Question about Kenmore Washing Machines
Kenmore elite he4t washer error code FH C03
I have a Kenmore Elite HE4t (about 7 years old). It kept stopping at multiple points during the cycle and was showing FH error code. I ran the diagnostic/assessment and it stops at C03. I replaced the water inlet valve and reran the diagnostic before reassembling the top, etc. The diagnostic still stops at C03. What now? Machine is empty, was unplugged during valve change and I dont see any water leaking or showing up in drain pan.
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite HE4T Washer
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: washer - kenmore elite he 4t
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 30, 2010
SOURCE: Kenmore Elite HE4t washer won't spin
What does the S2 code stand for on a he4t washer
Posted on Oct 07, 2012
HE4t washer stops with 2 minutes left in cycle with a flashing F 2 error. How do I correct this?
When I had the problem of stopping and F-ing erroring out during the spin (when the machine is being shaken the most and at a high frequency) I pulled the control card and reflowed all the solder joints, took care of the problem for a few months.
The problem returned. I reasoned that the relays must be sticky/old/defective. I removed and replaced all the relays on the control board (cost like $35) and it has been problem-free for 3 years. This is an easy fix for someone who has soldering equipment and know-how.
May 22, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T won't stop on the Spin Cycle. Stays
Replaced the relays with the 16Amp rated ones from Digitel.
Aug 15, 2009 | Kenmore Elite 45986 Front Load Washer
The motor controller board is likely bad.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Getting f an h error code
ok do you have flood stop hoses on your machine. if you do take them off and get a bucket turn the hoses back on and fill the bucket if no water comes out of 1 of the hoses your problem is the hose. the error fh means fill hose.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite error code
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4T washer
Get the same code 2 minutes into cicle. F H
Nov 03, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
81 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
