Question about Water Heaters
50 gallon tall gas hot water heater - Water Heaters
  • Water Heaters Master
  • 5,245 Answers
Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/Which-is-best-gas-water-heater.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Just add a comment at your convenience and describe what you want to know about your 50 gallon gas water heater, and include if this is new heater or older heater and what is going on.
Posted on Jul 14, 2013
  • 2976 Answers
SOURCE: takes a long time to heat water
If you are using a 3/8" copper line for your gas, get it replaced ASAP. It will fail. 1/2" Black Iron is required with natural gas. 50 gallons is a lot of water to heat. Look on the heater label for the recovery rate.
Posted on Feb 27, 2009
  • 62 Answers
SOURCE: GE 40 Gallon Natural Gas Tall Water Heater won't
Is it a new unit? If so, the safety mechanism may has tripped. If it is a GE built be Rheem, the safety device is a one time device - you have to replace the water heater. Check to maek sure you don't having a venting problem.
Posted on Jul 14, 2009
  • 297 Answers
SOURCE: Rheem 50 gallon gas water heater less than one
it could also be the dip tube. this is a tube that is installed at the time the unit is made.it is a plastic tube that is on the cold intake side of the hot water heater.it may have fallen inside the unit or may not be in the unit at all check to see if there is a plastic tube this will help the heater stay hotter for a longer period of time. good luck with your project.
Posted on Sep 29, 2009
  • 21 Answers
SOURCE: I have a Rheem Warrior Glass water heater for a
Probably a 40 gallon one ... if it's electric you probably have a burned out element. (easily replaced)
Posted on Nov 27, 2009
heatman101
  • 43501 Answers
SOURCE: Pilot will not relight properly
The thermocouple needs to be replaced. That is what keeps the pilot light lit. The thermocouple is the little metal probe that sticks up into the pilot flame. Very easy to replace.
heatman101
Posted on Mar 26, 2010
Just re[placed the upper and lower element on our hot water heater. That was three hours ago. the water is still cold.
Push in reset button located on upper thermostat.
Push circuit breaker fully off and then fully on.
Make sure tank is filled with water before turning power ON or elements will burn out
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
Gene
Oct 03, 2014 | Reliance 606 Series 50 Gallon Tall Gas...
Gallon
Copy following links for lighting and troubleshooting gas water heater.
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Clean air intake, inspect for tripped FV system
Post more detailed question on pro water heater forum
Or call plumber
Jun 01, 2013 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water running on floor
your tank is probably going bad in your water heater the shut off valve would be your homes water supply valve.
Jul 04, 2012 | Whirlpool 6th Sense 50-Gallon 6-Year Tall...
Which one is compatable water heater to Rheemglas fury Model#41V50?
You have 6-year 50 gallon gas water heater:
42V50 would be the newer model number. They make tall and short models.
http://www.rheem.com/product.aspx?id=CC643E03-4C15-4775-B139-E504A95651F7
All brands of water heater are good.
So any 50 gallon gas water heater from local box store or hardware is good product.
Tanks with longer warranty last longer. So 9-year and 12-year water heater will last longer, unless you have very hard water or odor in water and need to change frequently.
I recommend avoiding water heaters with electronic controls since they are not protected from power surge and can cost more to repair.
Additional resources:
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 31, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
6 yr old electric rheem fury 50 gallon all of a sudden runs out of hot water. Only one shower of hot water now where before atleast two.
you have a couple things that may cause this. you may have a bad element a bad thermastat a tripped eco (emergency cut off ) or problem with electric suppling heater.if you have no electric backround or training you should call a pro
Mar 25, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
35 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
