Question about AEG Refrigerators
Confused by controls of AEG SANTO 75388
Hello. Please excuse probably "duhh" question but I'm confused by the controls on this F/Freeezer. On left is a dial marked 1-5 with a graduated line, thickening from 1-5. Next to it is a schematic picture of the F/F with the top half white and the bottom half black. Over on the right is a similar dial and graduated line going from H - 5 and a schematic with black at the top and white at the bottom. I'm guessing that the left controls the freezer and the right the fridge. Is this right and is 5 'coldest' and does the setting of one affect the operation of the other or are they independent? I ask because after i turned the left dial to 5 the fridge half stopped working and the usual fan noise you'd hear after shutting the fridge door stopped happening. I turned it off at the wall and the fan now makes a noise but I'm not sure if its getting colder. Your experience and thoughts would be much appreciated Ben
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 36 Answers
SOURCE: top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Posted on Dec 16, 2008
electrodynam
  • 35 Answers
SOURCE: AEG Santo fridge not cooling but freezer is working.
The compressor is obviously still good or the freezer wouldn't work.I'm sure you checked the settings,but turn the freezer all the way up (hot)after it is cool so the unit doesn't come on for the freezer,then turn the refrigerator controls all the way down to the coolest setting.listen for the compressor to start,and/or the fans to run.If the compressor starts,and no fan there may be a problem with the fan.(this is a general test I'm not familiar with your specific unit which may not have a fan,but most newer units do).If the compressor doesn't start after a short time the thermostat/control for the refrigerator section is broken,and needs replaced.
Posted on Mar 16, 2009
heatman101
  • 43501 Answers
SOURCE: Refrigerator will only get 58 degrees no colder,
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 28, 2010
SOURCE: AEG SANTO 3790-6 KG
hi i have got a fridgefreezer and it keeps beeping and also inside my fridge is warm but my freezer is ok what could this be
Posted on Jan 19, 2011
Finding a refrigerater seal for an old aeg santo 1605
HI DAN.wow still going hain.well u'll be lucky to find one.i think yours is a screw on seal.try matching it to a universal fridge door seal.and cut to size.no other way.:) good luck.ali
Jul 04, 2012 | AEG Refrigerators
Aeg santo 8600041 freezing with control set on lowest setting
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 24, 2011 | AEG Santo U 86000i Compact Refrigerator
Aeg santo has stopped working, no power to it
Check the wall outlet for power and your breaker box for a popped breaker. Rate me if I am correct!
Aug 26, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
My brother has a AEG fridge freezer he thinks the part number is either R600A or 412 or KG2 we need new door seals for both doors can you advise the part numbers needed? it is a fridge at the top and a...
The R600a is the isobutane gas in the system. The 412 is probably the alternate gas to be used. The KG2 is probably the weight. You have the make & model number above. most magnetic door seals will fit you buy it in a roll and cut it to size.
Apr 17, 2010 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo 1683-TK7 Led's and interior light flashes when door is opened
as rwsummers correctly points out replace this part as from uk i bought it from maplins £3.31 part no N74CN 1UF 275V de-solder the two points on rear of pcb and re-solder new part in place and reassemble turn on power and "voila" works like new. Thanks.
Oct 06, 2008 | AEG Refrigerators
AEG Santo
here is a link where you can download an english version http://www.nodevice.com/user_manual/aeg/refrigeration_1192865302/santo_3442_kg_glassline_621672048.html
you will need adobe reader to be able to read it, you can also download it for free. if this helped you then please leave feed back,cheers.
Feb 24, 2008 | AEG Santo 3888 KG8 Bottom Freezer...
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
ashburton
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
