Kenmore elite he4t washer FH C03
Cycle kept stopping and showing FH error code. Ran diagnostic, which stops at C03. Replaced water inlet valve and reran diagnostic. Still stops at C03. What now??
SOURCE: Kenmore Elite HE4T washer
Get the same code 2 minutes into cicle. F H
Posted on Dec 23, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Posted on Apr 19, 2009
  • 3741 Answers
SOURCE: Washer stops with F11 code; door won't open
F-11 ERROR CODE MEANS :
Serial Communication Error Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
TO RESOLVE THE PROBLEM:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Posted on May 05, 2009
pride applia
  • 232 Answers
SOURCE: Kenmore Elite quietpak9 HE4T washer FH error code
go 2 repair clinic on line, same codes for whirlpool duet repair help then error code tab
Posted on Dec 24, 2009
Getting oL code even after diagnostic check
OL, usually means Over Loaded. It is an error code thrown up by the on board computericon1.png.. generally when TOO much wet weight is in the bowl.
This condition is could be caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced.
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controller board is damaged and will need to be replaced.
Jan 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Fh showing on my kenmore washer
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Feb 27, 2013 | Kenmore Elite HE4 Electric Dryer
FH appears
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code
Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3
    Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
    One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
    If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
    Nov 28, 2010 | Kenmore Washing Machines
    Error code FH on my AWM, what does it mean?
    "FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
    Thank you !!
    Jul 12, 2010 | Whirlpool AWM8163 Front Load Washer
    What do these error codes mean?
    FH
    No water detected entering machine or pressure switch trip not detected
    If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
    OR
    If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
    Press PAUSE/CANCEL twice to clear the display.
    Possible Causes / Procedure
    • If there is no water in the unit:
    - Make sure that both valves at the water source(s) are turned on all the way.
    - Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
    - Verify inlet valve operation.
    • If there is water in the unit:
    - Verify drain pump operation.
    - Verify that the pressure switch hose is in good condition and properly connected to tub
    and pressure switch.
    1. Verify there is not a siphon problem.
    2. Unplug washer or disconnect power.
    3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
    and Central Control Unit (CCU).
    4. Check all hoses for possible leaks.
    5. Plug in washer or reconnect power.
    6. Verify pressure switch operation.
    7. Verify flow meter operation by blowing air through the part and measuring the resistance.
    8. Verify CCU operation by running a Diagnostic test or any cycle.
    Replace failed component.(usually this will be failed pressure switch. the hose should be replaced as well)
    Jul 20, 2009 | Kenmore Elite 45986 Front Load Washer
    take the lid off attached to the inlet valve to the dispenserr you will see a little white mechanisim in line with them. this is called your flowmeter take it off and blow through it is should sound like a cazoo. put it back on and try to do a wash cycle. if this doesn't help you need a new flowmeter. also if you take the kick panel off you will find the tech sheet to help you diagnose this problem.
    Jun 23, 2009 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    69 people viewed this question
    Top Washing Machines Experts
