Question about Sansui HDLCD4050 TV
Sansui HDLCD4050C 40" TV -Horizontal Lines bottom half issues. What is wrong?
I bought my Sansui HDLCD4050C 40" tv last Feb 2012 at BJs Warehouse. It is in perfect condition and has had regular daily use. never bumped or dropped and regularly dusted. Today suddenly I have a horizontal line thru the middle and the bottom half is either a different color, flickering, or a lighter contrast depending on what is showing on the tv. What is wrong?
    Top Expert:
  • Sansui Master
  • 74,136 Answers
It sounds that the vertical output section has the fault. Contact any service technician. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Posted on Jul 15, 2013
rulds2008
  • 3866 Answers
SOURCE: No surround sound
Your not goingto achive true dobly sound you need a HDMI solution for this and hence you dvd player is rather old since it does not use HDMI if you want true HDMI sound you need to purchase a DVD with HDMI outputs to the TV
Posted on May 25, 2009
mbostermeyer
  • 58 Answers
SOURCE: I have a Sansui 19
That model of tv has problems with the bulb overheating. Just try to keep it from getting to hot, and let it cool down if it happens.
Posted on Oct 24, 2009
  • 8909 Answers
SOURCE: Sir, My Sansui TV has switch
I suspect a power supply fault. Check for dry joints around any heavy component, transformers, heatsinks with transistors on etc, as they are most likely to suffer from dry joints.
Hope this helps.
Posted on Nov 17, 2010
  • 597 Answers
SOURCE: Sansui HDLCD2612 LAST NIGHT THE PICTURE
Firstly, the extended warranty is a very cheap insurance, because the labor could be as high as $168/hr. Instead of putting $200+ in this unit, I would purchase another with 3-5 yr warranty.
Posted on Jun 10, 2011
SD Tech
  • 14553 Answers
SOURCE: I have a 42" Plasma Sansui and just recently there are now multiple lines running through the screen. This makes it impossible to watch. I've tried the power, cords, stations, etc. Any ideas of pr
Ten years is two lifetimes for a Plasma, it most likely is either the display panel itself or a main board, in either case not cost effective to repair or smart but the real problem would be parts, I bet almost zero is available for this.
Posted on Dec 11, 2012
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
Why half screen is ok, other half I.e. bottom part horizontal lines are seen.
Your LCD or Control Board is damaged. You can replace the LCD or the Board or have someone do it for you.
Aug 03, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Horizontal lines on SONY TV
the ribbon flat connection tapes that connect the led panel driver to the panel have prob delaminated
this cant be repaired easily and you would need to replace the panel
Dec 05, 2014 | Sony KDL40EX520 Bravia KDL-40EX520 40 Inch...
Dale 42 inch plasma TV model number w4201chd
Take it back to the place you bought it from they will most likely fix it if you have a warranty. Thats your only choice if you want it fixed unless if you wanna pay a hundred bucks to get a 3rd party lcd put in it haha.
Jun 19, 2013 | Televison & Video
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
Our LN40A630 has three horizontal white lines across the screen on power up (center, center of upper half , and center of lower half). After about five minutes the lines go away. Tried Picture Test in...
This is a sign of your LCD panel beginning to die. Sometime soon those lines won't fade away and will become permanent parts of your TV screen.
Considering the fact that your TV is approx 3-4 years old, this is normally the expected lifespan of a TV. Once the TV becomes unwatchable, your best bet would be to begin shopping for a new one.
Mar 07, 2011 | Samsung LN40A630 40 in. LCD TV
Colored thinline on right side of screen from bottom to top
try going to where you bought the tv. they might have a record of the purchase. was the warranty with the store or manufacturer. if with the store they should definately have records.
Mar 29, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sansui HDLCD4050 TV Logo
94 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
