Question about Kenmore 43142 Front Load Washer
Model 110.475 discharge hose leaking
Movers must of crimped the hose it seams to be spirting water right were it comes out the back of washer. I cant find any information on replacing this hose.
jsrock516
  • 5911 Answers
SOURCE: washer leaking water from underneath
Your leak could be coming from the rubber door seal. Inspect all the way around the rubber seal paying particular attention to the areas behind the rubber seal where it meets the wash tub. They wear with age and can develop small holes. When they start leaking it appears like water coming from under the machine. I hopes this helps.
Posted on May 12, 2007
SOURCE: Kenmore Washer Top Load Series 60 won't drain
The water pump is a belt-driven device actuated by a clutch. Your problem could be:
1. Stuck pulley - break it loose and WD-40 it
2. Broken belt - replace
3. Bad clutch - call repair or replace
There is almost nothing that can go wrong in the pump itself. It's probably one of these three.
Posted on Dec 16, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE3T washer leaking water
The rubber seal is called the "bellow". Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. All three sites offer great service, so shop around for the best prices.
For instructions on how to replace the bellow yourself, follow this link:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair, but it can be a bit intimidating to a beginner. If you have questions along the way, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 31, 2009
SOURCE: washer leaks water in the back of the washer but i
I have a Kenmore front loading washer HE2 Plus.
Started leaking only 6 months old from the back over the spin motor.
I found a bolt had come out of the motor bracket causing the motor to crack a small hole in the plastic outer drum. I've been down for about a month waiting on the part and service. This is under warranty and we cant get any help any sooner from sears, not even a loaner.
Will not purchase Kenmore products again, 2nd front loader from Kenmore, 2nd problems.
Posted on Nov 15, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore elite He3 leaking water into tub
Outstanding diagnosis. You are correct to assume a water inlet problem and, "yes", this can be a common problem. If you live in area that has hard water, or if you use well water, sediment, rust and calcified deposits can clog the small diaphragms inside the valve causing them not to close properly and leak by. You can attempt to clean the valve by removing it and submerging it in a 50/50 solution of distilled vinegar and hot water for about 30 minutes, Sometimes this can dissolve any clogs and restore the valve to full operate. However, if this does not work, you will need to replace the valve.
The following link explains the steps required to replace the valve if you need directions:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I have included web resources to search for replacement parts.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on May 30, 2010
The black hose that drains the water out has come off and draining water straight out as it fills. I cannot for the life of me figure out where it connects to. Any help would be great!
The black discharge hose (the J shaped one) is connected to the output side of the discharge pump inside the washer. It's likely the hose has come off.
  • first, unplug the washer.
  • Shut off the hot and cold water faucets to the washer.
  • Pull the washer away so you have access to the back.
  • Remove screws holding the back panel in place.
  • Remove panel.
  • Examine the hose where it attaches to the pump. Look for cracks, holes or broken ends.
  • Examine the clamp attaching the hose. Is it broken or worn?
  • Replace any of the above hoses and/or clamps if faulty with hardware comparable with your model. Re-assemble in reverse sequence of dis-assembly.
  • Attach hot/cold water lines.
  • Ensure ALL excess water has been removed before plugging washer in. Ensure ground wire is attached!
  • Plug washer in and start cycle. Examine for leaks.
Feb 01, 2016 | Washing Machines
My whirlpool duet front load has been leaking. It leaks only when doing a load of laundry. Leak is coming out the back and on the right side. Took the front bottom off to see if I can see anything and...
First, make sure that the washing machine is not too close to the wall behind it. This could crimp the drain hose & force water out at the connection behind the machine. This could also crack/split the washer machine's port (to which the drain hose attaches). Second, check the hose clamp for a secure hold at the washer machine's port, & check the drain hose for leaks & for insertion in the drain tube at the wall.
Feb 22, 2015 | Whirlpool Washing Machines
Water leaked out from under washer while it was running. No leaks visible from hose connections at hose bibs, nor where water supply lines (hot and cold) thread on to the top right at the back. No leaks...
