Question about Giant MTX 250
Parts where can I get replacement brake handles?
Is this one of those "Who's buried in Grant's tomb?" kind of questions? Just in case the question was asked in all seriousness, you might try going to.....a bike shop!
Posted on Jul 14, 2013
How too release the emergency brake foot pedal when the cable is broken?
About 73,400 results (0.87 seconds) Search Results
    Parking brake release cable snaps - Chevy Avalanche Fan Club of ...
    chevyavalanchefanclub.com > ... > Problems: Brakes
    24 posts - ‎16 authors
    Went to release the parking brake on my 04 and the cable snapped. ... More like the end cap coming of the cable that attaches to the foot pedal. ..... Then I released the parking brake, pulled out the broken release cable/handle assembly, ...
    How To Install Repair Replace Parking Brake Release ...
    ? 5:54
    https://www.youtube.com/watch?v=qx0oGfV62NQ
    Jun 23, 2011 - Uploaded by 1A Auto Parts
    How To Install Repair Replace Parking Brake Release CableHandle ... or replace a broken or worn out parking brake release cable handle.
    Emergency Brake Pedal Assembly & Stuck Brake Cable ...
    ? 10:13
    https://www.youtube.com/watch?v=0jYfvthBzhU
    Apr 17, 2014 - Uploaded by corgLLC
    Emergency (Parking) Brake Pedal Assembly & Stuck Emergency (Parking) Rear Brake Cable The emergency ...
    E-Brake Cable Broken? Stuck Emergency Brake... Help Please ' Chevy ...
    www.tahoeyukonforum.com > ... > Engine & Drivetrain
Jan 25, 2016 | Cars & Trucks
Do i need a chevy brake tool to change drum brakes
There is no special tool for chevies, at least that I know of.
Go to any parts house, NAPA, Autozone, etc.) and pick up a pair of brake spring pliers. On the "Jaws" end will be two hooks for removing and replacing the springs. On the handle ends will be a socket looking tool which you use to compress and turn the dampers. The other handle will have a flattened shape, and a lip to rehook the springs. You will need a pry of some type to remove the drum, some flat end screw drivers, a pair of slip joint pliers, a set of box/open end wrenches, and of course a hammer.
Probably going to need to have them turned, common that they have "groves" which will wear the shoes faster.
Jul 31, 2014 | Brakes for Chevrolet Chevy
The brake release handle is broke and I can't get my emergency brakes to unlock
If you can remove parts under the steering wheel there are bolts that hold the break pedal mechanism in place. When it is unbolted it should be able to lower it so you can manually release it and replace the release handle. It sounds like a big job. I hope this helps.
Aug 29, 2011 | 1999 Dodge Caravan
My 21" Mastercraft self-propelled, 3-in-1 mulching
There is a flywheel brake that is contolled by the safety bar of the handle. If the cable to the safety bar has broken or is no longer attached the the flywheel brake will be on. Not only that there is an ignition Kill switch as part of the flywheel brake. If the brake is on, the kill switch is activated.
Your mower needs some simple maintenence
1. Recoil assembly repaired or replaced.
2, Throttle cable and control repaired or replaced (Item 10 below link)
3. User Safety Bar cable adjustment or replacement. (Item 11 below link)
The above items are not a good reason to call your mower a parts source.
Without a model number I had to GUESS which model this was.
This is my best guess:
http://www.jackssmallengines.com/help.cfm#/MTD/125-478C054_(1995)/General_Assembly/0054900-E/00549000001
Thanks for choosing FixYa,
Kelly
Jun 07, 2011 | Briggs & Stratton Garden
My parking brake light stays on even when releasing the parking brake handle.
Check your BRAKE switch under the steering column, just where ur brake pedal resting on it when ur not stepping on it! Connection might have been disconnected or the switch needs replacement! Taah!
Nov 11, 2010 | Ranger Pickups 19932010 Books
My saturns e-brake stoped working and wont stay up how can i fix that?
if you mean the parking brake, sounds like you have broken a cable. the cables keep tension on the handle and without that tension it won't stay up. also the broken cable would mean no parking brakes. if however the parking brakes work when you pull and hold the brake handle, then you have a broken part in the handle itself. you will need to get under it to figure out which cable is broken and replace it. the heat shielding may make this hard. I think the parking brake system is made of three separate cables, you can buy new ones at autozone, advance, ebay. stay away from dealers and used parts on this repair.
Mar 13, 2010 | Saturn SL2 Cars & Trucks
Replace parking brake handle
Same problem - the stupid thing just snapped off in my hand! Any idea how to install the replacement part? Am NOT going to the dealer unless I absolutely have to. Thanks!
Oct 21, 2009 | 2005 Chrysler Pacifica
2000 Chevrolet Silverado 1500 brake release cable broke and won't release the emergency brake. I checked the brake release handle and cable and discovered a small nut like metal piece on the floor below...
Same thing happened to me on my 2000 silverado July 3, 2009.
There is a release next to the parking brake pedal. You have to reach way under the dash but it has worked for me for the last month. I have the part to fix it but haven't had the time.
Jul 12, 2009 | 2000 Chevrolet Silverado 1500
Emergency Brake Cable Is Broken
Somewhat easy to replace. The part is a dealer item (purchase only from Chevrolet dealer) If you are going to do this yourself, take many photos on the progression of the job to refer back to when putting it back together. Good Luck!
Apr 21, 2009 | 1996 GMC Suburban
Giant MTX 250 Logo
Top Giant Cycling Experts
John Egan
John Egan
Mark Schmit
Mark Schmit
dante
Are you a Giant Cycling Expert? Answer questions, earn points and help others
