Question about Tools & Hardware - Others
What these type of nails called?
See picture
    New Friend:
  • 4 Answers
What?
Posted on Jul 14, 2013
  • yoghurt_nutt Jul 15, 2013
    Hey, do you know what this type of nail this is in the picture?
How do I hang a picture using picture hooks?
You should have two 'pin' nails that hammer through the two nail guides at top. You picture will need wire hanger which settles into the lower hook part of the picture hook.
Nov 25, 2014 | Ook Picture Hanger Shield"
Deformed and yellow toe nails
first, cut as short as possible. Soak them in vinegar and sulfur powder daily to get rid of the fungus you have. 15 minutes and make sure your nails are in the solution. Disinfect your clippers, etc, your hands after touching your feet. Probably need to disinfect all footwear, wash socks daily. May take 1-6 weeks -
Jun 04, 2013 | Health & Beauty
What degree nails to use?
Your gun uses 22 degree round head plastic strip nails. Most likely nail that is easy to find in stores is 21 degree nails for Hitachi , Duo Fast and others. Both work ok.
Apr 03, 2013 | Porter Cable Cable No. FR350A Rnd Head...
My N88rh shoots two nails at a time
N88rh uses a full round head plastic collated nails which are spaced apart enough that the driver cannot hit two nails at once. If your are using other nails that fit into your magazine that are closer together you may in fact drive two nails at once. If, however you are using the correct nail and the nailer shoots twice, then you probable have a very sensitive firing valve. You could change the TVA6 valve or change the actual trigger. To overcome this problem of double firing and you do not want to try changing the firing valve, you need to change the trigger to sequential type instead of bump fire type. This trigger is usually white and will only permit one nail to be fired. Check www.toolpartsdirect.com or bostitch.com for parts. Good holiday
Nov 28, 2010 | Stanley Bostitch N88rh Framing Nailer...
My nail gun was fired and its air flowed through the trigger, but the nails don't shoot out. Why is this? Please assist me.
nail jam remove air, open front of nailer, make sure the shaft goes back up in..also check for incorrect size or type nails
Oct 22, 2010 | Nailers 3 12" Pneumatic Air Round Head...
Not sure how to load nails into magazine
Generally two reasons for nails not to make contact with driver. Make sure that the driver is returning to top of cylinder. If it stays in the path of the nail feeder, the nail cannot slide into position. Second, nails are not the right type or gauge for gun. Some nails even if they are the right gauge have a large head not allowing the strip to enter into chamber. Remove air hose from gun, check that piston is all the way up, then slide nails into chamber and see if they go all the way in easily with-out having to push. You should see the first nail in place from bottom where nail shoots out. The angle of the nail is very important. most pin nailers are 0 degree (not angled), but others have an angle. The gun should be labeled as to angle of nail. Hold a strip of nails against the outside of the magazine and see is the first nail is in line with the driver path. Good luck and post again if you have other question.
Jun 28, 2010 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
I just bought a porter cable fr350a nail gun and need to know what type and angle nail goes in it.
it will shoot a nail from .113 to .148 diameter plastic collated full round head from 2" to 3 1/2" 22degree nail. If you want you can download the instruction manual from Dewaltservicenet.com and type in your model number under looking for manual it is 15 pages long. If I have helped you with your request would you please rate this response accordingly and thank you.
Nov 12, 2009 | Porter Cable Cable No. FR350A Rnd Head...
Problem accessing nails
Hi, No you can't. They are two different feeds. The F33 uses tape feed and the N79 uses stick feed. The N79 is a basic wood frame nailer that uses 3 to 3 1/4 sticks, while the F33 uses up to 2 1/2 paper feed. The stick nails are the most common for the older nailers and on the box look for Bostitch as the brand to fit, as the N79 was sold under that brand not Stanley. This should Fixya!
Mar 02, 2009 | Stanley F33PT Paper Tape Framing Nail
Nail Guns Types
The real different between nail gun's models are the sort of power supply they use. A nail gun can be powered by compressed air, electricity or batteries, or electromagnetism. Some small guns are powered by butane, a fuel that causes a small explosive charge to drive the nail into the wood. The most common type of nail gun is the pneumatic nailer, which works with compressed air.
Aug 27, 2008 | Stanley Pneu Roof Stapler
Tools & Hardware - Others Logo
26 people viewed this question
Top Tools & Hardware - Others Experts
ray gallant
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
