Question about Dell Vostro 1700 Notebook
Sudden death Laptop was working fine (running on mains, battery full). Made a small noise and went completely dead. Now totally unresponsive when I press the start button. No lights, nothing.
  • 40 Answers
Mostly looks like hardware problem with your laptop as no lights are turning on.Check if power button is turned on.if its still unresponsive then conatct dell support.Below is the link for dell support:
http://support.euro.dell.com/support/index.aspx
Regards,
Rahul
Posted on Jul 14, 2013
  • 3940 Answers
SOURCE: laptop won't start
Most likely, a bad motherboard. Here is a link to the Dell troubleshooting tool for this model system:
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&dl=false&l=en&s=gen&treeid=542FE6FE783DC236E040AE0AB7E1692B&doclang=en
Posted on Apr 05, 2009
mwalker02
  • 41 Answers
SOURCE: Screen went black,but still on...turned it off...now won't start up.
All Dell laptops have a similar design flaw (in my opinion). The socket where the power cord plugs in to the laptop is probably loose. Use a toothpick or something to check it. Don't use anything metalic. If the socket moves easily then it has probably come loose from the motherboard. You may want to take the laptop to a computer repair shop to have the power socket soldered back to the motherboard. If you have the knowledge you can do this yourself but I don't suggest it. Laptops have a LOT of small parts. Hope this helps! Thanks!
Posted on Jun 01, 2009
haayz
  • 197 Answers
SOURCE: Won't Start No lights flashing does nothing when I hit the power button
Try taking out battery and plug in power. If it works, battery is faulty.
If not, try taking out your hard disk plug in power, if it works, hard disk is faulty.
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Posted on Jun 02, 2009
shynysaxena
  • 166 Answers
SOURCE: My Dell Latitude D600 Battery is not working?
I can understand. But here is a very strict word of caution for you. I hope you must have already heard about spoiled battery cases from many vendors like Lenovo, Compaq & Dell also. In that case, all these companies have decided to change laptop's battery for free. Please check out if your battery also falls under same category of faulty batteries.
If yes then contact Dell Customer care for assistance & replacement of battery because it may turn out as an explosion also !!!
If this solution was helpful to you then please rate 100% (or FIXYA) for this solution, otherwise don't rate at all. It was my pleasure helping you.
With regards,
Shyny Saxena
Posted on Jun 29, 2009
budmrtn
  • 11361 Answers
SOURCE: My laptop was working fine when the keyboard
You need to look and see if the ribbon cable may have come off the connector.
Posted on Dec 23, 2009
What causes dials to go crazy on instrument panel, then car dies?
It sounds like an alternator related issue. Once the battery drops below 12 volts it will do lots of silly things with gauges and thats why when you change it all works fine. Check that with engine running with a volt meter you have 13.8 to 14.2 volts across the battery, if not you may have an alternator issue
Oct 08, 2014 | 1998 Oldsmobile 88
Tip
This is a nice simple solution to a problem commonly experienced with Toshiba...
This is a nice simple solution to a problem commonly experienced with Toshiba laptops or notebooks. Please remember this is not a guaranteed solution as there may be other factors involved as to why your laptop is failing to start e.g faulty RAM.
However, this is a very common issue that appears with these laptops and hence the reason for the Tip. It is very simple to do, involves no cost and often resolves the problem without any further intervention.
If your Toshiba laptop has mysteriously turned itself off and is now totally unresponsive or appears completely dead and won't turn back on - then read on.
Symptoms:
  • Laptop mysteriously turns itself off and will not turn back on
  • Laptop appears completely dead/black screen/unresponsive
  • Laptop refuses to charge the battery when connected to the mains supply i.e. No charge light showing.
  • There may be a brief flash of the screen or power button when you try to turn it on but then it immediately shuts off again.
Solution:
  • If the laptop is still connected to the mains unplug it completely
  • Remove the battery from underneath the machine by releasing the locking tabs (or screws dependant on your version).
  • *Important*: With the battery removed - press and hold down the power button for at least 20 seconds. This is to remove any residual power from the laptop.
  • Reinstall the battery and plug the laptop back in to the mains.
  • Turn laptop on as normal and hopefully it should power up.
As stated at the outset, in some instances there will be other reasons as to why your laptop is not turning on. However, because these symptoms are a common yet often overlooked problem with this laptop, it is highly recommended to troubleshoot this procedure first before resorting to testing or replacing any hardware.
If the problem has failed to resolve using this simple step then please see my Hardware troubleshoot LapTop Will Not Turn On or Boot
This includes a video walkthrough to help guide you through the process.
Please do help by registering your vote for this Tip using the buttons below.
on Mar 06, 2010 | Baby Care
Tip
If your Toshiba Laptop Will Not Turn On
Symptoms:
Solution:
on Jan 25, 2010 | Computers & Internet
Running fine, all of a sudden car is completely dead
sounds like short somewhere draining battery. Might be alternator causing this also. can have it checked at autozone at no cost....good luck and hope this info helps....Please rate this post.
Aug 15, 2012 | 1995 Nissan Maxima
Hp zd9500 My I.T. put in a new hard drive the other day and it was running fine. Today I turned it on, it was booting up and then went completely dead - no lights, or anything. The power cord is working -...
You could test to see if hard drive is culprit by removing the drive. This is done by removing the access panel on bottom of laptop and slipping out the drive. Once out, try turning on laptop. It won't boot up, but you should get power light on.
I suspect you will not.
If so, problem is in power supply within laptop. Fixing requires a full diagnostic check of the power supply and battery charger. I highly recommend a trained technician for that.
Oct 05, 2009 | HP Pavilion dv6000z Notebook
Car won't start
Either an interior light or head lights were left on all night, or there's a dead short in the electrical system, or... the battery completely failed internally such as a weak spot or defect in the plates. At any rate, it all obviously points to the battery. Replace the battery.
Feb 23, 2009 | 2006 Infiniti M35
Kawasaki zzr400 (1994 model),streetfighter wont start
Its Starter relay may be causing main problem. You can try Yezdis starter relay as it can help you solving your problem
Jan 22, 2009 | 1994 kawasaki ZZR 400
check starter solenoid.see if getting power to starter side when pressing button .if yes check if power to starter w/ test light when pressing button.if power there check starter,also motor, will it turn manually or is it seized.if no power to starter side of solenoid, jump across solenoid posts w/ a large screwdriver -motor will probaly turn over,w/ key on.if small wire to solenoid has power when pressing start,solenoid bad,if no power, wiring or start button bad.
Jan 22, 2009 | 1997 kawasaki ZZR 400
Dead laptop
Check the ac adapter is the proper one for that laptop. Check the power jack is not damaged or loose. let laptop site without battery or power for a few hours. remove battery and retry power. try another ac adapter if that doesn't work, you may have a reset button but not likely to solve the problem. sounds like motherboard is damaged, or something blew.
Aug 27, 2007 | Compaq Presario M2000 Notebook
Dell Vostro 1700 Notebook Logo
Alun Cox
