Question about Refrigerators
Avanti 18cyc/yw/yb refrigerator
I use this small refrigerator in the summer and unplug it in the winter months this summer it would not come on. The cord and wall outlet are fine . what else can I check?
  • limb_larry
    limb_larry Jul 16, 2013
    It does not make any noise when you plug or unplug it.It worked fine 6 months ago.
5 Suggested Answers
22yooper
  • 828 Answers
SOURCE: Refrigerator won't work after winter shut down at camp
This is a problem we frequently run into in a situation such as yours. Refrigerators are meant to be used in continuous operation. Using them seasonally will let the high side condenser tubing, internal to most cabinets, rust through and loose the refrigerant charge.
Posted on May 03, 2008
prawinmv22
  • 106 Answers
SOURCE: I have a Kenmore refrigerator. The freezer works,
hi,,
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting.the refrigerator then cools properly
rate me...
Posted on Jun 16, 2009
  • 340 Answers
SOURCE: Avanti refrigerator not cooling
thermostat set ? might not be defrosting all the way. damper actuator not opening from freezer to refrigerator. is the condenser clean?
Posted on Jun 17, 2009
aasc
  • 1606 Answers
SOURCE: On my 106.55244400 refrigerator, does the cord to
If you remove the 3 screws holding the ice maker to the wall , and you do not see a plug at the rear , then unplug the refrig . Remove the ice maker cover ( it just snaps off ) . Where the line connects to on the ice maker , you will see a small square hole with a " flap " which has to be depressed , and the wiring will slide out , after unclipping the black fuse piece , from the mold .
Posted on Nov 15, 2009
What weight oil to use in the summer in a 2003 pontiac grand am
heavier oils are fine in warm summer months, 10W30 or 10W40-
all cars ran on these oils summer or winter for years. Newer vehicles are designed for 5W oils and you should use a 5W oil for them in the winter months
Jul 15, 2016 | Pontiac Cars & Trucks
I have an Avanti 1.7 cu ft superconducting mini-refrigerator. it was accidentally unplugged all night, and this morning it keeps emanating a recurring low volume high pitched "beep." It's almost inaudible...
some thing caused a failure of the compressor area, loud noise is air or freon blown out through small hole in the service lines, i do not know if they are worth fixing because they around 100 dollars
Feb 20, 2015 | Avanti Refrigerators
Pontiac engine codes
1964 - 1979 Pontiac Engine Codes Bold Type is for manual transmissionStarting in '73,2nd HP # is for Dual Exhaust 1964 326 250 HP 92x,96-0 326 280 HP 94x,97-0 389 230 HP 04L,05L,08R,09R 389 235 HP 22B 389 267 HP 389 283 HP 10A 389 303 HP 25K,26K,27P,28P 389 306 23B,29N 389 325 78X,79J 389 330 32B,34N,33-6 389 348 76X,77J 421 320 35B,38S,43N 421 350 44B,47S,49N 1965 326 250 WP,ZN 326 285 WR,YP 389 256 WA,WB,YA,YB 389 290 WC,YC,YD 389 325 YE,YF 389 333 WE 389 335 WT,YS 389 338 WF,YG 389 360 WS,YR 421 338 HP WG,YH 421 356 WH,YJ 421 376 WJ,YK 1966 326 250 WP,WX,YN,XF 326 285 WR,YP,XG 389 256 WA,WB,YA 389 290 WC,YV,YU,YC,YD 389 325 YX,YL,YW,YF,YE 389 333 WE 389 335 WW,WT,YS,XE 389 