Question about Cavalry Storage CAUM3701T0 1 TB USB 2.0 Hard Drive
Cavalry ExHD powers on but doesn't light up or connect to laptop.
Laptop Info: Windows 7, Dell Inspiron 1764 I've had a Cavalry 1TB ExHD for years and never had a problem with it. Usually only use it to put large files on for long term storage. But now when I turn it on, I can hear and feel it start up (disk is turning), but 1) the blue light that illuminates the logo doesn't appear and 2) I can't get it to connect to my laptop (never see it pop up as a connected usb device or under my computer in explorer display. Would really like some help on what the problem is and hopefully some way to fix it (or at least get it working long enough to transfer data to another ExHD if I have to get one). Thanks.
5 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: The front light changed from blue to red and now
http://www.fixya.com/support/r4247716-usb_device
Check ther for most of the simple and common fixes
Bob
Posted on Jul 18, 2010
lock123
  • 6831 Answers
SOURCE: Hard Disk won't connect to my computer
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
  • 1768 Answers
SOURCE: I recently purchased a new Cavalry external hard
1. This could be due to several things.
a. The power supply for the external drive is not working properly
b. A broken power supply connector.
c. The USB drive was disconnected improperly > that is not disconnected safely in Windows
d. The external drive controller in the USB case is defective. A new case is needed.
Posted on Mar 18, 2011
djbr1ck
  • 158 Answers
SOURCE: My Cavalry 1TB hard drive
The HDD is probably in working condition, however the enclosure may be damaged. You can remove the hdd inside the cavalry storage enclosure, and if you have a desktop install it in the desktop to get your data off of it. You may instead wish to purchase a new hdd enclosure which can be bought online from many websites such as http://ncix.com or newegg.com
Posted on May 11, 2011
Find a windows 7 driver or a windows 7 replacement modem
Robert,
Unfortunately, Dell does not have Windows 7 drivers available for download for the Inspiron 9100. You can click the link below to download the online service manual for steps removing and replacing the modem in your computer.
Inspiron 9100 Manuals
http://dell.to/1KXJsjK
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 17, 2015 | Dell Bcm94154m Dell/inspiron 56k Mdc Modem...
Dell Inspiron 6400 doesn't boot past dell splash
The hard drive has failed, or windows 7 is not compatable with the laptop. Try installing vista, if this works! there is a problem with windows 7, no change! have the hardware checked for possible replacement.
Jul 01, 2012 | Dell Inspiron 6400 Notebook
Unlock the mouse in dell inspiron m5030
1) Examine your "Function"/"F" keys and look for a touchpad icon. If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad. Move on to Step 2 if your laptop doesn't support this feature.
  • 2) Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button. Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results.
  • 3) Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable." Your touchpad is now unlocked.
  • Feb 06, 2012 | Dell Inspiron M5030 Laptop
    I have a Dell inspiron 5100. When I try to turn it on, it just stays blank. It shows the Dell and Windows logos, but the screen where I'm supposed to choose my user account doesn't appear.
    Are there any error messages displayed? Does the laptop switch off, or does it still remain on? (are lights etc. on?). Also, have you connected to an external monitor recently? I suggest attempting to connect to a monitor or TV using the S-Video or VGA connectors on your laptop, this should get the login screen to show up.
    Jul 05, 2011 | Dell Computers & Internet
    My Cavalry 1TB hard drive stopped working the 3rd day after i bought it. It powers on, you can hear it working, but the computer won't recognize it. I can't initialize it through Diskpart or Disk...
    May 11, 2011 | Cavalry Storage CAUM3701T0 1 TB USB 2.0...
    I ve reinstalle windows 7 recently in my dell inspiron 1545 laptop with windows vista home premium. i ve installed the driver softwares too. but now i ve to double press the eject botton on the keypad to...
    It sounds to me to be a software problem and not a hardware problem. What you will want to do is go to the following dell support website and download updated QuickSet application.
    The link is http://support.dell.com/support/downloads/driverslist.aspx?os=W764&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=STUDIO1737&hidos=WLH&hidlang=en&TabIndex=&scanSupported=True&scanConsent=False
    You may also want to check and see what version of Bios you have and update. They release a new version last month.
    Thanks and hope this helps.
    May 09, 2011 | Dell Studio 1737 Laptop
    I recently purchased a new Cavalry external hard drive (500gb, CAUG25500), and had been using it on my Thinkpad laptop with XP. It was working fine, no problems. Before a trip I was going on, I wanted to...
    Mar 16, 2011 | Cavalry Storage Cavalry CAUG 500GB USB 2.0...
    My Cavalry 1TB USB 2.0 external hard drive will not connect to my computer. I have not had it for long, possibly 2 months. It worked fine all day today but tonight the blue light does not turn on. It...
    Hey Jeff,
    Sounds like this is something with info you need to keep..Keeping/securing/BACKING UP your data is your priority!! Personally, I would find a QUALITY (ASK a lot of questions.. can they guarantee their work,,- and NOT LOSE your data..!!) .. skip the geek squad - .. computer repair shop..(or some 10 year old).. I would first see if they could copy this drive to another drive (solid state) so you will not lose your data... we are at 4.0 with USB now... 2.0 is becoming the "floppy" of today..I have 3.0 drives and feel left out.. again.. securing/copying/backing up your data is paramount.. Good luck,,,
    Sep 08, 2017 | Cavalry Storage Cavalry CADB001U32 1TB...
    Cavalry Storage CAUM3701T0 1 TB USB 2.0 Hard Drive Logo
    51 people viewed this question
    Top Cavalry Storage Computers & Internet Experts
    Arora Singh
    Arora Singh
    gary433
    Glenn Smart
    Glenn Smart
    Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
