Question about Kitchen Ranges
Where to buy turboair cooker hood gr01n -nv - Kitchen Ranges
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
I need to buy a fan ..where can i get parts?
Hi lisa,
There are loads of online retailers, such as ourselves, who supply a huge selection of spares for cooker hoods. Hope that you'll have a look at our site. Here is the link to all our cooker hood spares.
Cheers,
eSpares
Mar 03, 2010 | TecnoWind isola d3 Stainless Steel Kitchen...
Where can i buy new Baumatic 7.3 GL cooker hood halogen lights at a good price
FIRST TURN OFF THE POWER TO THE HOOD UNIT THEN LOCATE THE BULBS AND REMOVE TAKE THEM TO THE LOCAL DIY STORE TO FIND REPLACEMENTS IF NOT FOUND THERE YOU CAN GO TO AN ELECTRICAL AND PLUMMERS SUPPLY STORE , GOOD HUNTING.
Nov 17, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
Cooker hood
Look around on the hood and cooker for a small fuse. If you find one, replace it with one of the same type and rating.
Apr 16, 2009 | General Electric Stove/Oven/Range Chrome...
Am buying a Bosch cooker hood - does it come with filters?
filters required only if you are venting inside your house (ie recirculating the air), if it is going outside, then you don't need them.
Jul 26, 2008 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Turboair taw-12 missing grate
Try one of these supply companies, they've only failed me a couple of times.
http://www.wilmar.com/
CENTURY Maintenance Supply , 1-800-880-3416
Johnstone Supply, 1-800-493-4822
Maintenance Warehouse 1-800-431-3000
That should get you started. Hope it helps.
Dec 10, 2007 | Turboair TAW-12 Air Conditioner
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
Oct 17, 2007 | Kitchen Ranges
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