360 WV,WS,XS,YR 1967 326 250 HP WP,WX,WC,WH 326 250 HP YO,YN,XF,YJ,XI 326 285 HP WR,XR,WK,WD 326 285 HP YP,XG,YM,XO 400 255 HP XL,XM 400 260 HP 400 265 HP WA,WB 400 265 HP YA,YB,YC,YD 400 290 HP XV,XU 400 293 HP XC 400 325 HP WU,WZ,WQ,WI 400 325 HP YE,YF,YT,XE,XN,XW,XX 400 333 HP WD,WE,WY,XT 400 335 HP WT,WW,YS 400 350 HP XZ,XY,XH,XJ 400 360 HP WS,WV,WR,XS,YZ,XP 428 360 HP WG,Y2,YY 428 376 HP WJ,XK,Y3,YH,Yk 1968 350 265 HP WD,WC,YN,YJ 350 320 HP WR,WK,YP,YM 400 265 HP XM,YA 400 290 HP WA,WB,YC 400 330 HP 400 335 HP WQ,WZ,WI,XN 400 340 HP WU,XT 400 350 HP XZ,XH,YS,YZ 400 360 HP WT,WS,XS,XP 400 366 HP WY,XW 428 375 HP WG,YH 428 390 HP WJ,YK 1969 350 265 HP WC,WP,WM,WU 350 265 HP XL,YJ,XR,YN,XB,YE,YU,XS 350 325 HP WK,WN,XC,XD 350 330 HP WR,WV,XT,XU,YP 400 265 HP XM,YZ,XX,YB,YF 400 290 HP WA,WB,WD,WE,YC,YD 400 330 HP WZ,YT 400 335 HP WQ,YW 400 340 HP 400 345 HP WH,XN 400 350 HP WT,WX,YS,XH 400 366 HP WS,YZ 400 370 HP WW,XP 400 375 HP WI,WY,XY,XW 428 360 HP WG,YL,YH,XE,XJ 428 370 HP WF,XF 428 390 HP WJ,WL,YK,XG 1970 350 255 HP W7,WU,X7,YU 400 265 HP 400 290 HP WE,YD 400 330 HP 400 350 HP WX,WT,XH,YS 400 366 WS,YZ 400 370 WW,WH,XP,XN 455 360 HP WA,YC,YH 455 370 HP WG,XF 1971 350 250 HP WR,WU,WN,WP 350 250 HP XR,YU,YN,YP 400 265 HP WS,WX,XX,YX 400 300 HP WK,WT,YS 455 280 HP WG,YG 455 325 HP WJ,YC 455 335 HP WL,WC,YE 1972 350 160 HP WR,YU,YV,YR 400 200 HP YX,YZ,ZR,ZV,ZX 400 250 HP WK,WS,YS,YT,ZS 455 200 HP 455 220 HP YA,YC,Y4 455 300 WD,WM,YB,YE 1973 350 150,175 HP XR,WV,ZB,ZD 350 150,175 HP Y2,Y7,YR,YV,ZR,ZV 350 150,175 HP WA,WC,WD,WF,WL,WN,XZ 400 170,185 HP W5,XH,XI,X3,X4 400 170,185 HP YI,YP,YX,YZ,Y4,ZK,ZX 400 200,230 HP WK,WS,WP,YN,YX,YT 400 200,230 HP Y3,ZN,ZS,XK,XN,XX 400 200,230 HP XZ,X5,YF,YG,Y6 455 215,250 HP WT,WW,ZZ,ZE,YA,YC 455 215,250 HP YD,YK,ZA,AC,XA,XE,XJ 455 215,250 HP XL,XY,XT,X7,XO,YE 455 290 ZJ,XD 455 310 Z8,X8 1974 350 155,170 HP WA,WB,AA,YA,ZA 350 155,170 HP YB,YC,ZB,YN,YP,YS 350 170,200 HP WN,WP,ZP,YN,YP,YS 400 175,190 HP AH,YH,YJ,ZH,ZJ 400 175,190 HP AD,YF,YK,ZD,ZK 400 200,225 HP WT,WR,Y3,AT,YT 400 200,225 HP YZ,ZT,AD,YL,YM,ZS 455 215,250 HP AU,YR,YU,YW,YX 455 215,250 HP YY,ZU,ZW,ZX,A4 455 215,250 HP 455 290 HP W8,Y8 1975 350 155 HP YB,YA 350 175 HP WN,YN,ZP 400 170 HP 400 185 HP WT,YS,YT,ZT,YM 455 200 HP WX,YU,YW,ZU,ZW 1976 350 160 HP (Early) YB,YA,YP,YR,ZX 350 160 HP (Late) XM,XP,XU,XR,XW,XX,X3,ZF,ZH 350 165 HP 400 170 HP (Early) YJ,YC 400 170 HP (Late) X9,X4,XT,XY,XS,XZ,X8 400 185 HP (Early) WT,Y6,Y7,YS,YT,YY,YZ,ZA,ZK 400 185 HP (Late) WY,X7,ZJ,ZL,X6 455 200 HP WX,Y3,Y4,Z3,Z4,Y8,ZB 1977 301 135 HP WB,YW,YX,YH,YK 350 170 HP YA,YB,XB,XC,Y9 400 180 HP 400 180 HP YU,Y4,XA,Y7,XK 400 200 HP WA,Y6 1978 301 140 HP XA,XC,XL,YM 301 140 HP XD,XB,YL,YP 301 150 HP XF,XH,XU,XW 400 180 HP XJ,XK,X9,YK,YH,YS 400 180 HP YT,YJ,YR,YW,YA,YU 400 220 HP WC,X7 1979 301 135 HP PX7,PX9,PXF 301 135 HP PXH,PXP,PXR 301 150 HP PWA,PWB 301 150 HP PX4,PX6,PXL,PXN 301 150 HP PXS,PXT,PXU,PXW 400 220 HP PWH,LAST 400
Dec 21, 2013 | Cars & Trucks
I have a small Avanti refrigerator which I unplugged for about 3 months. When I plugged it back in it does not run or make any kind of noise. The model no. is 18CYC/YW/YB.
