor control board for dry joints, poor contact, signs of excessive heat around plugs/pins
I would try new brushes again or thoroughly inspect whether they are contacting the commutator.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Mar 01, 2011
Mastercool accu-charge 2 scale
Are the terminals where battey connects clean if not they wont make the connection
Jun 01, 2016 | Mastercool MSC98210A AccuCharge II...
Can I put higher Ah batteries in my Shoprider Streamer?
Absolutely. Let me explain what "Ah" means. "Ah" stands for Amp Hours. A 32ah battery will run a 1 amp motor for 32 hours...or a 32 amp motor for one hour...a 16 amp motor for two hours etc.. As long as the battery voltage is the same it's absolutely fine. As long as your chargers are the correct voltage, they'll be fine as well. So basically, the higher the "Ah", the longer the battery will last. This is why higher "Ah" batteries are more expensive. Hope this helps : )
Jun 09, 2014 | Shoprider Streamer Sport Power Chair
Bosch cordless drill not working.
First The model is pretty new. you need to register your tool on line. this takes you from a one year warranty to a three year warranty. They will give you a pro-vantage number. with that said it sounds like a trigger switch. Yhe trigger switch is the brain of your tool. not only does it do your variable speed but it also controlls the brake and your fuel gauge. Because of the cost I highly recomend taking it to your closes Bosch service center.
Oct 13, 2012 | Bosch Cordless Impact Driver, 18V, 1/4 Dr,...
I have got an 18 volt 3.0 ah impact driver from hitachi its about 2 years old but the batterys don't hold charge over night
Batteries require replacement. It has lost its holding ability. You can try replacing the batteries as the charge holding capacity is lost as per your statement.
Oct 04, 2010 | Hitachi 51F500 51" Rear Projection...
Does the battery need charging for first use of machine. Bosch AHS 52 ACCU hedge trimmer.
Hi Mary, most of the time they do, plug it into charge and leave it over night.
Aug 11, 2010 | Garden
No power
Dead battery; blown main fuse. How old is the battery? How often has it been properly charged (idling does not charge the battery)? If the battery is a couple years old you can take it to a battery shop to have it charged/tested. If you know it is a new, charged battery then you need to track down through the wiring diagram as to why current is not flowing.
Feb 24, 2009 | 1996 Yamaha Royal Star XVZ 1300 A
Bosch AHS 41 ACCU Cordless Hedge Trimmer Logo
179 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
