Indesit w160 Can't get the door open after a wash.
kjmac
  • 97 Answers
SOURCE: Indesit WE14UK front loading washing machine door locked
try turning the timer knob/programme selector dial round to a black dot, switch appliance off then back on again. the red light should flash once, then pause, then twice then pause then three times. the appliance should now be reset and your door should open, if not there could be a fault on the main pcb control unit.
hope this helps
kj
Posted on Nov 07, 2007
jason0110
  • 66 Answers
SOURCE: Door locked
sounds like your interlock has failed you can buy from any appliance spares outlet or online regards jason
Posted on Jun 15, 2008
  • 1462 Answers
SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Posted on Jul 10, 2008
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
  • 92 Answers
SOURCE: Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Posted on Jul 07, 2009
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
The door handle on my Indesit W83 just broke off and I can't open the door... Any tips for getting my clothes out?? :/
same thing happened to me with my indesit w10.....so now i have touse a screwdriver to lever the door open (could always buy another handle, but hey...).
there should be a hole where the handle would lever the metal catch open...stick a screwdriver / spoon in there and lever it open...there's a technique to it but have a play around, you'll work it out... its easy enough!
Jun 27, 2010 | Indesit W 83
Jul 07, 2009 | Indesit W 123 Front Load Washer
no easy way to open
Jul 10, 2008 | Indesit W 123 Front Load Washer
Door locked
Jun 08, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
