Question about Garden
Coil for o41 stihl farmboss chainsaw serial no. 5744323
  • 1,807 Answers
Here is the full illustrated parts diagram.
Posted on Jul 16, 2013
  • 2692 Answers
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
SOURCE: Stihl Farmboss - cord will not move
try taking plug out to see if it turns then.if not take off pull cord assembley to see if something has come loose and jammed flywheel, failing that could possibly have snapped the piston ring and jammed. oh yes one last thing check clutch if you have chain brake on and clutch is jammed obviously wont turn.
Posted on Dec 24, 2009
dontbother10
  • 2220 Answers
SOURCE: Problem with cord on Stihl 029 Farmboss chainsaw
A written diagnosis by a good independent saw shop ($10-20, I recommend Stihl) might be a good idea at this point.
1. Remove the starter housing. Does the starter operate smoothly? If yes, reinstall the cover and continue with 2, if no repair starter.
3. Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? May be caused by leaky intake connection at the engine or carburetor.
· Remove the spark plug wire and plug. Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
· Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
· Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
4. The last likely possibility is the saw has jumped timing. This problem or any not discussed is usually beyond the ability of the operator to repair. Please take it to a good local saw seller/mechanic for a written diagnosis before authorizing any repair. HTH
Lou
Posted on Jan 04, 2010
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
Need sparkplug wire for ms180c chainsaw
Robert, spark plug wire for Stihl MS 180C. Check the attached links, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Ignition Coil Spark Plug Wire Fits Stihl 017 018 Ms170 Ms180...
New Ignition Coil Spark plug wires for Stihl 017 018 MS170 MS180 Chainsaw...
Amazon com IGNITION COIL MODULE FITS STIHL MS170 MS180 017 018 ENGINE...
Jul 30, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Chain Saw Stihl 290 Farmboss wont idle well
Check to see if the air filter is clean. If it is, increase the idle speed adjustment screw on the carburetor.
Feb 09, 2014 | Stihl Garden
Now spark on a stihl farmboss041 chainsaw
The best thing and not so cheap is to replace the points with a electronic ignition coil. We do this at our shop all the time.
Sep 26, 2012 | Stihl Garden
Coil settings for stihl chainsaw
Use a business card. You can use it on any 2-cycle equipment and get a good gap. Or, take a microfiche card and fold it in half.
Jan 16, 2012 | Stihl Garden
What should the coil gap be on a stihl 034 chainsaw
the coil gap on that saw is 10-15 thousandths
find parts and details about Stihl at dealers like www.arcolawn.com
Joe
Jan 01, 2011 | Standard Oregon Chainsaw Chain For Stihl...
I have a stihl 041 farmboss and I am getting excessive bar oiling on the chain and bar. I was wondering if there is an ajustment to control the amount of lubrication to the chain and bar. Thanks Jim
Yes, but the location of the oiler is a secret.
An entire thread dedicated to your question follows (see post 5):
http://www.arboristsite.com/showthread.php?t=33705&highlight=041+oiler+adjustment
Please go here and request a manual. Please ask they add one that can downloaded too.
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 12, 2010 | Garden
Dec 21, 2009 | Garden
Parts breakout for stihl 041 (farmboss) chain saw
Stihl has terminated almost ALL support for this model and Illustrated Parts Lookups are not available online for Stihl products.
Oct 05, 2009 | Heavy Machinery
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
