Question about Compaq Presario CQ62-112TU
Ac keeps shutting
Everytime i plug in the charger, my laptop shuts down, could someone explain why it does this, and some solution on how to fix it, thx
  • 40 Answers
Remove the battery and plug in the AC adapter. If you can not power on the laptop, your AC adapter has gone bad on you and will need to be replaced.
If it will turn on with the AC adapter, place the battery while the laptop is on. See if it registers the battery as charging in the task bar. If not, there may be something wrong with the battery or the components connecting to the battery within the laptop.
Also you can below steps to check:
1) take the battery out of your laptop and the laptop charger
2) plug your laptop charger in your laptop without the battery in it,
3) Try to turn it on the normal way:
If it turns on, then your battery has gone, (Its drained and run out of use like all batteries do)
if it stays off then its a charger problem
You would want to hope its a charger problem as they are cheap and easily replaceable
Hope i helped
I guess its a charger problem because its not turning on and the laptop automatically would use the charger as a main power supply if the battery doesn't work
and oh by the way
If the battery isn't in it, your laptop will act as a pc whereas if you plug the charger in it will work, but if you take it out while the laptop is on then it will go off instantly without a successful shutdown which could mean a loss of work
Regards,
Rahul
Posted on Jul 14, 2013
4 Suggested Answers
SOURCE: my laptop as randomly started shutting down on its
Put you Vista DVD in the drive & boot off of DVD, and when you see the menu select Startup repair... leave it go on through it's process and reboot when told , this should repair your startup issue, otherwise get back to me.
Posted on Feb 18, 2010
  • 214 Answers
SOURCE: I found a trojan and
I propose two solutions :-
1) Just format your machine once and install the OS again. Observe if it is behaving same.
2) If yes then you need to replace your Cooling FAN.
With regards
FIXYA team
Posted on Oct 08, 2010
  • 37 Answers
SOURCE: How to stop a compaq cq60 laptop from shutting off due to overheating?
Some tips:
  • Use a "laptop cooling pad",search on Amazon, you will find many of them
  • Use the laptop on hard surfaces, not a sofa or bed cover, etc.
  • Use compressed air to blow dust out of the fan area (I would do this when the laptop is turned off).
  • Check if the laptop is under warranty and have it serviced. Warranty can be from the manufacturer, the store where you bought it. You credit card may have doubled your warranty.
  • Install the "core temp" program to monitor your laptop's temperature, and alert you when it gets too high. Then you can learn when it is going to shut down.
  • You may be able to run the laptop in a lower power setting, which could reduce the amount of heat generated. This will be under "Power Options" in the Control Panel.
Source: http://www.techsupportforum.com/forums/f108/hp-compaq-shutting-down-due-to-overheating-559606.html
Posted on Feb 12, 2012
Acer aspire switch 10 e, keeps shutting off randomly even when ac charger is being used
Is the airway clear to allow for good cooling? Bad connection on the RAM or HDD socket?
Aug 28, 2016 | Acer Aspire Computers & Internet
Plugged in, NOT Charging!
If new then it's defective. Return that bad boy.
Feb 14, 2015 | Computers & Internet
My computer shuts down when i plug in the charger
Assuming this AC laptop charger functioned correctly at one time. Several Possibilities: (1) laptop charger has failed ... connect another compatible charger to your computer to test for this; (2) or the battery has failed ... remove battery and test if the charger plugged in directly powers the laptop.
Apr 07, 2013 | Targus APA30US AC Laptop Charger AC...
Laptopp plugged in not charging
What's your OS? Someone claimed to have resolved this problem following the steps below:Shut down Computer. unplug AC. Take out battery. Plug in AC. Start up computer. Disable Microsoft ACPI CC Method Battery Shut down computer. Unplug AC. Insert battery. Plug in AC. Turn on. Enable Microsoft ACPI.
Then it was working.
Original post:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/gateway-laptop-plugged-in-not-charging/6db4fe50-d318-44da-a938-2fc58f4bbe7b
Of course, there were some different voice on this post. Have a read, and may this help.
Nov 20, 2011 | Computers & Internet
I have a compaq presario c700em it keeps shutting down even when: The battery and charger are both plugged in The battery is plugged in by itself The charger is plugged in by itself
are you looking at youtube or a video at the time it shuts down, it might be a over heating problem and i would get the laptop cleaned out and see how you get on after that.
Oct 05, 2010 | Computers & Internet
My dell inspiron 1525 notebook keeps shutting down everytime
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 23, 2010 | Dell Inspiron 1525 Notebook
I have a problem with my laptop toshiba a305-S6825, everytime i plug in the ac charger the laptop shuts down and reboot. I can only use the battery. I have to shut down the laptop everytime so i can charge...
try to press start button and then search for device manger then click on the battery and find out its condition wither it needs to be replaced or it may some programmes need to update by pressing trouble shoot
Sep 14, 2010 | Toshiba Satellite A305-S6845 Notebook
Computers & Internet Logo
60 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
