Question about Locks & Locksmithing
Kwikset 6wal how do you remove inside knob - Locks & Locksmithing
3 Suggested Answers
  • 8404 Answers
SOURCE: how to remove a tumbler from kwikset entry knob ?
You need a kwikset removal tool. Search kwik set core removal tool to take you to a lock smith supply, or try to buy one locally.
Notice, purchase of this tool may not be legal in your juresdiction and MIGHT be considered burgary tools.
Posted on Dec 27, 2009
  • 207 Answers
SOURCE: The inside door knob came off of the Kwikset keyed
There is probably a small set screw (hex head) on the bottom of the knob. If that doesn't work try just pushing it back on.
Posted on Jun 06, 2011
Kwikset lockset does not lock
The shaft for the lock fits in the knob. The lock on the knob might be 90 or 180 degrees out of rotation. Please remove the know and twist the lock 1/4 turn and put it back together. Also you may need to reset the location with a key and when the lock knob is off, turn the lock set with the key, then turn it and replace the knob.
Mar 01, 2018 | Kwikset Locks & Locksmithing
Door knob replacement
On the inside side of the door knob you should be able to use a screwdriver to remove the finish covering against the door. This should get you to a point where you can release everything.
Nov 14, 2013 | Kwikset Locks & Locksmithing
I have an exterior screwless doorknob that I need to remove. The faceplate on the inside knob that covers the screws is also covering the little pin that removes the knob. Is there another way to remove...
There is the 3rd version of the Kwikset exterior door set. The interior face plate is removed and on each side of the base plate has small slots with a lever on either side that need to be moved to the other end of the slot. The whole interior knob assembly with come off.
Dec 23, 2011 | Kwikset Locks & Locksmithing
I have 3 door knobs on outside doors that are loose and need to be tightened. the knobs have come completely off sometimes when we go out the doors. how do I tighten the knobs so they are not loose?
On the inside side of the door knob, there is a decorative plate. Depending on which model door knobs you have, it is held on with a "set-screw" that might require an allen-wrench (looks like an 8-sided tool; usually in an L-shape), or just simply a screw driver, to loosen and remove it. Once you take the decorative plate off, there will be two very obvious screws that hold both sides (inside and outside) of the door knob together. Tighten these screws to tighten your knobs, then put the decorative plates back on again.
Feb 27, 2011 | Kwikset Professional Door Lock...
The inside door knob came off of the Kwikset keyed door lock. How do I re-attach the knob?
Feb 24, 2011 | Hardware & Accessories
How to remove a tumbler from kwikset entry knob ?
Dec 23, 2009 | Kwikset Professional Door Lock...
Door lock is loose
Inside plate arond the base of the knob needs to pop off.
Try removing the knob from the inside. Look for a place the push in with a flat head screwdriver. A release point is there some where.
After the knob is off the plate should come off and reveal the screws.
Mar 30, 2009 | Kwikset Professional Door Lock...
Need to remove the inside door knob from an entry set
These locks have a factory lubricate and should not need any extra during lifetime. If lock is malfunctioning may need to do other adjustments ei.. loosen throw bolt screws a bit. It is ok to spray lube into key slot for key.
Thank you.
Mar 19, 2009 | Schlage Locks & Locksmithing
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
61 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