Possible that the starter is dirty not working. You can find this on the side of the compressor unit. Remove the mains power and check the wiring to the fridge, check the circuit as normally shown on the backside of the fridge. You can find the circuit breaker/starter, remove and clean
Sep 26, 2013 | Frigidaire GLTF2940ES Front Load Washer
Does dehuidifiers stop working as hard in the winter months then in the summer months. Because my water bucket has not fill up since gotten cold. I live is Alexandria Va and it is winter here.
Generally speaking there is more moisture in the air during the summer months. As the humidity goes down in the winter your dehumidifier will not collect as much water because there is less moisture in the air.
Dec 28, 2010 | Haier DM30EAL Dehumidifier
My frig. in the garage.. The freezer works great in summer months but in winter months it doesn't. Why is that?
Good day,
That is normal. The thermostat that runs the whole machine is located in the refrigerator compartment.
When it reaches normal temperature, it shuts off. In winter months that may mean as long as 12 hours or more. Thus not enough running time per day to keep the freezer near it's normal temperature.
Engineers design domestic refrigerators to be in an area comfortable to humans. Normally 70 degrees or higher. Thus your problem.
The only solution is to bring the machine inside.
Sorry.
Thank you for using FixYa
Dec 29, 2009 | Refrigerators
Freezer doesn't freeze in winter?
Domestic refrigerators nowadays are designed not to operate at temperatures less than 45 degrees. First, if it's 45 degrees in the house, people probably are not living there. 2nd, 45 degrees keeps food refrigerated. 3, if people are not living in a space, then they don't need to keep frozen food.
This is a result of the changes in refrigerants we've been going through since 1992.
If you want an outdoor freezer, buy one, and make sure it's designed to be used in a non conditioned space.
Jan 26, 2009 | Frigidaire FRS23KF7AB Side by Side...
Avanti Wine Refrigeraator
thanks for the question i think the problem is that its under the counter no air flow to cool the coils try it not under counter thanks the appliance doc
Sep 24, 2008 | Danby DWC283BLS Wine Cooler
May 03, 2008 | Kenmore 73503 Stainless Steel Bottom...
May Tag Dishwasher
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07094.html
I think you should review this webpageThere have been over 2 million maytag dishwasher recalls due to them being a fire hazard. The chart below came from the site and Im not sure what your serial number is but your model number is on there.
Brand Model numbers MUST
begin with… AND serial numbers MUST end
with… Maytag® MDB3, MDB4, MDB5,
MDB6, MDB7, MDB8,
MDB9, MDBD, MDC3,
MDC4, MDC5, DWU9 SM, SQ, SS, SU, SW, SY, SZ, UB,
UD, UF, UH, UK, UM, UQ, US, UU,
UW, UY, UZ, WB, WD, WF, WH, WK,
WM, WQ, WS, WU, WW, WY, WZ,
YB, YD, YF, YH, YK, YM, YQ, YS, YU,
YW, YY, YZ Jenn-Air® JDB3, JDB4, JDB5,
JDB6, JDB7 UB, UD, UF, UH, UK, UM, UQ, US,
UU, UW, UY, UZ, WB, WD, WF, WH,
WK, WM, WQ, WS, WU, WW, WY,
WZ, YB, YD, YF, YH, YK, YM, YQ,
YS, YU, YW, YY, YZ
Mar 30, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
