Question about Dell Dimension 4600 PC Desktop
Wont power back up
The system was turned on but idle for several hours. Suddenly it shuts off on its own. I cannot turn system on by pressing the button on the from of the processor. it will not restart. there is a small light on the processor that will flash on and off, but computer will not power up. what can be done?
    Top Expert:
  • Dell Master
  • 12,223 Answers
Take out the small battery lithium from +3vdc and measure it, it is lower replace, and clean the contacts, control the RAM, for many different opeation. and try again.
If the problem persist you have problem with the power supply, replace it.
God bless you
Posted on Jul 14, 2013
Bubbabear64
  • 2794 Answers
SOURCE: does not power up
Is the amber light flashing on the monitor?
If so, you should get your power supply checked.
Posted on Jun 11, 2008
SOURCE: Computer wont turn on
I had the same problem here. And sure enough it was the USB socket that had been bent inside or broken off. Basically the pins were touching the sides of the casing and causing it to short on power up.
I used the method suggested above - get a screwdriver and (MAKING SURE THE POWER IS OFF) bend the pins from the USB socket back into shape so they are no longer touching the side casing. The USB port is unusable but the machine powered up straight away and is now working fine.
Thanks for your help!!
Posted on Oct 31, 2008
wprodgers
  • 32 Answers
SOURCE: dell dimension e510 won't turn on
Unplug the power cable from the power supply in your computer and reinsert it. If you still have nothing, most likely a dead power supply.
Posted on Jan 24, 2009
SOURCE: Dell 5150c shuts down orange flashing light
It was a faulty or worn out power supply fan. I just replaced it and the computer has been running for about an hour and a half and still no shut down. The system temperature is stable. It runs quieter now. New fan cost 13.88CAD.
Posted on Apr 06, 2009
As a temporary measure, taking the side panel off the dell 5150c stopped it from shutting down, so in my case it was clearly a heat problem, as suggested by previous the poster. The following instructions assume you're comfortable replacing computer hardware components - do at your own risk!
The solution is to buy an 'air duster' and some thermal compound for the CPU heat sink. If your CPU fan doesn't sound healthy (mine didn't), also buy a new one (ca. £20 on ebay: search for G9474 ).
Read the service manual: http://support.dell.com/support/edocs/systems/dim5150C/en/sm/index.htm for details on how to install / remove the fan and heat sink.
Clean out dust from the heat sink with air duster. Remove the fan, and clean or replace (recommended). Also clean the grill in front of the fan. Clean off old thermal compound from the CPU / heat sink and replace with a thin layer of fresh compound. Replace heat sink and side panel and you're done.
Posted on May 12, 2009
Why does my insignia converter box shuts off by itself after several hours of watching tv? Model NS-DXA2.
The power saving feature may be enabled on the converter box. The setting counts from the last operation performed by the remote.
Press Menu and navigate to Settings with the up/down arrows. Press OK. Then navigate to Power Saving and press OK again. Use the Up/Down arrows to change the power saving option to 4 hours, 8 hours, Program (the current program listed in the EPG for the channel you are on), or Off. Press OK to save the setting and then press Menu again to exit the On-Screen Menu system.
I hope this helps.
(I had to turn off the Power Saving option for my converter box that is connected to my DVD recorder.)
Feb 07, 2015 | Insignia Televison & Video
Truck shuts off while in park idling.
Your car is 18 years old. It's likely history. Sell it as is for what you can get.
Jul 15, 2017 | 2000 GMC Yukon Denali
Sharp 80le632u lcd turn off randomly & suddenly
Checked Power Board is it any solder is not proper. Resolder all main point.
Jun 04, 2017 | Sharp Aquos Televison & Video
I have a DELL Latitude D510. Intermittenly the laptop suddenly looses power. The batteries are fully charged, and the power is plugged in. Most often it will not restart immediatelly after such a power...
It may be because of a virus causing your system turn off suddenly. If you are sure that your system is free from Virus, then it may be because of processor over heating. If the processor heat reaches maximum limit, it shuts off the system automatically to prevent physical damage like burning, etc,. So, check weather your lappy's vent fan is working properly or not and clean if there are any obstacles like dust which are causing your processor over heating. Get back to me if this doesn't help...
Thanks
Dec 21, 2009 | Dell Latitude D510 Notebook
Downloaded update, next day I got the blinking red light
Mate if you turn your PS3 off when the hard drive is still operating or the power shuts of while playing a game and the PS3 is collecting or writing data to your hard drive, it will most definitely corrupt or even destroy your hard drive it is very common in PC's to.
Hint:
1. Do not shut down your PS3 while it is saving a game or collecting info from the hard drive. Rather quit the game then press your off key with one quick touch and let go of it, it will shut down when it is ready or hold down on the remote's PS button and select switch off system on screen.
2. If you live in a area where the power shuts off for no reason please please get your self a computer UPS(UN-INTERRUPTED POWER SUPPLY).
3. If you replace the hard drive make sure you buy a good quality hard drive like a Western Digital or Seagate.
Sep 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Diplomat adp 8242 beeps twice one flashing light not working. turn off leave for hours then might work.
Turn off plack power button, turn back on, then press cycle selection button 4 times very quickly. flashing lights should change, shut machine and it should fire up and work...... it worked for me. May have to try it several times as getting the 4 button press timed right can be a bit tricky.
Jul 13, 2009 | Dishwashers
Why does my computer suddenly shut down during use?
remove the side panel and have a look if your cpu fan is turning.... you may need to blow the dust and dirt out of it as well... if the tower even feels remotely warm that's likely the issue... also check the fan on the power supply. either way it will likely need to be cleaned
Robert
Jan 13, 2009 | Computers & Internet
Acer travelmate 2420
Hello! :)
The first thing I would have you do is to shutdown the computer (Hold the power button until the system turns off) and retry the format. Are you using a Microsoft XP disc or a recovery disc? If your not sure just post with all of the text that appears on the CD.
Sep 11, 2008 | Acer TravelMate 2300 Notebook
Dell Dimension 4600 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