I would open the door and puled up the bottom. Part were that fan twister spins on the bottom.. and check that the ida filler is not gonskie or may be blokidge right there So water would v come out. And clean it all there. It prolly never been done ????. Hope that helps ?? Tony
Apr 19, 2017 | Kenmore 24732 Top Load Washer
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
Ge front loader leaks when filling
Leaks are probably going to come from one of 4 places:
  1. Door gasket: water should run down the face of the washer from the lowest point of the door.
  2. Water connectors: left rear of machine
  3. Soap drawer: water running down front of machine from the upper left-hand side
  4. Discharge pump and hoses: Right side.
Rear right would probably indicate a discharge hose leak. Front right would most likely be the discharge pump and/or connectors to it. Here's a diagram:
If you don't see any of the easily visible leaks (door, soap dispenser, connectors), try to
pop off the front access panel by removing the 3 bottom screws. Once removed try to determine where the leak is originating from...then we can troubleshoot more. If you find this advice helpful, please don't forget to rate me -- trying to get my Guru level so I can offer premium support
Jun 23, 2010 | General Electric WCVH6800J Front Load...
Water will not drain out of washer
Disconnect the discharge hose from the washer and look for a clog at both ends of the hose. Also, look down where the discharge port is on the washer and clear out the clog there also. If you see no clogs, then make sure your discharge hose is not crimped at such an angle to prevent water from flowing through. Also, make sure your discharge hose is not running on the floor and that it goes vertical straight 4.5 to 5 feet from the floor and then loops directly into the discharge pipe. Give that a shot. Still no water drain? Then the water pump needs to be replaced.
Feb 19, 2010 | Kenmore 80754 Top Load Stacked Washer /...
A leak under the washer. model Splendide wd802
well there is a seal between the tub of the washer and the transmissition you cant see it utill you take it apart so just fill the tub with water and dont let the pumps or motors run if you are getting water from around the transmition that is your problem i have a maytag and that gasket cost just under 70 bucks so much cheaper than buying new washer
Mar 31, 2009 | Washing Machines
Kenmore Elite Washing Machine leaking water
Okay...my experience with this model front loader leads to the following possible problems:
CAUTION: UNPLUG the washer if you plan to service the interior. It is dangerous to have your hands inside the unit with moving parts and energized. Plug the washer back in and stand back if you plan on doing any operation checks.
1. Door bellow ripped or torn (this is the gray rubber boot around the door - open the door and inspect along the entire door boot. Including the areas behind the rubber fold where the rubber meets the wash tub. It is common for them wear out and tear. NOTE: Make sure the fill hose on the left-hand side of the door boot is fully snug in place. Sometimes it will come loose and leak BEHIND the door boot.
2. Drain pump or hoses leaking - You will need to remove the lower panel under the door to see inside the washer. Remove the three torx type screws under the front lip at the bottom of the panel. For easier access, place a small block of wood under each front foot. The washer is heavy so you may need assistance to lift the front slightly. CAUTION: Do not lift on the door, push on the door panel or control panel. If the panel sticks, slightly tap on the sides and it will drop down and come off. The pump is located in the front under the wash tub. Make sure the clean out trap is snug and all your hoses are tight and not torn. Check the drain hose that leads out of the back of the washer from the drain pump to ensure it is not cracked.
3. Air Dome hose has come loose from the tub - This will be a small rubber hose connected to a plastic piece (called an air dome) on the right-hand side of the wash tub as you are looking in from where you removed the bottom panel. It should be located behind the drain pump and mounted physically to the wash tub. The other end of this hose runs to the pressure switch, which turns the water flow off when the washer tub fills to the approriate level. If this hose comes off, the washer will start to leak on the FILL cycle and will not shut off. I don't think this is what you are talking about, but it is still worth a look since you have the panel opened.
4. Tub seal leaking or tub cracked - These would be the most undesirable of all possible problems because it would require the removal of the entire wash tub in order to correct. Inspect the wash tub seam and make sure there's no water coming from around the tub.
I hope this gives you a few possible items to work with. Inpsect the washer interior when you get the panel off and post back if you can determine where the leak is coming from.
HELPFUL HINT: Put the washer into diagnostics mode if you plan to leak test. At the control panel select DRAIN/SPIN, NO SPIN and press any key under OPTIONS 4 times (it must be the SAME key, however). "C00" will be displayed on the operator console, and you will hear the door latch engage. The washer will run through a series of tests by filling using hot and cold water, checks all your dispenser features, tumbles the drum, spins and drains. This diagnostics can be stopped at any time by pressing the PAUSE/CANCEL button twice. The drain pump will come on and drain the washer.
I hope this helps you...
Feb 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
47 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
